[postgis-tickets] r17001 - GiST and SP-GiST n-D indexes (based on GIDX) with overlaps, contains, within, and equals operators
Darafei komzpa at gmail.com
Sun Nov 11 02:39:57 PST 2018
Author: komzpa
Date: 2018-11-11 02:39:57 -0800 (Sun, 11 Nov 2018)
New Revision: 17001
   trunk/.travis.yml
   trunk/NEWS
   trunk/configure.ac
   trunk/libpgcommon/gserialized_gist.h
   trunk/postgis/Makefile.in
   trunk/postgis/gserialized_gist_nd.c
   trunk/postgis/lwgeom_box3d.c
   trunk/postgis/postgis.sql.in
   trunk/postgis/postgis_spgist.sql.in
   trunk/regress/core/Makefile.in
   trunk/regress/core/operators.sql
   trunk/regress/core/operators_expected
Patch by Esteban Zimányi and Arthur Lesuisse from Université Libre de Bruxelles (ULB)
Closes https://github.com/postgis/postgis/pull/327
Closes https://github.com/postgis/postgis/pull/293
Closes #4230
Modified: trunk/.travis.yml
--- trunk/.travis.yml	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/.travis.yml	2018-11-11 10:39:57 UTC (rev 17001)
@@ -9,8 +9,7 @@
   - tag=pg11-geos37-gdal23-proj52
   - tag=pg10-geos36-gdal23-proj49
   - tag=pg96-geos36-gdal22-proj49
-  - tag=pg95-geos36-gdal22-proj49
-  - tag=pg94-geos35-gdal111-proj48
+  - tag=pg95-geos35-gdal111-proj48
 matrix:
   allow_failures:
Modified: trunk/NEWS
--- trunk/NEWS	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/NEWS	2018-11-11 10:39:57 UTC (rev 17001)
@@ -2,33 +2,39 @@
 2019/xx/xx
 * Breaking Changes *
   - #3888, Raster support now available as a separate extension
-    (Sandro Santilli)
+           (Sandro Santilli)
   - #3807, Extension library files no longer include the minor version.
-        Use New configure switch --with-library-minor-version
-        if you need the old behavior (Regina Obe)
+           Use New configure switch --with-library-minor-version
+           if you need the old behavior (Regina Obe)
+  - #4230, ND box operators (overlaps, contains, within, equals) now don't look on
+           dimentions that aren't present in both operands.
+           Please REINDEX your ND indexes after upgrade.
 * New Features *
   - #2902, postgis_geos_noop (Sandro Santilli)
   - #4128, ST_AsMVT support for Feature ID (Stepan Kuzmin)
+  - #4230, SP-GiST and GiST support for ND box operators overlaps, contains,
+           within, equals (Esteban Zimányi and Arthur Lesuisse from Université
+           Libre de Bruxelles (ULB), Darafei Praliaskouski)
 * Enhancements and fixes *
   - #4153, ST_Segmentize now splits segments proportionally (Darafei
-    Praliaskouski).
+           Praliaskouski).
   - #4162, ST_DWithin documentation examples for storing geometry and
-    radius in table (Darafei Praliaskouski, github user Boscop).
+           radius in table (Darafei Praliaskouski, github user Boscop).
   - #4161, MVT: Drop geometries smaller than the resolution (Raúl Marín)
   - #4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)
   - #4181, St_AsMVTGeom: Avoid type changes due to validation (Raúl Marín)
   - #4183, St_AsMVTGeom: Drop invalid geometries after simplification (Raúl Marín)
-  - #4188, Avoid division by zero in kmeans (Raúl Marín)
+  - #4188, Avoid division by zero in KMeans (Raúl Marín)
   - #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
   - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
   - #4211, Fix ST_Subdivide for minimal exterior ring with minimal hole (Darafei
-    Praliaskouski)
+           Praliaskouski)
   - #3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)
   - #4215, Use floating point compare in ST_DumpAsPolygons (Darafei Praliaskouski)
   - #4155, Support for GEOMETRYCOLLECTION, POLYGON, TIN, TRIANGLE in
-    ST_LocateBetween and ST_LocateBetweenElevations (Darafei Praliaskouski)
+           ST_LocateBetween and ST_LocateBetweenElevations (Darafei Praliaskouski)
   - #2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)
 PostGIS 2.5.0
@@ -39,9 +45,9 @@
 GEOS >= 3.5
 * New Features *
-  - #1847, spgist 2d and 3d support for PG 11+
-    (Esteban Zimányi and Arthur Lesuisse from Université Libre de Bruxelles (ULB),
-      Darafei Praliaskouski)
+  - #1847, SP-GiST 2D and 3D support for PostgreSQL 11+ (Esteban Zimányi and
+           Arthur Lesuisse from Université Libre de Bruxelles (ULB), Darafei
+           Praliaskouski)
   - #4056, ST_FilterByM (Nicklas Avén)
   - #4050, ST_ChaikinSmoothing (Nicklas Avén)
   - #3989, ST_Buffer single sided option (Stephen Knox)
@@ -62,7 +68,7 @@
   - #4054, ST_SimplifyVW changed from > tolerance to >= tolerance
   - #3885, version number removed from address_standardize lib file
-          (Regina Obe)
+           (Regina Obe)
   - #3893, raster support functions can only be loaded in the same schema
            with core PostGIS functions. (Sandro Santilli)
   - #4035, remove dummy pgis_abs type from aggregate/collect routines.
Modified: trunk/configure.ac
--- trunk/configure.ac	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/configure.ac	2018-11-11 10:39:57 UTC (rev 17001)
@@ -483,9 +483,9 @@
   PGSQL_SHAREDIR=`"$PG_CONFIG" --sharedir`
   AC_MSG_RESULT([checking PostgreSQL version... $PGSQL_FULL_VERSION])
-  dnl Ensure that we are using PostgreSQL >= 9.4
-  if test $POSTGIS_PGSQL_VERSION -lt 94; then
-    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 9.4])
+  dnl Ensure that we are using PostgreSQL >= 9.5
+  if test $POSTGIS_PGSQL_VERSION -lt 95; then
+    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 9.5])
   fi
   HAVE_BRIN=no
Modified: trunk/libpgcommon/gserialized_gist.h
--- trunk/libpgcommon/gserialized_gist.h	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/libpgcommon/gserialized_gist.h	2018-11-11 10:39:57 UTC (rev 17001)
@@ -26,7 +26,6 @@
 #define GIDX_MAX_SIZE 36
 #define GIDX_MAX_DIM 4
  * This macro is based on PG_FREE_IF_COPY, except that it accepts two pointers.
  * See PG_FREE_IF_COPY comment in src/include/fmgr.h in postgres source code
@@ -33,8 +32,9 @@
  * for more details.
 #define POSTGIS_FREE_IF_COPY_P(ptrsrc, ptrori) \
-	do { \
-		if ((Pointer) (ptrsrc) != (Pointer) (ptrori)) \
+	do \
+		if ((Pointer)(ptrsrc) != (Pointer)(ptrori)) \
 			pfree(ptrsrc); \
 	} while (0)
@@ -51,7 +51,6 @@
 	float xmin, xmax, ymin, ymax;
 } BOX2DF;
 ** GIDX support functions.
@@ -61,7 +60,7 @@
 /* allocate a new gidx object on the heap */
-GIDX* gidx_new(int ndims) ;
+GIDX *gidx_new(int ndims);
 /* Increase the size of a GIDX */
 void gidx_expand(GIDX *a, float d);
@@ -70,7 +69,7 @@
 bool gidx_is_unknown(const GIDX *a);
 /* Generate human readable form for GIDX. */
-char* gidx_to_string(GIDX *a) ;
+char *gidx_to_string(GIDX *a);
 /* typedef to correct array-bounds checking for casts to GIDX - do not
    use this ANYWHERE except in the casts below */
@@ -79,24 +78,24 @@
 /* Returns number of dimensions for this GIDX */
 #define GIDX_NDIMS(gidx) ((VARSIZE((gidx)) - VARHDRSZ) / (2 * sizeof(float)))
 /* Minimum accessor. */
-#define GIDX_GET_MIN(gidx, dimension) (*((_gidx_float_array *)(&(gidx)->c)))[2*(dimension)]
+#define GIDX_GET_MIN(gidx, dimension) (*((_gidx_float_array *)(&(gidx)->c)))[2 * (dimension)]
 /* Maximum accessor. */
-#define GIDX_GET_MAX(gidx, dimension) (*((_gidx_float_array *)(&(gidx)->c)))[2*(dimension)+1]
+#define GIDX_GET_MAX(gidx, dimension) (*((_gidx_float_array *)(&(gidx)->c)))[2 * (dimension) + 1]
 /* Minimum setter. */
-#define GIDX_SET_MIN(gidx, dimension, value) ((gidx)->c[2*(dimension)] = (value))
+#define GIDX_SET_MIN(gidx, dimension, value) ((gidx)->c[2 * (dimension)] = (value))
 /* Maximum setter. */
-#define GIDX_SET_MAX(gidx, dimension, value) ((gidx)->c[2*(dimension)+1] = (value))
+#define GIDX_SET_MAX(gidx, dimension, value) ((gidx)->c[2 * (dimension) + 1] = (value))
 /* Returns the size required to store a GIDX of requested dimension */
-#define GIDX_SIZE(dimensions) (sizeof(int32) + 2*(dimensions)*sizeof(float))
