[postgis-tickets] [PostGIS] #4046: Revise Debbie Web Hook jobs (fix doc build)
trac at osgeo.org
Tue Mar 13 22:26:14 PDT 2018
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: trunk
Keywords: |
They changed the Generic Web Hook plugin to standardize on lowercase key
names
https://github.com/jenkinsci/generic-webhook-trigger-
plugin/blob/master/CHANGELOG.md
1.30 (2018-03-08 17:59:01)
No issue
improve header variable name description
Version 1.28 introduced RFC 2616 compatibility making all headers
lowercase.
This patch adds a note to make this fact more obvious.
Example situation where this matters: a CI systems that checks for X
-GitHub-Event header to make further decisions. Since 1.28 the resulting
variable changes from X_GitHub_Event to x_github_event effectively
breaking this process.
0fd81969349a1d0 jekader 2018-03-08 17:28:09
1.29 (2018-03-06 20:26:35)
GitHub #45 "This project is parameterized" parameters are being ignored if
triggered bug
Keeping default values in parameterized jobs #45
602ea1fd613abd2 Tomas Bjerre 2018-03-06 20:25:41
I think the 1.28 change is what broke the doc building (as Dan Baston
noticed) and the 1.30 will break the others, so have to change all of
those that use regex to match by lower case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4046>
