[postgis-tickets] r16503 - Fix crasher in raster when fed an empty raster (note was tempted to change the def of empty raster to include raster with no bands but not sure where else that is used, so just revised the clip check to not try to clip if no bands).
Regina Obe
lr at pcorp.us
Wed Mar 28 01:37:30 PDT 2018
Author: robe
Date: 2018-03-28 01:37:30 -0700 (Wed, 28 Mar 2018)
New Revision: 16503
trunk/doc/reference_raster.xml
trunk/raster/rt_pg/rtpg_mapalgebra.c
trunk/raster/test/regress/tickets.sql
trunk/raster/test/regress/tickets_expected
References #3055 for PostGIS 2.5 (trunk),
also minor doc fix references #2925 for PostGIS 2.5 (trunk)
Modified: trunk/doc/reference_raster.xml
--- trunk/doc/reference_raster.xml 2018-03-27 17:56:02 UTC (rev 16502)
+++ trunk/doc/reference_raster.xml 2018-03-28 08:37:30 UTC (rev 16503)
@@ -1132,7 +1132,7 @@
FROM st_gdaldrivers()
ORDER BY short_name;
- short_name | long_name | can_write
+ short_name | long_name | can_write
AAIGrid | Arc/Info ASCII Grid | t
ACE2 | ACE2 | f
@@ -1845,7 +1845,7 @@
</informalfigure></para>
<programlisting>
-- this will output a black circle taking up 150 x 150 pixels --
-SELECT ST_AsPNG(ST_AsRaster(ST_Buffer(ST_Point(1,5),10),150, 150, '2BUI'));</programlisting>
+SELECT ST_AsPNG(ST_AsRaster(ST_Buffer(ST_Point(1,5),10),150, 150));</programlisting>
<para><informalfigure>
<mediaobject>
@@ -3795,7 +3795,7 @@
ARRAY[1,3,2]::int[]
- bandnum | pixeltype | nodatavalue | isoutdb | path | outdbbandnum
+ bandnum | pixeltype | nodatavalue | isoutdb | path | outdbbandnum
1 | 8BUI | | t | /home/pele/devel/geo/postgis-git/raster/test/regress/loader/Projected.tif | 1
3 | 8BUI | | t | /home/pele/devel/geo/postgis-git/raster/test/regress/loader/Projected.tif | 3
@@ -7204,7 +7204,7 @@
ORDER BY 1, 2;
- query | bandnum | pixeltype | nodatavalue | isoutdb | path | outdbbandnum
+ query | bandnum | pixeltype | nodatavalue | isoutdb | path | outdbbandnum
1 | 1 | 8BUI | | t | /home/pele/devel/geo/postgis-git/raster/test/regress/loader/Projected.tif | 1
1 | 2 | 8BUI | | t | /home/pele/devel/geo/postgis-git/raster/test/regress/loader/Projected.tif | 2
@@ -7295,7 +7295,7 @@
ORDER BY 1, 2;
@@ -8337,7 +8337,7 @@
)).* AS metadata;
- upperleftx | upperlefty | width | height | scalex | scaley | skewx | skewy | srid | numbands
+ upperleftx | upperlefty | width | height | scalex | scaley | skewx | skewy | srid | numbands
0.5 | 0.5 | 10 | 20 | 2 | 3 | 0 | 0 | 10 | 0
</programlisting>
@@ -8347,9 +8347,9 @@
<refsection>
<title>See Also</title>
<para>
- <xref linkend="RT_ST_MetaData" />,
- <xref linkend="RT_ST_RastFromHexWKB" />,
- <xref linkend="RT_ST_AsBinary" />,
+ <xref linkend="RT_ST_MetaData" />,
+ <xref linkend="RT_ST_RastFromHexWKB" />,
+ <xref linkend="RT_ST_AsBinary" />,
<xref linkend="RT_ST_AsHexWKB" />
</para>
</refsection>
@@ -8390,7 +8390,7 @@
)).* AS metadata;
</programlisting>
@@ -8400,9 +8400,9 @@
<refsection>
<para>
- <xref linkend="RT_ST_RastFromWKB" />,
+ <xref linkend="RT_ST_RastFromWKB" />,
</para>
</refsection>
@@ -8471,7 +8471,7 @@
<refsection>
<para>
</para>
</refsection>
@@ -8515,7 +8515,7 @@
<programlisting>
SELECT ST_AsHexWKB(rast) As rastbin FROM dummy_rast WHERE rid=1;
- st_ashexwkb
+ st_ashexwkb
010000000000000000000000400000000000000840000000000000E03F000000000000E03F000000000000000000000000000000000A0000000A001400
</programlisting>
@@ -8525,7 +8525,7 @@
<refsection>
<para>
</para>
</refsection>
@@ -15578,30 +15578,30 @@
<programlisting>
$ ps aux | grep postgres
postgres 31713 0.0 0.4 179012 17564 pts/0 S Dec26 0:03 /home/dustymugs/devel/postgresql/sandbox/10/usr/local/bin/postgres -D /home/dustymugs/devel/postgresql/sandbox/10/pgdata
-postgres 31716 0.0 0.8 179776 33632 ? Ss Dec26 0:01 postgres: checkpointer process
-postgres 31717 0.0 0.2 179144 9416 ? Ss Dec26 0:05 postgres: writer process