+#define GIDX_SIZE(dimensions) (sizeof(int32) + 2 * (dimensions) * sizeof(float))
 /* Allocate a copy of the box */
-BOX2DF* box2df_copy(BOX2DF *b);
+BOX2DF *box2df_copy(BOX2DF *b);
 /* Grow the first argument to contain the second */
 void box2df_merge(BOX2DF *b_union, BOX2DF *b_new);
-GIDX* gidx_copy(GIDX *b);
+GIDX *gidx_copy(GIDX *b);
 void gidx_merge(GIDX **b_union, GIDX *b_new);
@@ -122,16 +121,14 @@
 /* Pull out the gidx bounding box from an already de-toasted geography */
 int gserialized_get_gidx_p(const GSERIALIZED *g, GIDX *gidx);
 /* Copy a new bounding box into an existing gserialized */
-GSERIALIZED* gserialized_set_gidx(GSERIALIZED *g, GIDX *gidx);
+GSERIALIZED *gserialized_set_gidx(GSERIALIZED *g, GIDX *gidx);
 /* Given two datums, do they overlap? Computed very fast using embedded boxes. */
 /* int gserialized_datum_overlaps(Datum gs1, Datum gs2); */
 /* Remove the box from a disk serialization */
-GSERIALIZED* gserialized_drop_gidx(GSERIALIZED *g);
+GSERIALIZED *gserialized_drop_gidx(GSERIALIZED *g);
 bool box2df_contains(const BOX2DF *a, const BOX2DF *b);
 void box2df_set_empty(BOX2DF *a);
 void box2df_set_finite(BOX2DF *a);
 void box2df_validate(BOX2DF *b);
@@ -146,7 +143,9 @@
 bool box2df_above(const BOX2DF *a, const BOX2DF *b);
 bool box2df_overabove(const BOX2DF *a, const BOX2DF *b);
+void gidx_validate(GIDX *b);
+void gidx_set_unknown(GIDX *a);
+bool gidx_overlaps(GIDX *a, GIDX *b);
+bool gidx_equals(GIDX *a, GIDX *b);
 bool gidx_contains(GIDX *a, GIDX *b);
 int gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df);
Modified: trunk/postgis/Makefile.in
--- trunk/postgis/Makefile.in	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/postgis/Makefile.in	2018-11-11 10:39:57 UTC (rev 17001)
@@ -61,7 +61,7 @@
 endif
 ifeq (@HAVE_SPGIST@,yes)
-SPGIST_OBJ= gserialized_spgist_2d.o gserialized_spgist_3d.o
+SPGIST_OBJ= gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
 endif
 ifeq (@HAVE_PROTOBUF@,yes)
Modified: trunk/postgis/gserialized_gist_nd.c
--- trunk/postgis/gserialized_gist_nd.c	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/postgis/gserialized_gist_nd.c	2018-11-11 10:39:57 UTC (rev 17001)
@@ -23,7 +23,6 @@
 ** R-Tree Bibliography
@@ -38,30 +37,27 @@
 #include "postgres.h"
-#include "access/gist.h"    /* For GiST */
+#include "access/gist.h" /* For GiST */
 #include "access/itup.h"
 #include "access/skey.h"
 #include "../postgis_config.h"
-/*#define POSTGIS_DEBUG_LEVEL 4*/
-#include "liblwgeom.h"         /* For standard geometry types. */
-#include "lwgeom_pg.h"       /* For debugging macros. */
-#include "gserialized_gist.h"	     /* For utility functions. */
+#include "liblwgeom.h"        /* For standard geometry types. */
+#include "lwgeom_pg.h"        /* For debugging macros. */
+#include "gserialized_gist.h" /* For utility functions. */
 #include "geography.h"
 #include <assert.h>
 /* Fall back to older finite() if necessary */
 #ifndef HAVE_ISFINITE
-# ifdef HAVE_GNU_ISFINITE
-#  define _GNU_SOURCE
-# else
-#  define isfinite finite
-# endif
+#ifdef HAVE_GNU_ISFINITE
+#define _GNU_SOURCE
+#else
+#define isfinite finite
 #endif
+#endif
 ** When is a node split not so good? If more than 90% of the entries
@@ -100,21 +96,18 @@
 ** ND Operator prototypes
 Datum gserialized_overlaps(PG_FUNCTION_ARGS);
+Datum gserialized_gidx_geom_overlaps(PG_FUNCTION_ARGS);
+Datum gserialized_gidx_gidx_overlaps(PG_FUNCTION_ARGS);
 Datum gserialized_contains(PG_FUNCTION_ARGS);
-#if POSTGIS_PGSQL_VERSION > 94
 Datum gserialized_gidx_geom_contains(PG_FUNCTION_ARGS);
 Datum gserialized_gidx_gidx_contains(PG_FUNCTION_ARGS);
-#endif
 Datum gserialized_within(PG_FUNCTION_ARGS);
 Datum gserialized_gidx_geom_within(PG_FUNCTION_ARGS);
 Datum gserialized_gidx_gidx_within(PG_FUNCTION_ARGS);
-#endif
-Datum gserialized_distance_nd(PG_FUNCTION_ARGS);
+Datum gserialized_same(PG_FUNCTION_ARGS);
 Datum gserialized_gidx_geom_same(PG_FUNCTION_ARGS);
 Datum gserialized_gidx_gidx_same(PG_FUNCTION_ARGS);
-#endif
+Datum gserialized_distance_nd(PG_FUNCTION_ARGS);
 ** GIDX true/false test function type
@@ -121,31 +114,31 @@
 typedef bool (*gidx_predicate)(GIDX *a, GIDX *b);
 /* Allocate a new copy of GIDX */
+GIDX *
+gidx_copy(GIDX *b)
-	GIDX *c = (GIDX*)palloc(VARSIZE(b));
+	GIDX *c = (GIDX *)palloc(VARSIZE(b));
 	POSTGIS_DEBUGF(5, "copied gidx (%p) to gidx (%p)", b, c);
-	memcpy((void*)c, (void*)b, VARSIZE(b));
+	memcpy((void *)c, (void *)b, VARSIZE(b));
 	return c;
 /* Ensure all minimums are below maximums. */
-static inline void gidx_validate(GIDX *b)
+void
+gidx_validate(GIDX *b)
 	uint32_t i;
 	Assert(b);
-	POSTGIS_DEBUGF(5,"validating gidx (%s)", gidx_to_string(b));
-	for ( i = 0; i < GIDX_NDIMS(b); i++ )
+	POSTGIS_DEBUGF(5, "validating gidx (%s)", gidx_to_string(b));
+	for (i = 0; i < GIDX_NDIMS(b); i++)
-		if ( GIDX_GET_MIN(b,i) > GIDX_GET_MAX(b,i) )
+		if (GIDX_GET_MIN(b, i) > GIDX_GET_MAX(b, i))
 			float tmp;
-			tmp = GIDX_GET_MIN(b,i);
-			GIDX_SET_MIN(b,i,GIDX_GET_MAX(b,i));
-			GIDX_SET_MAX(b,i,tmp);
+			tmp = GIDX_GET_MIN(b, i);
+			GIDX_SET_MIN(b, i, GIDX_GET_MAX(b, i));
+			GIDX_SET_MAX(b, i, tmp);
 	return;
@@ -154,16 +147,18 @@
 /* An "unknown" GIDX is used to represent the bounds of an EMPTY
    geometry or other-wise unindexable geometry (like one with NaN
    or Inf bounds) */
-inline bool gidx_is_unknown(const GIDX *a)
+inline bool
+gidx_is_unknown(const GIDX *a)
 	size_t size = VARSIZE(a) - VARHDRSZ;
 	/* "unknown" gidx objects have a too-small size of one float */
-	if ( size <= 0.0 )
+	if (size <= 0.0)
 		return true;
 	return false;
-static inline void gidx_set_unknown(GIDX *a)
+void
+gidx_set_unknown(GIDX *a)
 	SET_VARSIZE(a, VARHDRSZ);
@@ -170,7 +165,8 @@
 /* Enlarge b_union to contain b_new. If b_new contains more
    dimensions than b_union, expand b_union to contain those dimensions. */
-void gidx_merge(GIDX **b_union, GIDX *b_new)
+void
+gidx_merge(GIDX **b_union, GIDX *b_new)
 	int i, dims_union, dims_new;
 	Assert(b_union);
@@ -178,11 +174,11 @@
 	Assert(b_new);
 	/* Can't merge an unknown into any thing */
-	if( gidx_is_unknown(b_new) )
+	if (gidx_is_unknown(b_new))
 		return;
 	/* Merge of unknown and known is known */
-	if( gidx_is_unknown(*b_union) )
+	if (gidx_is_unknown(*b_union))
 		*b_union = b_new;
 		return;
@@ -193,20 +189,20 @@
 	POSTGIS_DEBUGF(4, "merging gidx (%s) into gidx (%s)", gidx_to_string(b_new), gidx_to_string(*b_union));
-	if ( dims_new > dims_union )
+	if (dims_new > dims_union)
 		POSTGIS_DEBUGF(5, "reallocating b_union from %d dims to %d dims", dims_union, dims_new);
-		*b_union = (GIDX*)repalloc(*b_union, GIDX_SIZE(dims_new));
+		*b_union = (GIDX *)repalloc(*b_union, GIDX_SIZE(dims_new));
 		SET_VARSIZE(*b_union, VARSIZE(b_new));
 		dims_union = dims_new;
-	for ( i = 0; i < dims_new; i++ )
+	for (i = 0; i < dims_new; i++)
 		/* Adjust minimums */
-		GIDX_SET_MIN(*b_union, i, Min(GIDX_GET_MIN(*b_union,i),GIDX_GET_MIN(b_new,i)));
+		GIDX_SET_MIN(*b_union, i, Min(GIDX_GET_MIN(*b_union, i), GIDX_GET_MIN(b_new, i)));
 		/* Adjust maximums */
-		GIDX_SET_MAX(*b_union, i, Max(GIDX_GET_MAX(*b_union,i),GIDX_GET_MAX(b_new,i)));
+		GIDX_SET_MAX(*b_union, i, Max(GIDX_GET_MAX(*b_union, i), GIDX_GET_MAX(b_new, i)));
 	POSTGIS_DEBUGF(5, "merge complete (%s)", gidx_to_string(*b_union));
@@ -214,42 +210,40 @@
 /* Calculate the volume (in n-d units) of the GIDX */
-static float gidx_volume(GIDX *a)
+static float
+gidx_volume(GIDX *a)
 	float result;
 	uint32_t i;
-	if ( a == NULL || gidx_is_unknown(a) )
-		/* elog(ERROR, "gidx_volume received a null argument"); */
+	if (!a || gidx_is_unknown(a))
 		return 0.0;
-	result = GIDX_GET_MAX(a,0) - GIDX_GET_MIN(a,0);
-	for ( i = 1; i < GIDX_NDIMS(a); i++ )
-		result *= (GIDX_GET_MAX(a,i) - GIDX_GET_MIN(a,i));
+	result = GIDX_GET_MAX(a, 0) - GIDX_GET_MIN(a, 0);
+	for (i = 1; i < GIDX_NDIMS(a); i++)
