[postgis-tickets] [PostGIS] #2925: [raster] ST_AsPNG does not support 2BUI. Potential regression
trac at osgeo.org
Wed Mar 28 01:53:20 PDT 2018
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.4.4
Component: documentation | Version: 2.1.x
Resolution: | Keywords:
Comment (by robe):
In [changeset:"16504" 16504]:
#!CommitTicketReference repository="" revision="16504"
Fix crasher in raster when fed an empty raster (note was tempted to change
the def of empty raster to include raster with no bands but not sure where
else that is used, so just revised the clip check to not try to clip if no
bands).
References #3055 for PostGIS 2.4.4,
also minor doc fix references #2925 for PostGIS 2.4.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2925#comment:8>
