[postgis-tickets] [PostGIS] #4169: Set `html-chunked` as a default for docs (was: Set `html-chinked` as a default for docs)
PostGIS trac at osgeo.org
Thu Nov 8 17:51:59 PST 2018
  Reporter:  pcav           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  low            |  Milestone:  PostGIS 3.0.0
 Component:  documentation  |    Version:  2.4.x
Resolution:                 |   Keywords:
Description changed by dbaston:
Old description:
> Currently the default for building the doc is a single paage called
> postgs.html. This causes some minor problems:
> * not being called `index.html` it is not rendered by default in apache
> * being pretty large it requires a long time to load aand render.
> Packages (e.g. Debian) take the default.
> I suggest therefore to use the target `html-chunked` as a default, and
> rename the output.
New description:
 Currently the default for building the doc is a single page called
 postigs.html. This causes some minor problems:
 * being pretty large it requires a long time to load and render.
 rename the output.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4169#comment:3>