+		result *= (GIDX_GET_MAX(a, i) - GIDX_GET_MIN(a, i));
 	POSTGIS_DEBUGF(5, "calculated volume of %s as %.8g", gidx_to_string(a), result);
 	return result;
 /* Calculate the edge of the GIDX */
-static float gidx_edge(GIDX *a)
+static float
+gidx_edge(GIDX *a)
 	float result;
 	uint32_t i;
 		return 0.0;
-		result += (GIDX_GET_MAX(a,i) - GIDX_GET_MIN(a,i));
+		result += (GIDX_GET_MAX(a, i) - GIDX_GET_MIN(a, i));
 	POSTGIS_DEBUGF(5, "calculated edge of %s as %.8g", gidx_to_string(a), result);
 	return result;
 /* Ensure the first argument has the higher dimensionality. */
-static void gidx_dimensionality_check(GIDX **a, GIDX **b)
+static void
+gidx_dimensionality_check(GIDX **a, GIDX **b)
-	if ( GIDX_NDIMS(*a) < GIDX_NDIMS(*b) )
+	if (GIDX_NDIMS(*a) < GIDX_NDIMS(*b))
 		GIDX *tmp = *b;
 		*b = *a;
@@ -258,30 +252,29 @@
 /* Calculate the volume of the union of the boxes. Avoids creating an intermediate box. */
-static float gidx_union_volume(GIDX *a, GIDX *b)
+static float
+gidx_union_volume(GIDX *a, GIDX *b)
 	float result;
 	int i;
 	int ndims_a, ndims_b;
-	POSTGIS_DEBUG(5,"entered function");
+	POSTGIS_DEBUG(5, "entered function");
-	if ( a == NULL && b == NULL )
+	if (!a && !b)
 		elog(ERROR, "gidx_union_volume received two null arguments");
 		return 0.0;
 		return gidx_volume(b);
-	if ( b == NULL || gidx_is_unknown(b) )
+	if (!b || gidx_is_unknown(b))
 		return gidx_volume(a);
-	if ( gidx_is_unknown(a) && gidx_is_unknown(b) )
+	if (gidx_is_unknown(a) && gidx_is_unknown(b))
 		return 0.0;
 	/* Ensure 'a' has the most dimensions. */
 	gidx_dimensionality_check(&a, &b);
@@ -290,19 +283,15 @@
 	ndims_b = GIDX_NDIMS(b);
 	/* Initialize with maximal length of first dimension. */
-	result = Max(GIDX_GET_MAX(a,0),GIDX_GET_MAX(b,0)) - Min(GIDX_GET_MIN(a,0),GIDX_GET_MIN(b,0));
+	result = Max(GIDX_GET_MAX(a, 0), GIDX_GET_MAX(b, 0)) - Min(GIDX_GET_MIN(a, 0), GIDX_GET_MIN(b, 0));
 	/* Multiply by maximal length of remaining dimensions. */
-	for ( i = 1; i < ndims_b; i++ )
-		result *= (Max(GIDX_GET_MAX(a,i),GIDX_GET_MAX(b,i)) - Min(GIDX_GET_MIN(a,i),GIDX_GET_MIN(b,i)));
+	for (i = 1; i < ndims_b; i++)
+		result *= (Max(GIDX_GET_MAX(a, i), GIDX_GET_MAX(b, i)) - Min(GIDX_GET_MIN(a, i), GIDX_GET_MIN(b, i)));
 	/* Add in dimensions of higher dimensional box. */
-	for ( i = ndims_b; i < ndims_a; i++ )
+	for (i = ndims_b; i < ndims_a; i++)
 	POSTGIS_DEBUGF(5, "volume( %s union %s ) = %.12g", gidx_to_string(a), gidx_to_string(b), result);
@@ -310,30 +299,29 @@
 /* Calculate the edge of the union of the boxes. Avoids creating an intermediate box. */
-static float gidx_union_edge(GIDX *a, GIDX *b)
+static float
+gidx_union_edge(GIDX *a, GIDX *b)
 	float result;
 	int i;
+	if (!a && !b)
 		elog(ERROR, "gidx_union_edge received two null arguments");
 		return 0.0;
 		return 0.0;
@@ -342,19 +330,15 @@
 	/* Add maximal length of remaining dimensions. */
-		result += (Max(GIDX_GET_MAX(a,i),GIDX_GET_MAX(b,i)) - Min(GIDX_GET_MIN(a,i),GIDX_GET_MIN(b,i)));
+		result += (Max(GIDX_GET_MAX(a, i), GIDX_GET_MAX(b, i)) - Min(GIDX_GET_MIN(a, i), GIDX_GET_MIN(b, i)));
 	POSTGIS_DEBUGF(5, "edge( %s union %s ) = %.12g", gidx_to_string(a), gidx_to_string(b), result);
@@ -362,38 +346,39 @@
 /* Calculate the volume of the intersection of the boxes. */
-static float gidx_inter_volume(GIDX *a, GIDX *b)
+static float
+gidx_inter_volume(GIDX *a, GIDX *b)
 	uint32_t i;
 	float result;
-	if ( a == NULL || b == NULL )
+	if (!a || !b)
 		elog(ERROR, "gidx_inter_volume received a null argument");
 		return 0.0;
-	if ( gidx_is_unknown(a) || gidx_is_unknown(b) )
+	if (gidx_is_unknown(a) || gidx_is_unknown(b))
 		return 0.0;
 	/* Initialize with minimal length of first dimension. */
-	result = Min(GIDX_GET_MAX(a,0),GIDX_GET_MAX(b,0)) - Max(GIDX_GET_MIN(a,0),GIDX_GET_MIN(b,0));
+	result = Min(GIDX_GET_MAX(a, 0), GIDX_GET_MAX(b, 0)) - Max(GIDX_GET_MIN(a, 0), GIDX_GET_MIN(b, 0));
 	/* If they are disjoint (max < min) then return zero. */
-	if ( result < 0.0 ) return 0.0;
+	if (result < 0.0)
+		return 0.0;
 	/* Continue for remaining dimensions. */
-	for ( i = 1; i < GIDX_NDIMS(b); i++ )
+	for (i = 1; i < GIDX_NDIMS(b); i++)
-		float width = Min(GIDX_GET_MAX(a,i),GIDX_GET_MAX(b,i)) - Max(GIDX_GET_MIN(a,i),GIDX_GET_MIN(b,i));
-		if ( width < 0.0 ) return 0.0;
+		float width = Min(GIDX_GET_MAX(a, i), GIDX_GET_MAX(b, i)) - Max(GIDX_GET_MIN(a, i), GIDX_GET_MIN(b, i));
+		if (width < 0.0)
+			return 0.0;
 		/* Multiply by minimal length of remaining dimensions. */
 		result *= width;
@@ -414,29 +399,34 @@
 ** Empty boxes never overlap.
-static bool gidx_overlaps(GIDX *a, GIDX *b)
+bool
+gidx_overlaps(GIDX *a, GIDX *b)
-	int i;
-	int ndims_b;
+	int i, dims_a, dims_b;
-	if ( (a == NULL) || (b == NULL) ) return false;
+	if (!a || !b)
+		return false;
 		return false;
-	/* Ensure 'a' has the most dimensions. */
-	gidx_dimensionality_check(&a, &b);
+	dims_a = GIDX_NDIMS(a);
+	dims_b = GIDX_NDIMS(b);
-	ndims_b = GIDX_NDIMS(b);
-	/* compare only up to dimensions of (b), missing dimensions always overlap */
-	for ( i = 0; i < ndims_b; i++ )
+	/* For all shared dimensions min(a) > max(b) and min(b) > max(a)
+	   Unshared dimensions do not matter */
+	for (i = 0; i < Min(dims_a, dims_b); i++)
-		if ( GIDX_GET_MIN(a,i) > GIDX_GET_MAX(b,i) )
-			return false;
-		if ( GIDX_GET_MIN(b,i) > GIDX_GET_MAX(a,i) )
-			return false;
+		/* If the missing dimension was not padded with -+FLT_MAX */
+		if (GIDX_GET_MAX(a, i) != FLT_MAX && GIDX_GET_MAX(b, i) != FLT_MAX)
+			if (GIDX_GET_MIN(a, i) > GIDX_GET_MAX(b, i))
+				return false;
+			if (GIDX_GET_MIN(b, i) > GIDX_GET_MAX(a, i))
+				return false;
 	return true;
@@ -447,44 +437,34 @@
 ** Box(A) CONTAINS Box(B) IFF (pt(A)LL < pt(B)LL) && (pt(A)UR > pt(B)UR)
-bool gidx_contains(GIDX *a, GIDX *b)
+bool
+gidx_contains(GIDX *a, GIDX *b)
-	int i, dims_a, dims_b;
+	uint32_t i, dims_a, dims_b;
-	POSTGIS_DEBUG(5, "entered function");
+	if (!a || !b)
+		return false;
 		return false;
-	if ( dims_a < dims_b )
+	/* For all shared dimensions min(a) > min(b) and max(a) < max(b)
-		** If (b) is of higher dimensionality than (a) it can only be contained
-		** if those higher dimensions are zeroes.
-		for (i = dims_a; i < dims_b; i++)
-			if ( GIDX_GET_MIN(b,i) != 0 )
+			if (GIDX_GET_MIN(a, i) > GIDX_GET_MIN(b, i))
 				return false;
-			if ( GIDX_GET_MAX(b,i) != 0 )
+			if (GIDX_GET_MAX(a, i) < GIDX_GET_MAX(b, i))
 				return false;
-	/* Excess dimensions of (a), don't matter, it just has to contain (b) in (b)'s dimensions */
-	for (i = 0; i < Min(dims_a, dims_b); i++)
-		if ( GIDX_GET_MIN(a,i) > GIDX_GET_MIN(b,i) )
-			return false;
-		if ( GIDX_GET_MAX(a,i) < GIDX_GET_MAX(b,i) )
-			return false;
 	return true;
@@ -493,47 +473,45 @@
 ** Box(A) EQUALS Box(B) IFF (pt(A)LL == pt(B)LL) && (pt(A)UR == pt(B)UR)
-static bool gidx_equals(GIDX *a, GIDX *b)
+bool
+gidx_equals(GIDX *a, GIDX *b)
-	uint32_t i;
+	if (!a && !b)
+		return true;
+	if (!a || !b)
+		return false;
-	if ( (a == NULL) && (b == NULL) ) return true;
 		return true;
 		return false;
-	/* For all shared dimensions min(a) == min(b), max(a) == max(b) */
-	for (i = 0; i < GIDX_NDIMS(b); i++)
+	/* For all shared dimensions min(a) == min(b), max(a) == max(b)
-		if ( GIDX_GET_MIN(a,i) != GIDX_GET_MIN(b,i) )
-			return false;
-		if ( GIDX_GET_MAX(a,i) != GIDX_GET_MAX(b,i) )
-			return false;
+			if (GIDX_GET_MIN(a, i) != GIDX_GET_MIN(b, i))
+				return false;
+			if (GIDX_GET_MAX(a, i) != GIDX_GET_MAX(b, i))
+				return false;
-	/* For all unshared dimensions min(a) == 0.0, max(a) == 0.0 */
-	for (i = GIDX_NDIMS(b); i < GIDX_NDIMS(a); i++)
-		if ( GIDX_GET_MIN(a,i) != 0.0 )
-			return false;
-		if ( GIDX_GET_MAX(a,i) != 0.0 )
-			return false;
 	return true;
-* Support function. Based on two datums return true if
-* they satisfy the predicate and false otherwise.
