[postgis-tickets] r16477 - Seems sometimes the postgis_svn_revision.h gets wiped out, so end up with no svn number.
Regina Obe
lr at pcorp.us
Sun Mar 18 03:43:31 PDT 2018
Author: robe
Date: 2018-03-18 15:43:31 -0700 (Sun, 18 Mar 2018)
New Revision: 16477
branches/2.4/ci/debbie/postgis_release_docs.sh
Explicitly call svn_repo_revision.pl to ensure we have an svn number to read
References #4047 for PostGIS 2.4
Modified: branches/2.4/ci/debbie/postgis_release_docs.sh
--- branches/2.4/ci/debbie/postgis_release_docs.sh 2018-03-18 22:42:35 UTC (rev 16476)
+++ branches/2.4/ci/debbie/postgis_release_docs.sh 2018-03-18 22:43:31 UTC (rev 16477)
@@ -37,7 +37,13 @@
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
--without-raster
make clean
-export VREV=`cat postgis_svn_revision.h | awk '{print $3}'`
+# generating postgis_svn_revision.h in case hasn't been generated
+if test -f utils/svn_repo_revision.pl; then
+ echo "Generating postgis_svn_revision.h"
+ perl utils/svn_repo_revision.pl
+fi
+export VREV="`cat postgis_svn_revision.h | awk '{print $3}'`"
echo "SVN is ${VREV}"
cd doc
