[postgis-tickets] [PostGIS] #4042: rect tree test failure
PostGIS trac at osgeo.org
Thu Mar 15 17:49:52 PDT 2018
  Reporter:  dbaston  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by dbaston):
 ==4342==    at 0x4E51216: lw_dist2d_pt_seg (measures.c:2234)
 ==4342==    by 0x4E82C6B: rect_leaf_node_intersects (lwtree.c:131)
 ==4342==    by 0x4E82C6B: rect_tree_intersects_tree_recursive
 (lwtree.c:949)
 ==4342==    by 0x4E82AD4: rect_tree_intersects_tree_recursive
 (lwtree.c:963)
 ==4342==    by 0x4E82A69: rect_tree_intersects_tree_recursive
 (lwtree.c:973)
 ==4342==    by 0x41FAE7: tree_inter.constprop.0 (cu_measures.c:356)
 ==4342==    by 0x41FC4C: test_rect_tree_intersects_tree
 (cu_measures.c:409)
 ==4342==    by 0x52F9D36: ??? (in /usr/lib/x86_64-linux-
 gnu/libcunit.so.1.0.1)
 ==4342==    by 0x52FA06F: ??? (in /usr/lib/x86_64-linux-
 ==4342==    by 0x52FA3BD: CU_run_all_tests (in /usr/lib/x86_64-linux-
 ==4342==    by 0x40710C: main (cu_tester.c:173)
 ==4342==
 ==4342== Conditional jump or move depends on uninitialised value(s)
 ==4342==    at 0x4E510B9: lw_dist2d_pt_pt (measures.c:2286)
 ==4342==    by 0x4E51294: lw_dist2d_pt_seg (measures.c:2268)
 (lwtree.c:949)
 (lwtree.c:963)
 (lwtree.c:973)
 (cu_measures.c:409)
 ==4342==
 ==4342==    at 0x4E82AD7: rect_tree_intersects_tree_recursive
 (lwtree.c:963)
 (lwtree.c:973)
 (cu_measures.c:409)
 ==4342==
 (lwtree.c:963)
 (lwtree.c:973)
 ==4342==    by 0x41FC7B: test_rect_tree_intersects_tree
 (cu_measures.c:416)
 ==4342==
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4042#comment:4>