+ * Support function. Based on two datums return true if
+ * they satisfy the predicate and false otherwise.
 static int
 gserialized_datum_predicate(Datum gs1, Datum gs2, gidx_predicate predicate)
@@ -540,16 +518,15 @@
 	/* Put aside some stack memory and use it for GIDX pointers. */
 	char boxmem1[GIDX_MAX_SIZE];
 	char boxmem2[GIDX_MAX_SIZE];
-	GIDX *gidx1 = (GIDX*)boxmem1;
-	GIDX *gidx2 = (GIDX*)boxmem2;
+	GIDX *gidx1 = (GIDX *)boxmem1;
+	GIDX *gidx2 = (GIDX *)boxmem2;
 	POSTGIS_DEBUG(3, "entered function");
 	/* Must be able to build box for each arguement (ie, not empty geometry)
 	   and predicate function to return true. */
-	if ( (gserialized_datum_get_gidx_p(gs1, gidx1) == LW_SUCCESS) &&
-	     (gserialized_datum_get_gidx_p(gs2, gidx2) == LW_SUCCESS) &&
-	      predicate(gidx1, gidx2) )
+	if ((gserialized_datum_get_gidx_p(gs1, gidx1) == LW_SUCCESS) &&
+	    (gserialized_datum_get_gidx_p(gs2, gidx2) == LW_SUCCESS) && predicate(gidx1, gidx2))
 		POSTGIS_DEBUGF(3, "got boxes %s and %s", gidx_to_string(gidx1), gidx_to_string(gidx2));
 		return LW_TRUE;
@@ -557,187 +534,98 @@
 	return LW_FALSE;
 static int
 gserialized_datum_predicate_gidx_geom(GIDX *gidx1, Datum gs2, gidx_predicate predicate)
-   /* Put aside some stack memory and use it for GIDX pointers. */
-   char boxmem2[GIDX_MAX_SIZE];
+	/* Put aside some stack memory and use it for GIDX pointers. */
+	char boxmem2[GIDX_MAX_SIZE];
-   POSTGIS_DEBUG(3, "entered function");
+	POSTGIS_DEBUG(3, "entered function");
-   /* Must be able to build box for gs2 arguement (ie, not empty geometry)
-      and predicate function to return true. */
-   if ( (gserialized_datum_get_gidx_p(gs2, gidx2) == LW_SUCCESS) &&
-       POSTGIS_DEBUGF(3, "got boxes %s and %s", gidx_to_string(gidx1), gidx_to_string(gidx2));
-       return LW_TRUE;
-   return LW_FALSE;
+	/* Must be able to build box for gs2 arguement (ie, not empty geometry)
+	   and predicate function to return true. */
+	if ((gserialized_datum_get_gidx_p(gs2, gidx2) == LW_SUCCESS) && predicate(gidx1, gidx2))
+		POSTGIS_DEBUGF(3, "got boxes %s and %s", gidx_to_string(gidx1), gidx_to_string(gidx2));
+		return LW_TRUE;
+	return LW_FALSE;
 static int
 gserialized_datum_predicate_geom_gidx(Datum gs1, GIDX *gidx2, gidx_predicate predicate)
-   GIDX *gidx1 = (GIDX*)boxmem2;
+	GIDX *gidx1 = (GIDX *)boxmem2;
-       return LW_TRUE;
-   return LW_FALSE;
+	if ((gserialized_datum_get_gidx_p(gs1, gidx1) == LW_SUCCESS) && predicate(gidx1, gidx2))
+		return LW_TRUE;
+	return LW_FALSE;
-#endif
-* Calculate the centroid->centroid distance between the boxes.
-#if POSTGIS_PGSQL_VERSION < 95
-static double gidx_distance_leaf_centroid(const GIDX *a, const GIDX *b)
+ * Calculate the box->box distance.
+static double
+gidx_distance(const GIDX *a, const GIDX *b, int m_is_time)
-  int ndims, i;
-  double sum = 0;
-  /* Base computation on least available dimensions */
-  ndims = Min(GIDX_NDIMS(b), GIDX_NDIMS(a));
-  for ( i = 0; i < ndims; ++i )
-    double ca, cb, d;
-    double amin = GIDX_GET_MIN(a,i);
-    double amax = GIDX_GET_MAX(a,i);
-    double bmin = GIDX_GET_MIN(b,i);
-    double bmax = GIDX_GET_MAX(b,i);
-    ca = amin + ( ( amax - amin ) / 2.0 );
-    cb = bmin + ( ( bmax - bmin ) / 2.0 );
-    d = ca - cb;
-    if ( ! isfinite(d) )
-      /* Can happen if a dimension was padded with FLT_MAX,
-       * effectively meaning "infinite range". In that case
-       * we take that dimension as adding 0 to the total
-       * distance.
-      continue;
-    sum += d * d;
-    POSTGIS_DEBUGF(3, " centroid of A for dimension %d is %g", i, ca);
-    POSTGIS_DEBUGF(3, " centroid of B for dimension %d is %g", i, cb);
-    POSTGIS_DEBUGF(3, " distance on dimension %d is %g, squared as %g, grows sum to %g", i, d, d*d, sum);
-  return sqrt(sum);
-#endif
-* Calculate the box->box distance.
-static double gidx_distance(const GIDX *a, const GIDX *b, int m_is_time)
-  int ndims, i;
-  double sum = 0;
-    double d;
-    POSTGIS_DEBUGF(3, "A %g - %g", amin, amax);
-    POSTGIS_DEBUGF(3, "B %g - %g", bmin, bmax);
-    if ( ( amin <= bmax && amax >= bmin ) )
-      /* overlaps */
-      d = 0;
-    else if ( i == 4 && m_is_time )
-      return FLT_MAX;
-    else if ( bmax < amin )
-      /* is "left" */
-      d = amin - bmax;
-    else
-      /* is "right" */
-      assert( bmin > amax );
-      d = bmin - amax;
-      /* Can happen if coordinates are corrupted/NaN */
-      continue;
-    sum += d * d;
-    POSTGIS_DEBUGF(3, "dist %g, squared %g, grows sum to %g", d, d*d, sum);
-  return sqrt(sum);
-static double gidx_distance_node_centroid(const GIDX *node, const GIDX *query)
-	int i;
+	int ndims, i;
 	double sum = 0;
-	int ndims = Min(GIDX_NDIMS(node), GIDX_NDIMS(query));
+	ndims = Min(GIDX_NDIMS(b), GIDX_NDIMS(a));
+	for (i = 0; i < ndims; ++i)
 		double d;
-		double amin = GIDX_GET_MIN(query,i);
-		double amax = GIDX_GET_MAX(query,i);
-		double bmin = GIDX_GET_MIN(node,i);
-		double bmax = GIDX_GET_MAX(node,i);
-		double ca = amin + ( ( amax - amin ) / 2.0 );
+		double amin = GIDX_GET_MIN(a, i);
+		double amax = GIDX_GET_MAX(a, i);
+		double bmin = GIDX_GET_MIN(b, i);
+		double bmax = GIDX_GET_MAX(b, i);
+		POSTGIS_DEBUGF(3, "A %g - %g", amin, amax);
+		POSTGIS_DEBUGF(3, "B %g - %g", bmin, bmax);
-		if ( ( ca <= bmax && ca >= bmin ) )
+		if ((amin <= bmax && amax >= bmin))
 			/* overlaps */
 			d = 0;
-		else if ( bmax < ca )
+		else if (i == 4 && m_is_time)
+			return FLT_MAX;
+		else if (bmax < amin)
 			/* is "left" */
-			d = ca - bmax;
+			d = amin - bmax;
 		else
 			/* is "right" */
-			assert( bmin > ca );
-			d = bmin - ca;
+			assert(bmin > amax);
+			d = bmin - amax;
+		if (!isfinite(d))
 			continue;
 		sum += d * d;
+		POSTGIS_DEBUGF(3, "dist %g, squared %g, grows sum to %g", d, d * d, sum);
 	return sqrt(sum);
-#else /* POSTGIS_PGSQL_VERSION >= 95 */
-static double gidx_distance_m(const GIDX *a, const GIDX *b)
+static double
+gidx_distance_m(const GIDX *a, const GIDX *b)
 	int mdim_a, mdim_b;
 	double d, amin, amax, bmin, bmax;
@@ -746,48 +634,45 @@
 	mdim_a = GIDX_NDIMS(a) - 1;
 	mdim_b = GIDX_NDIMS(b) - 1;
-	amin = GIDX_GET_MIN(a,mdim_a);
-	amax = GIDX_GET_MAX(a,mdim_a);
-	bmin = GIDX_GET_MIN(b,mdim_b);
-	bmax = GIDX_GET_MAX(b,mdim_b);
+	amin = GIDX_GET_MIN(a, mdim_a);
+	amax = GIDX_GET_MAX(a, mdim_a);
+	bmin = GIDX_GET_MIN(b, mdim_b);
+	bmax = GIDX_GET_MAX(b, mdim_b);
-      /* overlaps */
-      d = 0;
-      /* is "left" */
-      d = amin - bmax;
-    else
-      /* is "right" */
-      d = bmin - amax;
+		/* overlaps */
+		d = 0;
+		/* is "left" */
+		d = amin - bmax;
+	else
+		/* is "right" */
+		d = bmin - amax;
 	return d;
-#endif /* POSTGIS_PGSQL_VERSION >= 96 */
-* Return a #GSERIALIZED with an expanded bounding box.
-GSERIALIZED*
+ * Return a #GSERIALIZED with an expanded bounding box.
