[postgis-tickets] [PostGIS] #2767: AddRasterConstraint with 2 arguments is not documented
trac at osgeo.org
Wed Nov 7 20:35:22 PST 2018
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: documentation | Version: trunk
Resolution: | Keywords: postgisraster
Comment (by komzpa):
sunveersingh great!
Is there something we can help you with?
The file that should contain the documentation is
https://github.com/postgis/postgis/blob/svn-trunk/doc/reference_raster.xml
You can make a pull request with a change to it on github. To test whether
your edit didn't break document structure, run "make check" in root
directory of your check out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2767#comment:3>
