[postgis-tickets] [PostGIS] #4226: Prevent PostGIS runs from happening at same time as PostgreSQL builds are happening on debbie (was: PostgreSQL 9.4 is failing badly)
PostGIS trac at osgeo.org
Sun Nov 4 13:08:37 PST 2018
happening on debbie
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.0.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Changes (by robe):
 * owner:  pramsey => robe
 * component:  postgis => buildbots
Comment:
 okay think a false alarm.  I see the 9.4 built about 30 minutes ago so was
 probably building at the same time.
 Guess I got to come up with some rule to prevent both running at same
 time.
 I've changed the title of this
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4226#comment:1>