+GSERIALIZED *
 gserialized_expand(GSERIALIZED *g, double distance)
 	char boxmem[GIDX_MAX_SIZE];
-	GIDX *gidx = (GIDX*)boxmem;
+	GIDX *gidx = (GIDX *)boxmem;
 	float fdistance = (float)distance;
 	/* Get our bounding box out of the geography, return right away if
 	   input is an EMPTY geometry. */
-	if ( gserialized_get_gidx_p(g, gidx) == LW_FAILURE )
+	if (gserialized_get_gidx_p(g, gidx) == LW_FAILURE)
 		return g;
 	gidx_expand(gidx, fdistance);
@@ -795,40 +680,20 @@
-* GiST N-D Index Operator Functions
+ * GiST N-D Index Operator Functions
-* Do centroid to centroid n-d distance if you don't have
-* re-check available (PgSQL 9.5+), do "real" n-d distance
-* if you do
+ * do "real" n-d distance
 PG_FUNCTION_INFO_V1(gserialized_distance_nd);
 	char b1mem[GIDX_MAX_SIZE];
-	GIDX *b1 = (GIDX*)b1mem;
+	GIDX *b1 = (GIDX *)b1mem;
 	char b2mem[GIDX_MAX_SIZE];
-	GIDX *b2 = (GIDX*)b2mem;
+	GIDX *b2 = (GIDX *)b2mem;
-	/* Centroid-to-centroid distance */
-	Datum gs1 = PG_GETARG_DATUM(0);
-	Datum gs2 = PG_GETARG_DATUM(1);
-	double box_distance = FLT_MAX;
-	/* Must be able to build box for each argument (ie, not empty geometry). */
-	if ( (gserialized_datum_get_gidx_p(gs1, b1) == LW_SUCCESS) &&
-	     (gserialized_datum_get_gidx_p(gs2, b2) == LW_SUCCESS) )
-		box_distance = gidx_distance_leaf_centroid(b1, b2);
-		POSTGIS_DEBUGF(3, "got boxes %s and %s", gidx_to_string(b1), gidx_to_string(b2));
-	PG_RETURN_FLOAT8(box_distance);
-#else /* POSTGIS_PGSQL_VERSION >= 96 */
 	/* Feature-to-feature distance */
 	GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
 	GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
@@ -837,9 +702,8 @@
 	LWGEOM *closest;
 	double distance;
 	/* Find an exact shortest line w/ the dimensions we support */
-	if ( lwgeom_has_z(lw1) && lwgeom_has_z(lw2) )
+	if (lwgeom_has_z(lw1) && lwgeom_has_z(lw2))
 		closest = lwgeom_closest_line_3d(lw1, lw2);
 		distance = lwgeom_length(closest);
@@ -850,22 +714,21 @@
 		distance = lwgeom_length_2d(closest);
-	/* Un-sqrt the distance so we can add extra terms */
-	distance = distance*distance;
 	/* Can only add the M term if both objects have M */
-	if ( lwgeom_has_m(lw1) && lwgeom_has_m(lw2) )
+	if (lwgeom_has_m(lw1) && lwgeom_has_m(lw2))
 		double m1, m2;
 		int usebox = false;
+		/* Un-sqrt the distance so we can add extra terms */
+		distance = distance * distance;
-		if ( lwgeom_get_type(lw1) == POINTTYPE )
+		if (lwgeom_get_type(lw1) == POINTTYPE)
 			POINT4D p;
-			lwpoint_getPoint4d_p((LWPOINT*)lw1, &p);
+			lwpoint_getPoint4d_p((LWPOINT *)lw1, &p);
 			m1 = p.m;
-		else if ( lwgeom_get_type(lw1) == LINETYPE )
+		else if (lwgeom_get_type(lw1) == LINETYPE)
 			LWPOINT *lwp1 = lwline_get_lwpoint(lwgeom_as_lwline(closest), 0);
 			m1 = lwgeom_interpolate_point(lw1, lwp1);
@@ -872,17 +735,15 @@
 			lwpoint_free(lwp1);
 		else
 			usebox = true;
-		if ( lwgeom_get_type(lw2) == POINTTYPE )
+		if (lwgeom_get_type(lw2) == POINTTYPE)
 			POINT4D p;
-			lwpoint_getPoint4d_p((LWPOINT*)lw2, &p);
+			lwpoint_getPoint4d_p((LWPOINT *)lw2, &p);
 			m2 = p.m;
-		else if ( lwgeom_get_type(lw2) == LINETYPE )
+		else if (lwgeom_get_type(lw2) == LINETYPE)
 			LWPOINT *lwp2 = lwline_get_lwpoint(lwgeom_as_lwline(closest), 1);
 			m2 = lwgeom_interpolate_point(lw2, lwp2);
@@ -889,22 +750,20 @@
 			lwpoint_free(lwp2);
 		else
 			usebox = true;
-		if ( usebox )
+		if (usebox)
 			double d;
 			gserialized_get_gidx_p(geom1, b1);
 			gserialized_get_gidx_p(geom2, b2);
 			d = gidx_distance_m(b1, b2);
-			distance += d*d;
+			distance += d * d;
 		else
-			distance += (m2-m1)*(m2-m1);
+			distance += (m2 - m1) * (m2 - m1);
+		distance = sqrt(distance);
 	lwgeom_free(closest);
@@ -911,21 +770,18 @@
 	PG_FREE_IF_COPY(geom1, 0);
 	PG_FREE_IF_COPY(geom2, 1);
-	PG_RETURN_FLOAT8(sqrt(distance));
+	PG_RETURN_FLOAT8(distance);
-** '~' and operator function. Based on two serialized return true if
+** '~~' and operator function. Based on two serialized return true if
 ** the first is contained by the second.
 PG_FUNCTION_INFO_V1(gserialized_within);
-	if ( gserialized_datum_predicate(PG_GETARG_DATUM(1), PG_GETARG_DATUM(0), gidx_contains) == LW_TRUE )
+	if (gserialized_datum_predicate(PG_GETARG_DATUM(1), PG_GETARG_DATUM(0), gidx_contains))
 		PG_RETURN_BOOL(true);
 	PG_RETURN_BOOL(false);
@@ -932,115 +788,125 @@
-** '~' and operator function. Based on a GIDX and a serialized return true if
+** '~~' and operator function. Based on a GIDX and a serialized return true if
 PG_FUNCTION_INFO_V1(gserialized_gidx_geom_within);
-   GIDX *gidx = (GIDX *)PG_GETARG_POINTER(0);
+	GIDX *gidx = (GIDX *)PG_GETARG_POINTER(0);
-   if ( gserialized_datum_predicate_geom_gidx(PG_GETARG_DATUM(1), gidx, gidx_contains) == LW_TRUE )
-       PG_RETURN_BOOL(true);
+	if (gserialized_datum_predicate_geom_gidx(PG_GETARG_DATUM(1), gidx, gidx_contains))
+		PG_RETURN_BOOL(true);
-   PG_RETURN_BOOL(false);
+	PG_RETURN_BOOL(false);
-** '~' and operator function. Based on two GIDX return true if
+** '~~' and operator function. Based on two GIDX return true if
 PG_FUNCTION_INFO_V1(gserialized_gidx_gidx_within);
-   if ( gidx_contains((GIDX *)PG_GETARG_POINTER(1), (GIDX *)PG_GETARG_POINTER(0)))
+	if (gidx_contains((GIDX *)PG_GETARG_POINTER(1), (GIDX *)PG_GETARG_POINTER(0)))
 #endif
-** '@' and operator function. Based on two serialized return true if
+** '@@' and operator function. Based on two serialized return true if
 ** the first contains the second.
 PG_FUNCTION_INFO_V1(gserialized_contains);
-	if ( gserialized_datum_predicate(PG_GETARG_DATUM(0),PG_GETARG_DATUM(1), gidx_contains) == LW_TRUE )
+	if (gserialized_datum_predicate(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), gidx_contains))
-** '@' and operator function. Based on a GIDX and a serialized return true if
+** '@@' and operator function. Based on a GIDX and a serialized return true if
 PG_FUNCTION_INFO_V1(gserialized_gidx_geom_contains);
-   if ( gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_contains) == LW_TRUE )
+	if (gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_contains))
-** '@' and operator function. Based on two GIDX return true if
+** '@@' and operator function. Based on two GIDX return true if
 PG_FUNCTION_INFO_V1(gserialized_gidx_gidx_contains);
-   if ( gidx_contains((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)))
+	if (gidx_contains((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)))
+** '~=' and operator function. Based on two serialized return true if
+** the first equals the second.
+PG_FUNCTION_INFO_V1(gserialized_same);
+	if (gserialized_datum_predicate(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), gidx_equals))
 PG_FUNCTION_INFO_V1(gserialized_gidx_geom_same);
-   if ( gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_equals) == LW_TRUE )
+	if (gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_equals))
+** '~=' and operator function. Based on two GIDX return true if
 PG_FUNCTION_INFO_V1(gserialized_gidx_gidx_same);
-   if ( gidx_equals((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)) )
+	if (gidx_equals((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)))
-#endif
-** '&&' operator function. Based on two serialized return true if
+** '&&&' operator function. Based on two serialized return true if
 ** they overlap and false otherwise.
 PG_FUNCTION_INFO_V1(gserialized_overlaps);
-	if ( gserialized_datum_predicate(PG_GETARG_DATUM(0),PG_GETARG_DATUM(1), gidx_overlaps) == LW_TRUE )
+	if (gserialized_datum_predicate(PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), gidx_overlaps))
  * This is the cross-operator for the geographies
@@ -1047,38 +913,37 @@
 PG_FUNCTION_INFO_V1(gserialized_gidx_geog_overlaps);
 Datum gserialized_gidx_geog_overlaps(PG_FUNCTION_ARGS)
-   if ( gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_overlaps) == LW_TRUE )
+	if (gserialized_datum_predicate_gidx_geom(gidx, PG_GETARG_DATUM(1), gidx_overlaps))
 PG_FUNCTION_INFO_V1(gserialized_gidx_geom_overlaps);
 PG_FUNCTION_INFO_V1(gserialized_gidx_gidx_overlaps);
-   if ( gidx_overlaps((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)) )
+	if (gidx_overlaps((GIDX *)PG_GETARG_POINTER(0), (GIDX *)PG_GETARG_POINTER(1)))
-#endif
-* GiST Index  Support Functions
+ * GiST Index  Support Functions
 ** GiST support function. Given a geography, return a "compressed"
@@ -1089,10 +954,10 @@
 PG_FUNCTION_INFO_V1(gserialized_gist_compress);
 Datum gserialized_gist_compress(PG_FUNCTION_ARGS)
-	GISTENTRY *entry_in = (GISTENTRY*)PG_GETARG_POINTER(0);
+	GISTENTRY *entry_in = (GISTENTRY *)PG_GETARG_POINTER(0);
 	GISTENTRY *entry_out = NULL;
 	char gidxmem[GIDX_MAX_SIZE];
-	GIDX *bbox_out = (GIDX*)gidxmem;
+	GIDX *bbox_out = (GIDX *)gidxmem;
 	int result = LW_SUCCESS;
 	uint32_t i;
@@ -1102,7 +967,7 @@
 	** Not a leaf key? There's nothing to do.
 	** Return the input unchanged.
-	if ( ! entry_in->leafkey )
+	if (!entry_in->leafkey)
 		POSTGIS_DEBUG(4, "[GIST] non-leafkey entry, returning input unaltered");
 		PG_RETURN_POINTER(entry_in);
@@ -1115,11 +980,10 @@
 	** Null key? Make a copy of the input entry and
 	** return.
-	if ( DatumGetPointer(entry_in->key) == NULL )
+	if (!DatumGetPointer(entry_in->key))
 		POSTGIS_DEBUG(4, "[GIST] leafkey is null");
-		gistentryinit(*entry_out, (Datum) 0, entry_in->rel,
-		              entry_in->page, entry_in->offset, false);
+		gistentryinit(*entry_out, (Datum)0, entry_in->rel, entry_in->page, entry_in->offset, false);
 		POSTGIS_DEBUG(4, "[GIST] returning copy of input");
 		PG_RETURN_POINTER(entry_out);
@@ -1129,40 +993,45 @@
 	/* Is the bounding box valid (non-empty, non-infinite) ?
