[postgis-tickets] r16469 - bah so close I remarked out an fi by mistake
Regina Obe lr at pcorp.us
Sat Mar 17 10:07:56 PDT 2018
Author: robe
Date: 2018-03-17 22:07:55 -0700 (Sat, 17 Mar 2018)
New Revision: 16469
   trunk/ci/debbie/postgis_release_docs.sh
References #4047
Modified: trunk/ci/debbie/postgis_release_docs.sh
--- trunk/ci/debbie/postgis_release_docs.sh	2018-03-18 04:59:30 UTC (rev 16468)
+++ trunk/ci/debbie/postgis_release_docs.sh	2018-03-18 05:07:55 UTC (rev 16469)
@@ -48,7 +48,7 @@
 echo "Micro: $POSTGIS_MICRO_VERSION"
 #inject a development time stamp if we are in development branch
 if [[ "$POSTGIS_MICRO_VERSION" == *"dev"* ]]; then
-  #mv postgis.xml postgis.xml.orig
+  cp postgis.xml postgis.xml.orig
   export GIT_TIMESTAMP=`git log -1 --pretty=format:%ct`
   export GIT_TIMESTAMP="`date -d @$GIT_TIMESTAMP`" #convert to UTC date
   echo "GIT_TIMESTAMP: ${GIT_TIMESTAMP}"
@@ -72,7 +72,7 @@
   make -C po/de/ local-html
   #make -C po/ko_KR/ local-html
   #make pdf-localized
-#fi
+fi
 package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
@@ -81,7 +81,7 @@
-mv postgis.xml.orig postgis.xml
+#mv postgis.xml.orig postgis.xml
 mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
 cp -R html/*.*  /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
