[postgis-tickets] [PostGIS] #4044: PostgreSQL 11 regression failures on topology since March 3
PostGIS trac at osgeo.org
Sat Mar 17 11:36:43 PDT 2018
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by robe):
 * owner:  strk => pramsey
 * component:  topology => postgis
Comment:
 Weird it only broke in topology wonder if that's the only thing we are
 testing.
 strk you are brave enough I know you are or perhaps pramsey is braver.
 I challenge you two and don't try to cop out with "Can't fight with a
 girl" :)
 Anyway I took PG11 out of the tests until we fix it.  I'm tied up with
 other things at moment so feel free to work on it if you have time.  If
 you don't will have to wait till I'm less busy.
 And if I do it, I'm not back-porting it to 2.4 pramsey you hear that -
 robe will not back-port. robe does not want people using 2.4 for PG 11 and
 this is as perfect an excuse as any. Sure they'll still be able to
 compile, but they can't upgrade :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4044#comment:5>
