[postgis-tickets] [PostGIS] #4051: Strange result with raster ST_Intersects
PostGIS trac at osgeo.org
Wed Mar 21 18:06:38 PDT 2018
 Reporter:  stev00   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.4.4
Component:  postgis  |    Version:  2.4.x
 Keywords:           |
 I have odd behaviour when trying to use the ST_Intersects function with
 rasters, which I am using to filter raster tiles using an index for an
 ST_Value call.
 On both Linux Red Hat (RDS) and Windows using Postgres 10.1 and Postgis
 2.4 I get a null result for the filter call for a very small number of
 point geometries (in fact only one so far from around 1000 points). The
 only significant feature is that the x value of this point is a whole
 integer.
 I am attaching a full sql file to reproduce a minimal version of the
 problem. If you look at the rasters in QGIS you should be able to see it
 covers the point, and adding a very small increment or decrement to the X
 value means a value is returned (but no difference with y value).
 This combined with the whole number issue above means I wonder if it is
 something to do with the integer value.
 I will continue looking into this, and it could obviously be a dependent
 library issue, but would be interested to see if others can reproduce it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4051>
