[postgis-tickets] [PostGIS] #4223: ST_Distance returns 0 instead of 5
trac at osgeo.org
Mon Nov 5 14:34:37 PST 2018
Reporter: br0ke | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.1
Component: postgis | Version: 2.5.x
Resolution: fixed | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"16979" 16979]:
#!CommitTicketReference repository="" revision="16979"
Patch over bad behaviour for near-parallel boxes and distancetree.
Unfortunately, this "fix" is probably breakable, just put the boxes closer
and closer together until we get "close enough to be the same" results
from the edge normal comparison again. Only way around this is to do dot
product and comparisons in higher-than-double space.
Reworking this example with even closer together inputs would be useful
for exposing this problem for eventual complete fix.
Closes #4223
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4223#comment:3>
