[postgis-tickets] r16502 - update jenkins scripts with latest changes to can deploy like other branches
Regina Obe
lr at pcorp.us
Tue Mar 27 10:56:03 PDT 2018
Author: robe
Date: 2018-03-27 10:56:02 -0700 (Tue, 27 Mar 2018)
New Revision: 16502
Added:
branches/2.2/ci/debbie/postgis_make_dist.sh
branches/2.2/ci/debbie/postgis_release_docs.sh
branches/2.2/ci/debbie/postgis_doc_translations.sh
branches/2.2/ci/debbie/postgis_regress.sh
branches/2.2/ci/winnie/build_postgis.sh
branches/2.2/ci/winnie/package_postgis.sh
branches/2.2/ci/winnie/regress_postgis.sh
Modified: branches/2.2/ci/debbie/postgis_doc_translations.sh
--- branches/2.2/ci/debbie/postgis_doc_translations.sh 2018-03-27 17:38:18 UTC (rev 16501)
+++ branches/2.2/ci/debbie/postgis_doc_translations.sh 2018-03-27 17:56:02 UTC (rev 16502)
@@ -52,19 +52,21 @@
cp html/images/* images
#make epub
#make -e chunked-html 2>&1 | tee -a doc-errors.log
-make update-po
-make -C po/es/ local-html
-make -C po/fr/ local-html
-make -C po/it_IT/ local-html
-make -C po/pt_BR/ local-html
-make -C po/pl/ local-html
-make -C po/ko_KR/ local-html
-make pdf-localized
+#make update-po
+make html-localized
+# make -C po/es/ local-html
+# make -C po/fr/ local-html
+# make -C po/it_IT/ local-html
+# make -C po/pt_BR/ local-html
+# make -C po/pl/ local-html
+# make -C po/ko_KR/ local-html
cp -R html/*.* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
cp -R html/images/* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+#add back make pdf but after html copy so will work even if pdf generation fails
+make pdf-localized
cp -R po/*/*.pdf /var/www/postgis_stuff/
chmod -R 755 /var/www/postgis_stuff/postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}*.pdf
Added: branches/2.2/ci/debbie/postgis_make_dist.sh
--- branches/2.2/ci/debbie/postgis_make_dist.sh (rev 0)
+++ branches/2.2/ci/debbie/postgis_make_dist.sh 2018-03-27 17:56:02 UTC (rev 16502)
@@ -0,0 +1,35 @@
+#!/bin/bash
+set -e
+## begin variables passed in by jenkins
+export PG_VER=9.6
+# export PGPORT=8442
+export OS_BUILD=64
+# export POSTGIS_MAJOR_VERSION=2
+# export POSTGIS_MINOR_VERSION=2
+# export POSTGIS_MICRO_VERSION=0dev
+export PROJECTS=/var/lib/jenkins/workspace
+export GEOS_VER=3.6
+export GDAL_VER=2.2
+export WEB_DIR=/var/www/postgis_stuff
+export PATH="${PGPATH}/bin:$PATH"
+export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
+POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
+POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
+POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+export CONFIGURE_ARGS="--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}"
+#override the checkout folder used for building tar ball
+export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}"
+#fake production build
+#export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.0"
+sh make_dist.sh
+export package=${newoutdir}.tar.gz
+echo "The package name is $package"
+cp $package $WEB_DIR
+bash ci/debbie/postgis_release_docs.sh
Modified: branches/2.2/ci/debbie/postgis_regress.sh
--- branches/2.2/ci/debbie/postgis_regress.sh 2018-03-27 17:38:18 UTC (rev 16501)
+++ branches/2.2/ci/debbie/postgis_regress.sh 2018-03-27 17:56:02 UTC (rev 16502)
@@ -13,6 +13,7 @@
# export GDAL_VER=2.0
# export MAKE_GARDEN=1
# export MAKE_EXTENSION=0
+# export DUMP_RESTORE=1
## end variables passed in by jenkins
@@ -53,7 +54,9 @@
./configure \
--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config \
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
- --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config --without-interrupt-tests
+ --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config \
+ --without-interrupt-tests \
+ --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
make clean
## install so we can later test extension upgrade
make
@@ -73,6 +76,15 @@
fi
fi
+if [ "$DUMP_RESTORE" = "1" ]; then
+ echo "Dum restore test"
+ make install
+ make check RUNTESTFLAGS="-v --dumprestore"
+ if [ "$?" != "0" ]; then
+ exit $?