 	 * If not, use the "unknown" GIDX. */
-	if ( result == LW_FAILURE )
+	if (result == LW_FAILURE)
 		POSTGIS_DEBUG(4, "[GIST] empty geometry!");
 		gidx_set_unknown(bbox_out);
-		gistentryinit(*entry_out, PointerGetDatum(gidx_copy(bbox_out)),
-		              entry_in->rel, entry_in->page,
-		              entry_in->offset, false);
+			      PointerGetDatum(gidx_copy(bbox_out)),
+			      entry_in->rel,
+			      entry_in->page,
+			      entry_in->offset,
+			      false);
 	POSTGIS_DEBUGF(4, "[GIST] got entry_in->key: %s", gidx_to_string(bbox_out));
+	/* ORIGINAL VERSION */
 	/* Check all the dimensions for finite values.
 	 * If not, use the "unknown" GIDX as a key */
-	for ( i = 0; i < GIDX_NDIMS(bbox_out); i++ )
+	for (i = 0; i < GIDX_NDIMS(bbox_out); i++)
-		if ( ! isfinite(GIDX_GET_MAX(bbox_out, i))
-		     || ! isfinite(GIDX_GET_MIN(bbox_out, i)) )
+		if (!isfinite(GIDX_GET_MAX(bbox_out, i)) || !isfinite(GIDX_GET_MIN(bbox_out, i)))
-			              PointerGetDatum(gidx_copy(bbox_out)),
+				      entry_in->rel,
+				      entry_in->page,
+				      entry_in->offset,
+				      false);
-	/* Enure bounding box has minimums below maximums. */
+	/* Ensure bounding box has minimums below maximums. */
 	gidx_validate(bbox_out);
 	/* Prepare GISTENTRY for return. */
-	              entry_in->rel, entry_in->page, entry_in->offset, false);
+	gistentryinit(
+	    *entry_out, PointerGetDatum(gidx_copy(bbox_out)), entry_in->rel, entry_in->page, entry_in->offset, false);
 	/* Return GISTENTRY. */
 	POSTGIS_DEBUG(4, "[GIST] 'compress' function complete");
@@ -1184,28 +1053,28 @@
 ** GiST support function. Called from gserialized_gist_consistent below.
-static inline bool gserialized_gist_consistent_leaf(GIDX *key, GIDX *query, StrategyNumber strategy)
+static inline bool
+gserialized_gist_consistent_leaf(GIDX *key, GIDX *query, StrategyNumber strategy)
 	bool retval;
-	POSTGIS_DEBUGF(4, "[GIST] leaf consistent, strategy [%d], count[%i]",
-	               strategy, geog_counter_leaf++);
+	POSTGIS_DEBUGF(4, "[GIST] leaf consistent, strategy [%d], count[%i]", strategy, geog_counter_leaf++);
 	switch (strategy)
 	case RTOverlapStrategyNumber:
-		retval = (bool) gidx_overlaps(key, query);
+		retval = (bool)gidx_overlaps(key, query);
 		break;
 	case RTSameStrategyNumber:
-		retval = (bool) gidx_equals(key, query);
+		retval = (bool)gidx_equals(key, query);
 		break;
 	case RTContainsStrategyNumber:
 	case RTOldContainsStrategyNumber:
-		retval = (bool) gidx_contains(key, query);
+		retval = (bool)gidx_contains(key, query);
 		break;
 	case RTContainedByStrategyNumber:
 	case RTOldContainedByStrategyNumber:
-		retval = (bool) gidx_contains(query, key);
+		retval = (bool)gidx_contains(query, key);
 		break;
 	default:
 		retval = false;
@@ -1217,27 +1086,30 @@
-static inline bool gserialized_gist_consistent_internal(GIDX *key, GIDX *query, StrategyNumber strategy)
+static inline bool
+gserialized_gist_consistent_internal(GIDX *key, GIDX *query, StrategyNumber strategy)
-	bool		retval;
+	bool retval;
-	POSTGIS_DEBUGF(4, "[GIST] internal consistent, strategy [%d], count[%i], query[%s], key[%s]",
-	               strategy, geog_counter_internal++, gidx_to_string(query), gidx_to_string(key) );
+	POSTGIS_DEBUGF(4,
+		       "[GIST] internal consistent, strategy [%d], count[%i], query[%s], key[%s]",
+		       strategy,
+		       geog_counter_internal++,
+		       gidx_to_string(query),
+		       gidx_to_string(key));
 	switch (strategy)
+	case RTContainedByStrategyNumber:
+	case RTOldContainedByStrategyNumber:
 		break;
 		break;
-	case RTContainedByStrategyNumber:
-	case RTOldContainedByStrategyNumber:
-		break;
 	default:
 		retval = false;
@@ -1252,15 +1124,15 @@
 PG_FUNCTION_INFO_V1(gserialized_gist_consistent);
 Datum gserialized_gist_consistent(PG_FUNCTION_ARGS)
-	GISTENTRY *entry = (GISTENTRY*) PG_GETARG_POINTER(0);
-	StrategyNumber strategy = (StrategyNumber) PG_GETARG_UINT16(2);
+	GISTENTRY *entry = (GISTENTRY *)PG_GETARG_POINTER(0);
+	StrategyNumber strategy = (StrategyNumber)PG_GETARG_UINT16(2);
 	bool result;
-	GIDX *query_gbox_index = (GIDX*)gidxmem;
+	GIDX *query_gbox_index = (GIDX *)gidxmem;
 	/* PostgreSQL 8.4 and later require the RECHECK flag to be set here,
 	   rather than being supplied as part of the operator class definition */
-	bool *recheck = (bool *) PG_GETARG_POINTER(4);
+	bool *recheck = (bool *)PG_GETARG_POINTER(4);
 	/* We set recheck to false to avoid repeatedly pulling every "possibly matched" geometry
 	   out during index scans. For cases when the geometries are large, rechecking
@@ -1270,7 +1142,7 @@
 	POSTGIS_DEBUG(4, "[GIST] 'consistent' function called");
 	/* Quick sanity check on query argument. */
-	if ( DatumGetPointer(PG_GETARG_DATUM(1)) == NULL )
+	if (!DatumGetPointer(PG_GETARG_DATUM(1)))
 		POSTGIS_DEBUG(4, "[GIST] null query pointer (!?!), returning false");
 		PG_RETURN_BOOL(false); /* NULL query! This is screwy! */
@@ -1277,7 +1149,7 @@
 	/* Quick sanity check on entry key. */
-	if ( DatumGetPointer(entry->key) == NULL )
+	if (!DatumGetPointer(entry->key))
 		POSTGIS_DEBUG(4, "[GIST] null index entry, returning false");
 		PG_RETURN_BOOL(false); /* NULL entry! */
@@ -1284,7 +1156,7 @@
 	/* Null box should never make this far. */
-	if ( gserialized_datum_get_gidx_p(PG_GETARG_DATUM(1), query_gbox_index) == LW_FAILURE )
+	if (gserialized_datum_get_gidx_p(PG_GETARG_DATUM(1), query_gbox_index) == LW_FAILURE)
 		POSTGIS_DEBUG(4, "[GIST] null query_gbox_index!");
@@ -1293,15 +1165,13 @@
 	/* Treat leaf node tests different from internal nodes */
 	if (GIST_LEAF(entry))
-		result = gserialized_gist_consistent_leaf(
-		             (GIDX*)DatumGetPointer(entry->key),
-		             query_gbox_index, strategy);
+		result =
+		    gserialized_gist_consistent_leaf((GIDX *)DatumGetPointer(entry->key), query_gbox_index, strategy);
 	else
 		result = gserialized_gist_consistent_internal(
+		    (GIDX *)DatumGetPointer(entry->key), query_gbox_index, strategy);
 	PG_RETURN_BOOL(result);
@@ -1320,19 +1190,26 @@
 ** greater than float b, integer A with same bit representation as a is greater
 ** than integer B with same bits as b.
-static float pack_float(const float value, const int realm)
+static float
+pack_float(const float value, const int realm)
-  union {
-    float f;
-    struct { unsigned value:31, sign:1; } vbits;
-    struct { unsigned value:29, realm:2, sign:1; } rbits;
-  } a;
+	union {
+		float f;
+		struct
+			unsigned value : 31, sign : 1;
+		} vbits;
+		struct
+			unsigned value : 29, realm : 2, sign : 1;
+		} rbits;
+	} a;
-  a.f = value;
-  a.rbits.value = a.vbits.value >> 2;
-  a.rbits.realm = realm;
+	a.f = value;
+	a.rbits.value = a.vbits.value >> 2;
+	a.rbits.realm = realm;
-  return a.f;
+	return a.f;
@@ -1342,19 +1219,19 @@
 PG_FUNCTION_INFO_V1(gserialized_gist_penalty);
 Datum gserialized_gist_penalty(PG_FUNCTION_ARGS)
-	GISTENTRY *origentry = (GISTENTRY*) PG_GETARG_POINTER(0);
-	GISTENTRY *newentry = (GISTENTRY*) PG_GETARG_POINTER(1);
-	float *result = (float*) PG_GETARG_POINTER(2);
+	GISTENTRY *origentry = (GISTENTRY *)PG_GETARG_POINTER(0);
+	GISTENTRY *newentry = (GISTENTRY *)PG_GETARG_POINTER(1);
+	float *result = (float *)PG_GETARG_POINTER(2);
 	GIDX *gbox_index_orig, *gbox_index_new;
 	float size_union, size_orig, edge_union, edge_orig;
 	POSTGIS_DEBUG(4, "[GIST] 'penalty' function called");
-	gbox_index_orig = (GIDX*)DatumGetPointer(origentry->key);
-	gbox_index_new = (GIDX*)DatumGetPointer(newentry->key);
