[postgis-tickets] r16995 - Revert change to avoid slicing on box access.
Paul Ramsey
pramsey at cleverelephant.ca
Wed Nov 7 09:56:01 PST 2018
Author: pramsey
Date: 2018-11-07 09:56:00 -0800 (Wed, 07 Nov 2018)
New Revision: 16995
branches/2.5/NEWS
branches/2.5/liblwgeom/g_serialized.c
branches/2.5/postgis/gserialized_gist_2d.c
References #4216
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2018-11-07 17:17:16 UTC (rev 16994)
+++ branches/2.5/NEWS 2018-11-07 17:56:00 UTC (rev 16995)
@@ -16,6 +16,7 @@
Praliaskouski)
- #4223, ST_DistanceTree error for near parallel boxes (Paul Ramsey)
- Schema qualify more functions for raster (Regina Obe)
+ - #4216, Revert non-sliced box access (Paul Ramsey)
PostGIS 2.5.0
Modified: branches/2.5/liblwgeom/g_serialized.c
--- branches/2.5/liblwgeom/g_serialized.c 2018-11-07 17:17:16 UTC (rev 16994)
+++ branches/2.5/liblwgeom/g_serialized.c 2018-11-07 17:56:00 UTC (rev 16995)
@@ -86,6 +86,7 @@
uint32_t gserialized_get_type(const GSERIALIZED *s)
uint32_t *ptr;
+ assert(s);
ptr = (uint32_t*)(s->data);
LWDEBUG(4,"entered");
if ( FLAGS_GET_BBOX(s->flags) )
Modified: branches/2.5/postgis/gserialized_gist_2d.c
--- branches/2.5/postgis/gserialized_gist_2d.c 2018-11-07 17:17:16 UTC (rev 16994)
+++ branches/2.5/postgis/gserialized_gist_2d.c 2018-11-07 17:56:00 UTC (rev 16995)
@@ -649,15 +649,18 @@
POSTGIS_DEBUG(4, "entered function");
- ** Because geometry is declared as "storage = main" anything large
- ** enough to take serious advantage of PG_DETOAST_DATUM_SLICE will have
- ** already been compressed, which means the entire object will be
- ** fetched and decompressed before a slice is taken, thus removing
- ** any efficiencies gained from slicing. We need to move to
- ** "storage = external" and implement our own geometry compressor
- ** before we can take advantage of sliced retrieval.
+ ** The most info we need is the 8 bytes of serialized header plus the
+ ** of floats necessary to hold the bounding box.
- gpart = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
+ if (VARATT_IS_EXTENDED(gsdatum))
+ gpart = (GSERIALIZED*)PG_DETOAST_DATUM_SLICE(gsdatum, 0, 8 + sizeof(BOX2DF));
+ else
+ gpart = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
flags = gpart->flags;
POSTGIS_DEBUGF(4, "got flags %d", gpart->flags);
@@ -674,22 +677,28 @@
/* No, we need to calculate it from the full object. */
GBOX gbox;
+ GSERIALIZED *g = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
gbox_init(&gbox);
- result = gserialized_get_gbox_p(gpart, &gbox);
- if ( result == LW_SUCCESS )
+ if (gserialized_get_gbox_p(g, &gbox) == LW_FAILURE)
- result = box2df_from_gbox_p(&gbox, box2df);
+ POSTGIS_DEBUG(4, "could not calculate bbox, returning failure");
+ POSTGIS_FREE_IF_COPY_P(gpart, gsdatum);
+ POSTGIS_FREE_IF_COPY_P(g, gsdatum);
+ return LW_FAILURE;
- else
- POSTGIS_DEBUG(4, "could not calculate bbox");
+ result = box2df_from_gbox_p(&gbox, box2df);
- POSTGIS_DEBUGF(4, "result = %d, got box2df %s", result, result == LW_SUCCESS ? box2df_to_string(box2df) : "NONE");
+ if ( result == LW_SUCCESS )
+ POSTGIS_DEBUGF(4, "got box2df %s", box2df_to_string(box2df));
return result;