+ fi
+fi
if [ "$MAKE_GARDEN" = "1" ]; then
echo "Running garden test"
make garden
Added: branches/2.2/ci/debbie/postgis_release_docs.sh
--- branches/2.2/ci/debbie/postgis_release_docs.sh (rev 0)
+++ branches/2.2/ci/debbie/postgis_release_docs.sh 2018-03-27 17:56:02 UTC (rev 16502)
@@ -0,0 +1,85 @@
+#!/bin/bash
+export PG_VER=9.6
+export OS_BUILD=64
+#this is passed in via postgis_make_dist.sh via jenkins
+#export reference=
+export PGPATH=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
+./autogen.sh
+chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+echo $PATH
+#sh autogen.sh
+if [ -f GNUMakefile ]; then
+ make distclean
+fi
+# --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config
+# --without-raster
+CPPFLAGS="-I${PGPATH}/include" \
+LDFLAGS="-L${PGPATH}/lib" ./configure \
+ --with-pgconfig=${PGPATH}/bin/pg_config \
+ --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
+ --without-raster
+make clean
+cd doc
+mv postgis.xml postgis.xml.orig
+#sed -e "s:</title>:</title><subtitle><subscript>SVN Revision (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
+echo "Micro: $POSTGIS_MICRO_VERSION"
+#inject a development time stamp if we are in development branch
+if [[ "$POSTGIS_MICRO_VERSION" == *"dev"* ]]; then
+ export GIT_TIMESTAMP=`git log -1 --pretty=format:%ct`
+ sed -e "s:</title>:</title><subtitle><subscript>DEV TIMESTAMP (<emphasis>${GIT_TIMESTAMP}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
+fi
+make pdf
+rm -rf images
+mkdir images
+cp html/images/* images
+make epub
+make -e chunked-html 2>&1 | tee -a doc-errors.log
+if [[ "$reference" == *"trunk"* ]]; then #only do this for trunk because only trunk follows transifex
+ make update-po
+ make -C po/it_IT/ local-html
+ make -C po/pt_BR/ local-html
+ make -C po/ja/ local-html
+ make -C po/de/ local-html
+ make -C po/ko_KR/ local-html
+ #make pdf-localized
+fi
+package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
+export outdir=html
+tar -czf "$package" --exclude='.svn' --exclude='.git' --exclude='image_src' "$outdir"
+mv postgis.xml.orig postgis.xml
+mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
+cp -R html/*.* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+cp -R html/images/* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
+cp -R *.pdf /var/www/postgis_stuff/
+cp -R *.epub /var/www/postgis_stuff/
+cp -R $package /var/www/postgis_stuff/
Modified: branches/2.2/ci/winnie/build_postgis.sh
--- branches/2.2/ci/winnie/build_postgis.sh 2018-03-27 17:38:18 UTC (rev 16501)
+++ branches/2.2/ci/winnie/build_postgis.sh 2018-03-27 17:56:02 UTC (rev 16502)
@@ -2,21 +2,25 @@
set -e
#### $Id:build_postgis210.sh 10208 2012-08-30 05:38:22Z robe $
#all these get passed in by jenkins
-#export OS_BUILD=64
+#export OS_BUILD=64
#export PG_VER=9.2beta2
#export PGHOST=localhost
#export PGPORT=8442
#export PGUSER=postgres
-#export GEOS_VER=3.4.0dev
-#export GDAL_VER=1.9.1
#POSTGIS_SVN_REVISION=passed_in_by_buildbot
#POSTGIS_MAJOR_VERSION=2
#POSTGIS_MINOR_VERSION=1
#POSTGIS_MICRO_VERSION=0SVN
#export GCC_TYPE=gcc48 #for pre-4.8.0 compiles this is blank
-#export JSON_VER=0.9
-#export SFCGAL_VER=1.0.4
-#export PROJ_VER=4.8.0
+export SFCGAL_VER=1.3.2
+export GEOS_VER=3.6.2
+export GDAL_VER=2.2.4
+export PROJ_VER=4.9.3
+export PCRE_VER=8.33
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export CGAL_VER=4.11
export LIBXML_VER=2.7.8
@@ -46,6 +50,7 @@
echo PATH BEFORE: $PATH
export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
#export PROJSO=libproj-0.dll
@@ -52,6 +57,7 @@
export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
+echo POSTGIS_MICRO_VERSION: $POSTGIS_VER
if [[ "$POSTGIS_MICRO_VERSION" == *SVN* || "$POSTGIS_MICRO_VERSION" == *dev* ]] ; then
export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_VER}
else
@@ -61,7 +67,7 @@
#export POSTGIS_SRC=${PROJECTS}/postgis/trunk
export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
-# export REL_PGVER=$(echo $PG_VER | tr '.' '')
+# export REL_PGVER=$(echo $PG_VER | tr '.' '')
# echo $REL_PGVER
# export RELDIR=${MINGPROJECTS}/postgis/builds/postgis-21
# export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w64
@@ -68,8 +74,14 @@
#export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
export PATH="${PGPATH}/bin:${PGPATH}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/xsltproc:${PATH}"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
echo PATH AFTER: $PATH
+export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig
cd ${POSTGIS_SRC}
