[postgis-tickets] [PostGIS] #4044: PostgreSQL 11 regression failures on topology since March 3
trac at osgeo.org
Tue Mar 13 14:15:29 PDT 2018
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
Sorry guys been distracted lately and seems debbie has been chocking on
PostgreSQL 11 runs. I think it's changes upstream.
Has been happening since March 3rd (thus no doc builds since then for 2.5
either).
One issue is topology
https://debbie.postgis.net/job/PostGIS_Regress/8825/consoleFull
Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
TO '2.5.0devnext'
Upgrading PostGIS Topology in 'postgis_reg' using: ALTER EXTENSION
postgis_topology UPDATE TO '2.5.0devnext'
Died at ../../regress/run_test.pl line 1485.
failed (Error encountered altering EXTENSION POSTGIS_TOPOLOGY:
/var/lib/jenkins/workspace/postgis/tmp/2_5_pg11w64/regress_log)
sh: 1: createlang: not found
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
ERROR: column proc.proisagg does not exist
LINE 15: ...nd e.extname = $1 and c.relname = $2 AND
COALESCE(proc.prois...
HINT: Perhaps you meant to reference the column "proc.prolang".
QUERY: SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3 || ' ' ||
COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes) ||
')',typ.typname, cd.relname, op.oprname,
cs.typname || ' AS ' || ct.typname || ')
', opcname, opfname) || ';' AS remove_command
FROM pg_depend As d INNER JOIN pg_extension As e
ON d.refobjid = e.oid INNER JOIN pg_class As c ON
c.oid = d.classid
LEFT JOIN pg_proc AS proc ON proc.oid =
d.objid
LEFT JOIN pg_type AS typ ON typ.oid =
d.objid
LEFT JOIN pg_class As cd ON cd.oid =
d.objid
LEFT JOIN pg_operator As op ON op.oid =
d.objid
LEFT JOIN pg_cast AS ca ON ca.oid =
d.objid
LEFT JOIN pg_type AS cs ON ca.castsource =
cs.oid
LEFT JOIN pg_type AS ct ON ca.casttarget =
ct.oid
LEFT JOIN pg_opclass As oc ON oc.oid =
d.objid
LEFT JOIN pg_opfamily As ofa ON ofa.oid =
d.objid
WHERE d.deptype = 'e' and e.extname = $1 and c.relname =
$2 AND COALESCE(proc.proisagg, false) = $4;
CONTEXT: PL/pgSQL function postgis_extension_remove_objects(text,text)
line 27 at FOR over EXECUTE statement
make[2]: *** [Makefile:79: check] Error 1
make[2]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/2.5/topology/test'
make[1]: *** [Makefile:131: check] Error 2
make[1]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/2.5/topology'
make: *** [GNUmakefile:16: check] Error 1
Build step 'Execute shell' marked build as failure
An attempt to send an e-mail to empty list of recipients, ignored.
Triggering a new build of PostgreSQL stop
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4044>
