[postgis-tickets] [PostGIS] #4053: Memory leak in lwline_chaikin
PostGIS trac at osgeo.org
Fri Mar 23 02:24:01 PDT 2018
  Reporter:  Algunenano  |      Owner:  Algunenano
      Type:  defect      |     Status:  closed
  Priority:  high        |  Milestone:  PostGIS 2.5.0
 Component:  liblwgeom   |    Version:  trunk
Resolution:  fixed       |   Keywords:
Changes (by Raul Marin):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16485" 16485]:
 #!CommitTicketReference repository="" revision="16485"
 Fix memory leak in lwline_chaikin
 Closes https://github.com/postgis/postgis/pull/233
 Closes #4053
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4053#comment:2>