+	gbox_index_orig = (GIDX *)DatumGetPointer(origentry->key);
+	gbox_index_new = (GIDX *)DatumGetPointer(newentry->key);
 	/* Drop out if we're dealing with null inputs. Shouldn't happen. */
-	if ( (gbox_index_orig == NULL) && (gbox_index_new == NULL) )
+	if (!gbox_index_orig && !gbox_index_new)
 		POSTGIS_DEBUG(4, "[GIST] both inputs NULL! returning penalty of zero");
 		*result = 0.0;
@@ -1367,37 +1244,30 @@
 	*result = size_union - size_orig;
 	/* REALM 0: No extension is required, volume is zero, return edge */
- 	/* REALM 1: No extension is required, return nonzero area */
- 	/* REALM 2: Area extension is zero, return nonzero edge extension */
- 	/* REALM 3: Area extension is nonzero, return it */
+	/* REALM 1: No extension is required, return nonzero area */
+	/* REALM 2: Area extension is zero, return nonzero edge extension */
+	/* REALM 3: Area extension is nonzero, return it */
- 	if( *result == 0 )
+	if (*result == 0)
 		if (size_orig > 0)
 			*result = pack_float(size_orig, 1); /* REALM 1 */
 		else
 			edge_union = gidx_union_edge(gbox_index_orig, gbox_index_new);
 			edge_orig = gidx_edge(gbox_index_orig);
- 			*result = edge_union - edge_orig;
-	 			*result = pack_float(edge_orig, 0); /* REALM 0 */
- 			else
- 				*result = pack_float(*result, 2); /* REALM 2 */
+			*result = edge_union - edge_orig;
+			if (*result == 0)
+				*result = pack_float(edge_orig, 0); /* REALM 0 */
+			else
+				*result = pack_float(*result, 2); /* REALM 2 */
- 	else
- 		*result = pack_float(*result, 3); /* REALM 3 */
+	else
+		*result = pack_float(*result, 3); /* REALM 3 */
-	POSTGIS_DEBUGF(4, "[GIST] union size (%.12f), original size (%.12f), penalty (%.12f)", size_union, size_orig, *result);
+	POSTGIS_DEBUGF(
+	    4, "[GIST] union size (%.12f), original size (%.12f), penalty (%.12f)", size_union, size_orig, *result);
 	PG_RETURN_POINTER(result);
@@ -1408,9 +1278,9 @@
 PG_FUNCTION_INFO_V1(gserialized_gist_union);
 Datum gserialized_gist_union(PG_FUNCTION_ARGS)
-	GistEntryVector	*entryvec = (GistEntryVector *) PG_GETARG_POINTER(0);
-	int *sizep = (int *) PG_GETARG_POINTER(1); /* Size of the return value */
-	int	numranges, i;
+	GistEntryVector *entryvec = (GistEntryVector *)PG_GETARG_POINTER(0);
+	int *sizep = (int *)PG_GETARG_POINTER(1); /* Size of the return value */
+	int numranges, i;
 	GIDX *box_cur, *box_union;
 	POSTGIS_DEBUG(4, "[GIST] 'union' function called");
@@ -1417,13 +1287,13 @@
 	numranges = entryvec->n;
-	box_cur = (GIDX*) DatumGetPointer(entryvec->vector[0].key);
+	box_cur = (GIDX *)DatumGetPointer(entryvec->vector[0].key);
 	box_union = gidx_copy(box_cur);
-	for ( i = 1; i < numranges; i++ )
+	for (i = 1; i < numranges; i++)
-		box_cur = (GIDX*) DatumGetPointer(entryvec->vector[i].key);
+		box_cur = (GIDX *)DatumGetPointer(entryvec->vector[i].key);
 		gidx_merge(&box_union, box_cur);
@@ -1432,7 +1302,6 @@
 	POSTGIS_DEBUGF(4, "[GIST] union called, numranges(%i), pageunion %s", numranges, gidx_to_string(box_union));
 	PG_RETURN_POINTER(box_union);
@@ -1441,9 +1310,9 @@
 PG_FUNCTION_INFO_V1(gserialized_gist_same);
 Datum gserialized_gist_same(PG_FUNCTION_ARGS)
-	GIDX *b1 = (GIDX*)PG_GETARG_POINTER(0);
-	GIDX *b2 = (GIDX*)PG_GETARG_POINTER(1);
-	bool *result = (bool*)PG_GETARG_POINTER(2);
+	GIDX *b1 = (GIDX *)PG_GETARG_POINTER(0);
+	GIDX *b2 = (GIDX *)PG_GETARG_POINTER(1);
+	bool *result = (bool *)PG_GETARG_POINTER(2);
 	POSTGIS_DEBUG(4, "[GIST] 'same' function called");
@@ -1452,20 +1321,15 @@
 PG_FUNCTION_INFO_V1(gserialized_gist_geog_distance);
 Datum gserialized_gist_geog_distance(PG_FUNCTION_ARGS)
 	Datum query_datum = PG_GETARG_DATUM(1);
-#if POSTGIS_PGSQL_VERSION >= 95
-#endif
 	char query_box_mem[GIDX_MAX_SIZE];
-	GIDX *query_box = (GIDX*)query_box_mem;
+	GIDX *query_box = (GIDX *)query_box_mem;
 	GIDX *entry_box;
 	double distance;
@@ -1472,7 +1336,7 @@
 	POSTGIS_DEBUGF(3, "[GIST] '%s' function called", __func__);
 	/* We are using '13' as the gist geography distance <-> strategy number */
-	if ( strategy != 13  )
+	if (strategy != 13)
 		elog(ERROR, "unrecognized strategy number: %d", strategy);
 		PG_RETURN_FLOAT8(FLT_MAX);
@@ -1479,22 +1343,18 @@
-	if ( gserialized_datum_get_gidx_p(query_datum, query_box) == LW_FAILURE )
+	if (gserialized_datum_get_gidx_p(query_datum, query_box) == LW_FAILURE)
 		POSTGIS_DEBUG(2, "[GIST] null query_gbox_index!");
 	/* When we hit leaf nodes, it's time to turn on recheck */
 		*recheck = true;
-#endif
 	/* Get the entry box */
-	entry_box = (GIDX*)DatumGetPointer(entry->key);
+	entry_box = (GIDX *)DatumGetPointer(entry->key);
 	/* Return distances from key-based tests should always be */
 	/* the minimum possible distance, box-to-box */
@@ -1507,7 +1367,6 @@
 ** Take in a query and an entry and return the "distance" between them.
@@ -1527,14 +1386,12 @@
 PG_FUNCTION_INFO_V1(gserialized_gist_distance);
 Datum gserialized_gist_distance(PG_FUNCTION_ARGS)
 	GIDX *entry_box;
-#endif
 	double distance;
@@ -1542,13 +1399,14 @@
 	/* Strategy 13 is <<->> */
 	/* Strategy 20 is |=| */
-	if ( strategy != 13 && strategy != 20 ) {
+	if (strategy != 13 && strategy != 20)
-	if ( gserialized_datum_get_gidx_p(PG_GETARG_DATUM(1), query_box) == LW_FAILURE )
+	if (gserialized_datum_get_gidx_p(PG_GETARG_DATUM(1), query_box) == LW_FAILURE)
@@ -1555,10 +1413,8 @@
 	distance = gidx_distance(entry_box, query_box, strategy == 20);
@@ -1565,40 +1421,21 @@
 		*recheck = true;
-#else
-	if ( strategy == 20 )
-		elog(ERROR, "You need PostgreSQL 9.5.0 or higher in order to use |=| with index");
-		PG_RETURN_FLOAT8(FLT_MAX);
-	/* Treat leaf node tests different from internal nodes */
-	if (GIST_LEAF(entry))
-		/* Calculate distance to leaves */
-		distance = (double)gidx_distance_leaf_centroid(entry_box, query_box);
-	else
-		/* Calculate distance for internal nodes */
-		distance = (double)gidx_distance_node_centroid(entry_box, query_box);
-#endif
 ** Utility function to add entries to the axis partition lists in the
 ** picksplit function.
-static void gserialized_gist_picksplit_addlist(OffsetNumber *list, GIDX **box_union, GIDX *box_current, int *pos, int num)
+static void
+gserialized_gist_picksplit_addlist(OffsetNumber *list, GIDX **box_union, GIDX *box_current, int *pos, int num)
-	if ( *pos )
-		gidx_merge(box_union,  box_current);
+	if (*pos)
+		gidx_merge(box_union, box_current);
 	else
-		memcpy((void*)(*box_union), (void*)box_current, VARSIZE(box_current));
+		memcpy((void *)(*box_union), (void *)box_current, VARSIZE(box_current));
 	list[*pos] = num;
 	(*pos)++;
@@ -1607,33 +1444,34 @@
 ** Utility function check whether the number of entries two halves of the
 ** space constitute a "bad ratio" (poor balance).
-static int gserialized_gist_picksplit_badratio(int x, int y)
+static int
+gserialized_gist_picksplit_badratio(int x, int y)
 	POSTGIS_DEBUGF(4, "[GIST] checking split ratio (%d, %d)", x, y);
-	if ( (y == 0) || (((float)x / (float)y) < LIMIT_RATIO) ||
-	     (x == 0) || (((float)y / (float)x) < LIMIT_RATIO) )
+	if ((y == 0) || (((float)x / (float)y) < LIMIT_RATIO) || (x == 0) || (((float)y / (float)x) < LIMIT_RATIO))
 		return true;
 	return false;
-static bool gserialized_gist_picksplit_badratios(int *pos, int dims)
+static bool
+gserialized_gist_picksplit_badratios(int *pos, int dims)
 	int i;
-	for ( i = 0; i < dims; i++ )
+	for (i = 0; i < dims; i++)
-		if ( gserialized_gist_picksplit_badratio(pos[2*i],pos[2*i+1]) == false )
+		if (gserialized_gist_picksplit_badratio(pos[2 * i], pos[2 * i + 1]) == false)
 			return false;
 	return true;
