[postgis-tickets] [PostGIS] #3055: [raster] ST_Clip() on a raster without band crashes the server
PostGIS trac at osgeo.org
Wed Mar 28 01:53:20 PDT 2018
  Reporter:  pracine  |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.2.7
 Component:  raster   |    Version:  2.1.x
Resolution:           |   Keywords:
Comment (by robe):
 In [changeset:"16504" 16504]:
 #!CommitTicketReference repository="" revision="16504"
 Fix crasher in raster when fed an empty raster (note was tempted to change
 the def of empty raster to include raster with no bands but not sure where
 else that is used, so just revised the clip check to not try to clip if no
 bands).
 References #3055 for PostGIS 2.4.4,
 also minor doc fix references #2925 for PostGIS 2.4.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3055#comment:10>