-postgres 31718 0.0 0.2 179012 8708 ? Ss Dec26 0:06 postgres: wal writer process
-postgres 31719 0.0 0.1 179568 7252 ? Ss Dec26 0:03 postgres: autovacuum launcher process
-postgres 31720 0.0 0.1 34228 4124 ? Ss Dec26 0:09 postgres: stats collector process
-postgres 31721 0.0 0.1 179308 6052 ? Ss Dec26 0:00 postgres: bgworker: logical replication launcher
+postgres 31716 0.0 0.8 179776 33632 ? Ss Dec26 0:01 postgres: checkpointer process
+postgres 31717 0.0 0.2 179144 9416 ? Ss Dec26 0:05 postgres: writer process
+postgres 31718 0.0 0.2 179012 8708 ? Ss Dec26 0:06 postgres: wal writer process
+postgres 31719 0.0 0.1 179568 7252 ? Ss Dec26 0:03 postgres: autovacuum launcher process
+postgres 31720 0.0 0.1 34228 4124 ? Ss Dec26 0:09 postgres: stats collector process
+postgres 31721 0.0 0.1 179308 6052 ? Ss Dec26 0:00 postgres: bgworker: logical replication launcher
$ cat /proc/31718/limits
-Limit Soft Limit Hard Limit Units
-Max cpu time unlimited unlimited seconds
-Max file size unlimited unlimited bytes
-Max data size unlimited unlimited bytes
-Max stack size 8388608 unlimited bytes
-Max core file size 0 unlimited bytes
-Max resident set unlimited unlimited bytes
-Max processes 15738 15738 processes
+Limit Soft Limit Hard Limit Units
+Max cpu time unlimited unlimited seconds
+Max file size unlimited unlimited bytes
+Max data size unlimited unlimited bytes
+Max stack size 8388608 unlimited bytes
+Max core file size 0 unlimited bytes
+Max resident set unlimited unlimited bytes
+Max processes 15738 15738 processes
<emphasis role="strong">Max open files 1024 4096 files</emphasis>
-Max locked memory 65536 65536 bytes
-Max address space unlimited unlimited bytes
-Max file locks unlimited unlimited locks
-Max pending signals 15738 15738 signals
-Max msgqueue size 819200 819200 bytes
-Max nice priority 0 0
-Max realtime priority 0 0
+Max locked memory 65536 65536 bytes
+Max address space unlimited unlimited bytes
+Max file locks unlimited unlimited locks
+Max pending signals 15738 15738 signals
+Max msgqueue size 819200 819200 bytes
+Max nice priority 0 0
+Max realtime priority 0 0
Max realtime timeout unlimited unlimited us
</programlisting>
Modified: trunk/raster/rt_pg/rtpg_mapalgebra.c
--- trunk/raster/rt_pg/rtpg_mapalgebra.c 2018-03-27 17:56:02 UTC (rev 16502)
+++ trunk/raster/rt_pg/rtpg_mapalgebra.c 2018-03-28 08:37:30 UTC (rev 16503)
@@ -3022,8 +3022,8 @@
/* raster is empty, return empty raster */
- if (rt_raster_is_empty(arg->raster)) {
- elog(NOTICE, "Input raster is empty. Returning empty raster");
+ if (rt_raster_is_empty(arg->raster) || rt_raster_get_num_bands(arg->raster) == 0) {
+ elog(NOTICE, "Input raster is empty or has no bands. Returning empty raster");
rtpg_clip_arg_destroy(arg);
PG_FREE_IF_COPY(pgraster, 0);
Modified: trunk/raster/test/regress/tickets.sql
--- trunk/raster/test/regress/tickets.sql 2018-03-27 17:56:02 UTC (rev 16502)
+++ trunk/raster/test/regress/tickets.sql 2018-03-28 08:37:30 UTC (rev 16503)
@@ -112,3 +112,8 @@
DROP TABLE IF EXISTS test_raster_scale_small;
SET client_min_messages TO DEFAULT;
+ #3055 ST_Clip() on a raster without band crashes the server
+SELECT ST_SummaryStats(ST_Clip(ST_MakeEmptyRaster(42, 42, 0, 0, 1.0, 1.0, 0, 0, 4269), ST_MakeEnvelope(0, 0, 20, 20, 4269)));
Modified: trunk/raster/test/regress/tickets_expected
--- trunk/raster/test/regress/tickets_expected 2018-03-27 17:56:02 UTC (rev 16502)
+++ trunk/raster/test/regress/tickets_expected 2018-03-28 08:37:30 UTC (rev 16503)
@@ -12,3 +12,5 @@
t
test_raster_scale_small|rast||1
ERROR: new row for relation "test_raster_scale_small" violates check constraint "enforce_scaley_rast"
+NOTICE: Input raster is empty or has no bands. Returning empty raster
+NOTICE: Invalid band index (must use 1-based). Returning NULL
