[postgis-tickets] r16506 - Fix crasher in raster when fed an empty raster (note was tempted to change the def of empty raster to include raster with no bands but not sure where else that is used, so just revised the clip check to not try to clip if no bands).
Regina Obe
lr at pcorp.us
Wed Mar 28 02:07:16 PDT 2018
Author: robe
Date: 2018-03-28 02:07:16 -0700 (Wed, 28 Mar 2018)
New Revision: 16506
branches/2.2/NEWS
branches/2.2/raster/rt_pg/rtpg_mapalgebra.c
branches/2.2/raster/test/regress/tickets.sql
branches/2.2/raster/test/regress/tickets_expected
Closes #3055 for PostGIS 2.2.7
reorder NEWS tickets numerically
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2018-03-28 09:02:04 UTC (rev 16505)
+++ branches/2.2/NEWS 2018-03-28 09:07:16 UTC (rev 16506)
@@ -2,11 +2,13 @@
2018/xx/xx
* Bug Fixes *
+ - #3055, [raster] ST_Clip() on a raster without band crashes the server
+ (Regina Obe)
- #3965, ST_ClusterKMeans used to lose some clusters on initialization
(Darafei Praliaskouski)
- #3978, Fix KNN when upgrading from 2.1 or older (Sandro Santilli)
+ - #4017, lwgeom lexer memory corruption (Peter E)
- #4055, ST_ClusterIntersecting dropping SRID (Daniel Baston)
- - #4017, lwgeom lexer memory corruption (Peter E)
PostGIS 2.2.6
Modified: branches/2.2/raster/rt_pg/rtpg_mapalgebra.c
--- branches/2.2/raster/rt_pg/rtpg_mapalgebra.c 2018-03-28 09:02:04 UTC (rev 16505)
+++ branches/2.2/raster/rt_pg/rtpg_mapalgebra.c 2018-03-28 09:07:16 UTC (rev 16506)
@@ -3025,8 +3025,8 @@
/* raster is empty, return empty raster */
- if (rt_raster_is_empty(arg->raster)) {
- elog(NOTICE, "Input raster is empty. Returning empty raster");
+ if (rt_raster_is_empty(arg->raster) || rt_raster_get_num_bands(arg->raster) == 0) {
+ elog(NOTICE, "Input raster is empty or has no bands. Returning empty raster");
rtpg_clip_arg_destroy(arg);
PG_FREE_IF_COPY(pgraster, 0);
Modified: branches/2.2/raster/test/regress/tickets.sql
--- branches/2.2/raster/test/regress/tickets.sql 2018-03-28 09:02:04 UTC (rev 16505)
+++ branches/2.2/raster/test/regress/tickets.sql 2018-03-28 09:07:16 UTC (rev 16506)
@@ -112,3 +112,8 @@
DROP TABLE IF EXISTS test_raster_scale_small;
SET client_min_messages TO DEFAULT;
+ #3055 ST_Clip() on a raster without band crashes the server
+SELECT ST_SummaryStats(ST_Clip(ST_MakeEmptyRaster(42, 42, 0, 0, 1.0, 1.0, 0, 0, 4269), ST_MakeEnvelope(0, 0, 20, 20, 4269)));
Modified: branches/2.2/raster/test/regress/tickets_expected
--- branches/2.2/raster/test/regress/tickets_expected 2018-03-28 09:02:04 UTC (rev 16505)
+++ branches/2.2/raster/test/regress/tickets_expected 2018-03-28 09:07:16 UTC (rev 16506)
@@ -12,3 +12,5 @@
t
test_raster_scale_small|rast||1
ERROR: new row for relation "test_raster_scale_small" violates check constraint "enforce_scaley_rast"
+NOTICE: Input raster is empty or has no bands. Returning empty raster
+NOTICE: Invalid band index (must use 1-based). Returning NULL
