[postgis-tickets] [PostGIS] #4046: Revise Debbie Web Hook jobs (fix doc build)
trac at osgeo.org
Tue Mar 13 22:27:11 PDT 2018
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> They changed the Generic Web Hook plugin to standardize on lowercase key
> names
> https://github.com/jenkinsci/generic-webhook-trigger-
> plugi/blob/master/CHANGELOG.md
> 1.30 (2018-03-08 17:59:01)
> No issue
> improve header variable name description
> Version 1.28 introduced RFC 2616 compatibility making all headers
> lowercase.
> This patch adds a note to make this fact more obvious.
> Example situation where this matters: a CI systems that checks for X
> -GitHub-Event header to make further decisions. Since 1.28 the resulting
> variable changes from X_GitHub_Event to x_github_event effectively
> breaking this process.
> 0fd81969349a1d0 jekader 2018-03-08 17:28:09
> 1.29 (2018-03-06 20:26:35)
> GitHub #45 "This project is parameterized" parameters are being ignored
> if triggered bug
> Keeping default values in parameterized jobs #45
> 602ea1fd613abd2 Tomas Bjerre 2018-03-06 20:25:41
> I think the 1.28 change is what broke the doc building (as Dan Baston
> noticed) and the 1.30 will break the others, so have to change all of
> those that use regex to match by lower case.
New description:
names
plugin/blob/master/CHANGELOG.md
No issue
lowercase.
GitHub #45 "This project is parameterized" parameters are being ignored if
triggered bug
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4046#comment:2>