if [ -e ./GNUMakefile ]; then
make distclean
@@ -90,14 +102,13 @@
fi
if [ -n "$SFCGAL_VER" ]; then
- ##hard code versions of cgal etc. for now
- export CGAL_VER=4.2
BOOST_VER=1.53.0
#BOOST_VER_WU=1_49_0
export BOOST_VER_WU=1_53_0
export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
- CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+CFLAGS="-Wall -fno-omit-frame-pointer" \
LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
--host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
@@ -107,10 +118,15 @@
--with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
--with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
- --with-gui --with-gettext=no --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
- --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}
-elif [ "$POSTGIS_MAJOR_VERSION" == "2" ] ; then
+ --with-gui --with-gettext=no \
+ --with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
+ --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
+ --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} \
+ --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
+else
@@ -117,32 +133,20 @@
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
--with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
--with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
-else
-CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
- LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
- --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
- --with-pgconfig=${PGPATH}/bin/pg_config \
- --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
- --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
- --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
- --with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
- --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
- --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
- --with-gettext=no
fi;
-#make clean
-##hack to get around boolean incompatibility now only needed for 2.0 (no longer for 2.1)
-if [ "$POSTGIS_MINOR_VERSION" == "0" ] ; then
-cp ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h.for_compile ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h
-fi;
+make clean
#patch liblwgeom generated make to get rid of dynamic linking
sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
+#make uninstall
make && make install
Modified: branches/2.2/ci/winnie/package_postgis.sh
--- branches/2.2/ci/winnie/package_postgis.sh 2018-03-27 17:38:18 UTC (rev 16501)
+++ branches/2.2/ci/winnie/package_postgis.sh 2018-03-27 17:56:02 UTC (rev 16502)
@@ -9,13 +9,19 @@
#POSTGIS_MICRO_VERSION=0dev
-#export GDAL_VER=2.0.0
#export OS_BUILD=32
-#export PROJ_VER=4.9.1
#export GCC_TYPE=
-#export SFCGAL_VER=1.1.0
-#export PCRE_VER
if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
export PROJECTS=/projects
export MINGPROJECTS=/projects
@@ -48,13 +54,16 @@
export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_MINOR_VER}
- export svnurl="http://svn.osgeo.org/postgis/branches/${POSTGIS_MINOR_VER}"
+ export svnurl="https://svn.osgeo.org/postgis/branches/${POSTGIS_MINOR_VER}"
else
#tagged version -- official release
export POSTGIS_SRC=${PROJECTS}/postgis/tags/${POSTGIS_MINOR_VER}.${POSTGIS_MICRO_VERSION}
- export svnurl="http://svn.osgeo.org/postgis/tags/${POSTGIS_MINOR_VER}.${POSTGIS_MICRO_VERSION}"
+ export svnurl="https://svn.osgeo.org/postgis/tags/${POSTGIS_MINOR_VER}.${POSTGIS_MICRO_VERSION}"
fi;
+if [[ "$reference" == *trunk* ]] ; then
+ export svnurl="https://svn.osgeo.org/postgis/trunk"
+fi;
#POSTGIS_SVN_REVISION=will_be_passed_in_by_bot
@@ -88,12 +97,13 @@
# it seems 9.2 and 9.3 doesn't come with its own libiconv good grief
# and trying to use their libiconv2.dll makes shp2pgsql crash
if [[ "$PG_VER" == *9.2* || "$PG_VER" == *9.3* ]]; then
- cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
+ cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
fi;
-cp ${PGPATHEDB}/bin/libpq.dll $outdir/bin/postgisgui
-#cp ${PGPATHEDB}/bin/libiconv2.dll $outdir/bin/postgisgui
+cp ${PGPATHEDB}/bin/libpq.dll $outdir/bin/postgisgui
+#cp ${PGPATHEDB}/bin/libiconv2.dll $outdir/bin/postgisgui
cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
-cp ${PGPATHEDB}/bin/libintl.dll $outdir/bin/postgisgui
+cp ${PGPATHEDB}/bin/libintl*.dll $outdir/bin/postgisgui
cp ${PGPATHEDB}/bin/ssleay32.dll $outdir/bin/postgisgui
cp ${PGPATHEDB}/bin/libeay32.dll $outdir/bin/postgisgui
@@ -116,6 +126,9 @@
cp ${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
+#for protobuf
