[postgis-tickets] [PostGIS] #4059: Please avoid use of variable length array
PostGIS trac at osgeo.org
Wed Mar 28 01:22:57 PDT 2018
 Reporter:  vmo      |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.5.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 While trying to compile with Microsoft Visual, I came across this use of
 variable length array (in geography_centroid.c) because the compiler
 doesn't support those.
     case MULTIPOINTTYPE:
         LWMPOINT* mpoints = lwgeom_as_lwmpoint(lwgeom);
         /* average between all points */
         uint32_t size = mpoints->ngeoms;
         POINT3DM points[size];
                 uint32_t i;
                 for (i = 0; i < size; i++) {
             points[i].x = lwpoint_get_x(mpoints->geoms[i]);
             points[i].y = lwpoint_get_y(mpoints->geoms[i]);
             points[i].m = 1;
                 lwpoint_out = geography_centroid_from_wpoints(srid,
 points, size);
         break;
 This is a tad dangerous IMHO with geometries, since they can be
 arbitrarily large (let's take the geographic centroid of a pointcloud ;)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4059>
