[postgis-tickets] r16970 - Remove use of VLA from geography centroid
Paul Ramsey
pramsey at cleverelephant.ca
Thu Nov 1 12:31:24 PDT 2018
Author: pramsey
Date: 2018-11-01 12:31:24 -0700 (Thu, 01 Nov 2018)
New Revision: 16970
branches/2.4/postgis/geography_centroid.c
References #4059
Modified: branches/2.4/postgis/geography_centroid.c
--- branches/2.4/postgis/geography_centroid.c 2018-10-31 22:02:55 UTC (rev 16969)
+++ branches/2.4/postgis/geography_centroid.c 2018-11-01 19:31:24 UTC (rev 16970)
@@ -105,7 +105,7 @@
/* average between all points */
uint32_t size = mpoints->ngeoms;
- POINT3DM points[size];
+ POINT3DM* points = palloc(size*sizeof(POINT3DM));
uint32_t i;
for (i = 0; i < size; i++) {
@@ -115,6 +115,7 @@
lwpoint_out = geography_centroid_from_wpoints(srid, points, size);
+ pfree(points);
break;
@@ -258,7 +259,7 @@
size += (mline->geoms[i]->points->npoints - 1) * 2;
uint32_t j = 0;
for (i = 0; i < mline->ngeoms; i++) {
@@ -295,7 +296,9 @@
- return geography_centroid_from_wpoints(mline->srid, points, size);
+ LWPOINT* result = geography_centroid_from_wpoints(mline->srid, points, size);
+ pfree(points);
+ return result;
@@ -313,7 +316,7 @@
uint32_t j = 0;
/* use first point as reference to create triangles */
@@ -379,6 +382,7 @@
- return geography_centroid_from_wpoints(mpoly->srid, points, size);
+ LWPOINT* result = geography_centroid_from_wpoints(mpoly->srid, points, size);
+ pfree(points);
+ return result;