+cp ${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin/libprotobuf-c-*.dll $outdir/bin
echo "POSTGIS: ${POSTGIS_MINOR_VER} r${POSTGIS_SVN_REVISION} http://postgis.net/source" > $verfile
@@ -122,7 +135,7 @@
## only copy gdal components if 2+. 1.5 doesn't have raster support
cp -p ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
cp -rp ${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal $outdir/gdal-data
if [ "$POSTGIS_MINOR_VERSION" > "0" ] ; then
## only copy pagc standardizer components for 2.1+
cp -p ${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/bin/libpcre-1*.dll $outdir/bin
@@ -133,7 +146,6 @@
## only copy cgal and sfcgal stuff if sfcgal is packaged
- export CGAL_VER=4.6.1
export BOOST_VER=1.59.0
export BOOST_VER_WU=1_59_0
export GMP_VER=5.1.2
@@ -142,12 +154,15 @@
echo "Boost VERSION: ${BOOST_VER} http://www.boost.org" >> $verfile
echo "GMP VERSION: ${GMP_VER} https://gmplib.org" >> $verfile
echo "MPFR VERSION: ${MPFR_VER} http://www.mpfr.org" >> $verfile
cp -p ${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
cp -p ${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/*.dll $outdir/bin
# cp -p ${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
# cp -p ${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/*.dll $outdir/bin/postgisgui
fi;
+echo "PROTOBUF VERSION: ${PROTOBUF_VER} https://github.com/google/protobuf" >> $verfile
+echo "PROTOBUF-C VERSION: ${PROTOBUFC_VER} https://github.com/protobuf-c/protobuf-c" >> $verfile
#cp ${MINGPROJECTS}/libxml/rel-libxml2-2.7.8w${OS_BUILD}/bin/*.dll $outdir/bin/
cp ${PGPATHEDB}/bin/libxml2-2.dll $outdir/bin/
@@ -183,7 +198,9 @@
#cp topology/README* ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
#cp utils/* ${RELDIR}/${RELVERDIR}/utils
#cp extras/* ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}/extras
-cp -r extensions/*/sql/* ${RELDIR}/${RELVERDIR}/share/extension
+cp ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
+cp ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${RELDIR}/${RELVERDIR}/share/extension
+cp ${PGPATH}/share/extension/address_standardizer*${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
cp -r extensions/*/*.control ${RELDIR}/${RELVERDIR}/share/extension
cp -r extensions/*/*.dll ${RELDIR}/${RELVERDIR}/lib #only address_standardizer in theory has this
#cp extensions/postgis_topology/sql/* ${RELDIR}/${RELVERDIR}/share/extension
Modified: branches/2.2/ci/winnie/regress_postgis.sh
--- branches/2.2/ci/winnie/regress_postgis.sh 2018-03-27 17:38:18 UTC (rev 16501)
+++ branches/2.2/ci/winnie/regress_postgis.sh 2018-03-27 17:56:02 UTC (rev 16502)
@@ -1,16 +1,15 @@
#!/bin/bash
set -e
-#winnie passed in variables
-#export GCC_TYPE=gcc48
-#export PG_VER=9.3
-#export PROJSO=libproj-0.dll
-#export POSTGIS_MAJOR_VERSION=2
-#export POSTGIS_MINOR_VERSION=2
-#export POSTGIS_MICRO_VERSION=0dev
export PATHOLD=$PATH
@@ -54,6 +53,11 @@
#PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+#add protobuf
+export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
echo WORKSPACE IS $WORKSPACE
@@ -81,15 +85,14 @@
- BOOST_VER=1.59.0
- export BOOST_VER_WU=1_59_0
+ export CGAL_VER=4.11
+ BOOST_VER=1.53.0
+ #BOOST_VER_WU=1_49_0
+ export BOOST_VER_WU=1_53_0
- #this is a major cludge but only building with pcre support if SFCGAL is built - can't figure out how to do this without passing PCRE
- #TODO: turn back on topology regression testing once topology issues resolved
@@ -99,10 +102,15 @@
- --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} --without-interrupt-tests
+else
@@ -109,32 +117,17 @@
-else
- --with-gettext=no
fi;
make clean
-fi;
@@ -152,17 +145,19 @@
cp topology/*.dll ${PGPATHEDB}/lib
cp postgis/postgis*.dll ${PGPATHEDB}/lib
cp raster/rt_pg/rtpostgis-*.dll ${PGPATHEDB}/lib
- cp -r extensions/*/sql/* ${PGPATHEDB}/share/extension
+ cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
+ cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${PGPATHEDB}/share/extension
+ cp -r ${PGPATH}/share/extension/address_standardizer*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
cp -r extensions/*/*.control ${PGPATHEDB}/share/extension
cp -r extensions/*/*.dll ${PGPATHEDB}/lib
make check RUNTESTFLAGS="--extension -v"
##test address standardizer
cd ${POSTGIS_SRC}
cd extensions/address_standardizer
make installcheck
##test tiger geocoder
cd ${POSTGIS_SRC}
cd extensions/postgis_tiger_geocoder
@@ -172,6 +167,15 @@
fi
fi
+ make install
+ exit $?
+ fi
+fi
if [ "$MAKE_GARDEN" == "1" ]; then
make garden
