[postgis-tickets] r16981 - Patch over bad behaviour for near-parallel boxes and distancetree.
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 5 02:41:31 PST 2018
Author: pramsey
Date: 2018-11-05 14:41:31 -0800 (Mon, 05 Nov 2018)
New Revision: 16981
trunk/liblwgeom/cunit/cu_geodetic.c
trunk/liblwgeom/cunit/cu_tree.c
trunk/liblwgeom/lwgeodetic.h
Unfortunately, this "fix" is probably breakable, just put the boxes closer and closer together until we get "close enough to be the same" results from the edge normal comparison again. Only way around this is to do dot product and comparisons in higher-than-double space
References #4223
Modified: trunk/liblwgeom/cunit/cu_geodetic.c
--- trunk/liblwgeom/cunit/cu_geodetic.c 2018-11-05 22:36:48 UTC (rev 16980)
+++ trunk/liblwgeom/cunit/cu_geodetic.c 2018-11-05 22:41:31 UTC (rev 16981)
@@ -586,6 +586,12 @@
GEOGRAPHIC_POINT g;
uint32_t rv;
+ /* 5m close case */
+ line2pts("LINESTRING(58.5112113206308 0, 58.511211320077201 0.00090193752520337797)", &A1, &A2);
+ line2pts("LINESTRING(58.511166525601702 0.00027058124084120699, 58.511166525562899 0.00036077498778824899)", &B1, &B2);
+ rv = edge_intersects(&A1, &A2, &B1, &B2);
+ CU_ASSERT(rv == 0);
/* Covers case, end-to-end intersection */
line2pts("LINESTRING(50 -10.999999999999998224, -10.0 50.0)", &A1, &A2);
line2pts("LINESTRING(-10.0 50.0, -10.272779983831613393 -16.937003313332997578)", &B1, &B2);
Modified: trunk/liblwgeom/cunit/cu_tree.c
--- trunk/liblwgeom/cunit/cu_tree.c 2018-11-05 22:36:48 UTC (rev 16980)
+++ trunk/liblwgeom/cunit/cu_tree.c 2018-11-05 22:41:31 UTC (rev 16981)
@@ -177,11 +177,35 @@
LWGEOM *lwg1, *lwg2;
CIRC_NODE *c1, *c2;
SPHEROID s;
- double d1, d2, d3, d4;
+ double d1, d2, d3, d4, e1, e2;
double threshold = 0.0;
spheroid_init(&s, 1.0, 1.0);
+ /* Ticket #4223 */
+ /* tall skinny rectangle */
+ lwg1 = lwgeom_from_wkt("POLYGON((58.5112113206308 0,58.5112113200772 0.000901937525203378,58.511300910044 0.000901937636668872,58.5113009105976 0,58.5112113206308 0))", LW_PARSER_CHECK_NONE);
+ /* square box 5m to left */
+ lwg2 = lwgeom_from_wkt("POLYGON((58.5111665256017 0.000270581240841207,58.5111665255629 0.000360774987788249,58.5110769356128 0.000360774943200728,58.5110769356515 0.000270581207400566,58.5111665256017 0.000270581240841207))", LW_PARSER_CHECK_NONE);
+ c1 = lwgeom_calculate_circ_tree(lwg1);
+ c2 = lwgeom_calculate_circ_tree(lwg2);
+ d1 = circ_tree_distance_tree(c1, c2, &s, threshold);
+ d2 = lwgeom_distance_spheroid(lwg1, lwg2, &s, threshold);
+ e1 = d1 * WGS84_RADIUS;
+ e2 = d2 * WGS84_RADIUS;
+ // printf("d1 = %g d2 = %g\n", d1, d2);
+ // printf("e1 = %g e2 = %g\n", e1, e2);
+ // printf("polygon a\n");
+ // circ_tree_print(c1, 0);
+ // printf("polygon b\n");
+ // circ_tree_print(c2, 0);
+ circ_tree_free(c1);
+ circ_tree_free(c2);
+ lwgeom_free(lwg1);
+ lwgeom_free(lwg2);
+ CU_ASSERT_DOUBLE_EQUAL(e1, e2, 0.0001);
/* Ticket #1958 */
lwg1 = lwgeom_from_wkt("LINESTRING(22.88333 41.96667,21.32667 42.13667)", LW_PARSER_CHECK_NONE);
lwg2 = lwgeom_from_wkt("POLYGON((22.94472 41.34667,22.87528 41.99028,22.87389 41.98472,22.87472 41.98333,22.94472 41.34667))", LW_PARSER_CHECK_NONE);
Modified: trunk/liblwgeom/lwgeodetic.h
--- trunk/liblwgeom/lwgeodetic.h 2018-11-05 22:36:48 UTC (rev 16980)
+++ trunk/liblwgeom/lwgeodetic.h 2018-11-05 22:41:31 UTC (rev 16981)
@@ -37,6 +37,11 @@
#define NAN 0.0/0.0
#endif
+#ifdef FP_TOLERANCE
+#undef FP_TOLERANCE
+#define FP_TOLERANCE 1e-14
+#endif
extern int gbox_geocentric_slow;
#define POW2(x) ((x)*(x))