 ** Where the picksplit algorithm cannot find any basis for splitting one way
 ** or another, we simply split the overflowing node in half.
-static void gserialized_gist_picksplit_fallback(GistEntryVector *entryvec, GIST_SPLITVEC *v)
+static void
+gserialized_gist_picksplit_fallback(GistEntryVector *entryvec, GIST_SPLITVEC *v)
 	OffsetNumber i, maxoff;
 	GIDX *unionL = NULL;
@@ -1645,59 +1483,56 @@
 	maxoff = entryvec->n - 1;
 	nbytes = (maxoff + 2) * sizeof(OffsetNumber);
-	v->spl_left = (OffsetNumber*) palloc(nbytes);
-	v->spl_right = (OffsetNumber*) palloc(nbytes);
+	v->spl_left = (OffsetNumber *)palloc(nbytes);
+	v->spl_right = (OffsetNumber *)palloc(nbytes);
 	v->spl_nleft = v->spl_nright = 0;
 	for (i = FirstOffsetNumber; i <= maxoff; i = OffsetNumberNext(i))
-		GIDX *cur = (GIDX*)DatumGetPointer(entryvec->vector[i].key);
+		GIDX *cur = (GIDX *)DatumGetPointer(entryvec->vector[i].key);
 		if (i <= (maxoff - FirstOffsetNumber + 1) / 2)
 			v->spl_left[v->spl_nleft] = i;
-			if (unionL == NULL)
+			if (!unionL)
 				unionL = gidx_copy(cur);
 			else
 				gidx_merge(&unionL, cur);
 			v->spl_nleft++;
 		else
 			v->spl_right[v->spl_nright] = i;
-			if (unionR == NULL)
+			if (!unionR)
 				unionR = gidx_copy(cur);
 			else
 				gidx_merge(&unionR, cur);
 			v->spl_nright++;
 	if (v->spl_ldatum_exists)
-		gidx_merge(&unionL, (GIDX*)DatumGetPointer(v->spl_ldatum));
+		gidx_merge(&unionL, (GIDX *)DatumGetPointer(v->spl_ldatum));
 	v->spl_ldatum = PointerGetDatum(unionL);
 	if (v->spl_rdatum_exists)
-		gidx_merge(&unionR, (GIDX*)DatumGetPointer(v->spl_rdatum));
+		gidx_merge(&unionR, (GIDX *)DatumGetPointer(v->spl_rdatum));
 	v->spl_rdatum = PointerGetDatum(unionR);
 	v->spl_ldatum_exists = v->spl_rdatum_exists = false;
-static void gserialized_gist_picksplit_constructsplit(GIST_SPLITVEC *v, OffsetNumber *list1, int nlist1, GIDX **union1, OffsetNumber *list2, int nlist2, GIDX **union2)
+static void
+gserialized_gist_picksplit_constructsplit(GIST_SPLITVEC *v,
+					  OffsetNumber *list1,
+					  int nlist1,
+					  GIDX **union1,
+					  OffsetNumber *list2,
+					  int nlist2,
+					  GIDX **union2)
-	bool		firstToLeft = true;
+	bool firstToLeft = true;
 	POSTGIS_DEBUG(4, "[GIST] picksplit in constructsplit function");
@@ -1711,32 +1546,41 @@
 			GIDX *RLr = gidx_copy(*union1);
 			double sizeLR, sizeRL;
-			gidx_merge(&LRl, (GIDX*)DatumGetPointer(v->spl_ldatum));
-			gidx_merge(&LRr, (GIDX*)DatumGetPointer(v->spl_rdatum));
-			gidx_merge(&RLl, (GIDX*)DatumGetPointer(v->spl_ldatum));
-			gidx_merge(&RLr, (GIDX*)DatumGetPointer(v->spl_rdatum));
+			gidx_merge(&LRl, (GIDX *)DatumGetPointer(v->spl_ldatum));
+			gidx_merge(&LRr, (GIDX *)DatumGetPointer(v->spl_rdatum));
+			gidx_merge(&RLl, (GIDX *)DatumGetPointer(v->spl_ldatum));
+			gidx_merge(&RLr, (GIDX *)DatumGetPointer(v->spl_rdatum));
-			sizeLR = gidx_inter_volume(LRl,LRr);
-			sizeRL = gidx_inter_volume(RLl,RLr);
+			sizeLR = gidx_inter_volume(LRl, LRr);
+			sizeRL = gidx_inter_volume(RLl, RLr);
 			POSTGIS_DEBUGF(4, "[GIST] sizeLR / sizeRL == %.12g / %.12g", sizeLR, sizeRL);
 			if (sizeLR > sizeRL)
 				firstToLeft = false;
 		else
 			float p1, p2;
-			GISTENTRY oldUnion,	addon;
+			GISTENTRY oldUnion, addon;
-			gistentryinit(oldUnion, (v->spl_ldatum_exists) ? v->spl_ldatum : v->spl_rdatum,
-			              NULL, NULL, InvalidOffsetNumber, false);
+			gistentryinit(oldUnion,
+				      (v->spl_ldatum_exists) ? v->spl_ldatum : v->spl_rdatum,
+				      NULL,
+				      NULL,
+				      InvalidOffsetNumber,
+				      false);
 			gistentryinit(addon, PointerGetDatum(*union1), NULL, NULL, InvalidOffsetNumber, false);
-			DirectFunctionCall3(gserialized_gist_penalty, PointerGetDatum(&oldUnion), PointerGetDatum(&addon), PointerGetDatum(&p1));
+			DirectFunctionCall3(gserialized_gist_penalty,
+					    PointerGetDatum(&oldUnion),
+					    PointerGetDatum(&addon),
+					    PointerGetDatum(&p1));
 			gistentryinit(addon, PointerGetDatum(*union2), NULL, NULL, InvalidOffsetNumber, false);
-			DirectFunctionCall3(gserialized_gist_penalty, PointerGetDatum(&oldUnion), PointerGetDatum(&addon), PointerGetDatum(&p2));
+					    PointerGetDatum(&p2));
 			POSTGIS_DEBUGF(4, "[GIST] p1 / p2 == %.12g / %.12g", p1, p2);
@@ -1754,10 +1598,10 @@
 		v->spl_nleft = nlist1;
 		v->spl_nright = nlist2;
-			gidx_merge(union1, (GIDX*)DatumGetPointer(v->spl_ldatum));
+			gidx_merge(union1, (GIDX *)DatumGetPointer(v->spl_ldatum));
 		v->spl_ldatum = PointerGetDatum(*union1);
-			gidx_merge(union2, (GIDX*)DatumGetPointer(v->spl_rdatum));
+			gidx_merge(union2, (GIDX *)DatumGetPointer(v->spl_rdatum));
 		v->spl_rdatum = PointerGetDatum(*union2);
 	else
@@ -1767,10 +1611,10 @@
 		v->spl_nleft = nlist2;
 		v->spl_nright = nlist1;
-			gidx_merge(union2, (GIDX*)DatumGetPointer(v->spl_ldatum));
+			gidx_merge(union2, (GIDX *)DatumGetPointer(v->spl_ldatum));
 		v->spl_ldatum = PointerGetDatum(*union2);
-			gidx_merge(union1, (GIDX*)DatumGetPointer(v->spl_rdatum));
+			gidx_merge(union1, (GIDX *)DatumGetPointer(v->spl_rdatum));
 		v->spl_rdatum = PointerGetDatum(*union1);
@@ -1777,10 +1621,9 @@
+#define BELOW(d) (2 * (d))
+#define ABOVE(d) ((2 * (d)) + 1)
-#define BELOW(d) (2*(d))
-#define ABOVE(d) ((2*(d))+1)
 ** GiST support function. Split an overflowing node into two new nodes.
 ** Uses linear algorithm from Ang & Tan [2], dividing node extent into
@@ -1792,9 +1635,9 @@
 Datum gserialized_gist_picksplit(PG_FUNCTION_ARGS)
-	GistEntryVector	*entryvec = (GistEntryVector*) PG_GETARG_POINTER(0);
-	GIST_SPLITVEC *v = (GIST_SPLITVEC*) PG_GETARG_POINTER(1);
+	GIST_SPLITVEC *v = (GIST_SPLITVEC *)PG_GETARG_POINTER(1);
 	OffsetNumber i;
 	/* One union box for each half of the space. */
 	GIDX **box_union;
@@ -1817,24 +1660,24 @@
 	max_offset = entryvec->n - 1;
-	box_current = (GIDX*) DatumGetPointer(entryvec->vector[FirstOffsetNumber].key);
+	box_current = (GIDX *)DatumGetPointer(entryvec->vector[FirstOffsetNumber].key);
 	box_pageunion = gidx_copy(box_current);
 	/* Calculate the containing box (box_pageunion) for the whole page we are going to split. */
-	for ( i = OffsetNumberNext(FirstOffsetNumber); i <= max_offset; i = OffsetNumberNext(i) )
+	for (i = OffsetNumberNext(FirstOffsetNumber); i <= max_offset; i = OffsetNumberNext(i))
-		box_current = (GIDX*) DatumGetPointer(entryvec->vector[i].key);
+		box_current = (GIDX *)DatumGetPointer(entryvec->vector[i].key);
-		if ( all_entries_equal == true && ! gidx_equals (box_pageunion, box_current) )
+		if (all_entries_equal && !gidx_equals(box_pageunion, box_current))
 			all_entries_equal = false;
-		gidx_merge( &box_pageunion, box_current );
+		gidx_merge(&box_pageunion, box_current);
 	POSTGIS_DEBUGF(3, "[GIST] box_pageunion: %s", gidx_to_string(box_pageunion));
 	/* Every box in the page is the same! So, we split and just put half the boxes in each child. */
-	if ( all_entries_equal )
+	if (all_entries_equal)
 		POSTGIS_DEBUG(4, "[GIST] picksplit finds all entries equal!");
 		gserialized_gist_picksplit_fallback(entryvec, v);
@@ -1845,13 +1688,13 @@
 	nbytes = (max_offset + 2) * sizeof(OffsetNumber);
 	ndims_pageunion = GIDX_NDIMS(box_pageunion);
 	POSTGIS_DEBUGF(4, "[GIST] ndims_pageunion == %d", ndims_pageunion);
-	pos = palloc(2*ndims_pageunion * sizeof(int));
-	list = palloc(2*ndims_pageunion * sizeof(OffsetNumber*));
-	box_union = palloc(2*ndims_pageunion * sizeof(GIDX*));
-	for ( d = 0; d < ndims_pageunion; d++ )
+	pos = palloc(2 * ndims_pageunion * sizeof(int));
+	list = palloc(2 * ndims_pageunion * sizeof(OffsetNumber *));
+	box_union = palloc(2 * ndims_pageunion * sizeof(GIDX *));
+	for (d = 0; d < ndims_pageunion; d++)
-		list[BELOW(d)] = (OffsetNumber*) palloc(nbytes);
-		list[ABOVE(d)] = (OffsetNumber*) palloc(nbytes);
+		list[BELOW(d)] = (OffsetNumber *)palloc(nbytes);
+		list[ABOVE(d)] = (OffsetNumber *)palloc(nbytes);
 		box_union[BELOW(d)] = gidx_new(ndims_pageunion);
 		box_union[ABOVE(d)] = gidx_new(ndims_pageunion);
 		pos[BELOW(d)] = 0;
@@ -1864,23 +1707,20 @@
 	** Each entry thereby ends up in three of the six partitions.
 	POSTGIS_DEBUG(4, "[GIST] 'picksplit' calculating best split axis");
-	for ( i = FirstOffsetNumber; i <= max_offset; i = OffsetNumberNext(i) )
+	for (i = FirstOffsetNumber; i <= max_offset; i = OffsetNumberNext(i))
-			if ( GIDX_GET_MIN(box_current,d)-GIDX_GET_MIN(box_pageunion,d) < GIDX_GET_MAX(box_pageunion,d)-GIDX_GET_MAX(box_current,d) )
-				gserialized_gist_picksplit_addlist(list[BELOW(d)], &(box_union[BELOW(d)]), box_current, &(pos[BELOW(d)]), i);
+			if (GIDX_GET_MIN(box_current, d) - GIDX_GET_MIN(box_pageunion, d) <
+			    GIDX_GET_MAX(box_pageunion, d) - GIDX_GET_MAX(box_current, d))
+				gserialized_gist_picksplit_addlist(
+				    list[BELOW(d)], &(box_union[BELOW(d)]), box_current, &(pos[BELOW(d)]), i);
 			else
-				gserialized_gist_picksplit_addlist(list[ABOVE(d)], &(box_union[ABOVE(d)]), box_current, &(pos[ABOVE(d)]), i);
+				    list[ABOVE(d)], &(box_union[ABOVE(d)]), box_current, &(pos[ABOVE(d)]), i);
@@ -1890,7 +1730,7 @@
 	** sides of the page union box can occasionally all end up in one place, leading
 	** to this condition.
-	if ( gserialized_gist_picksplit_badratios(pos,ndims_pageunion) == true )
+	if (gserialized_gist_picksplit_badratios(pos, ndims_pageunion) == true)
 		** Instead we split on center points and see if we do better.
@@ -1898,22 +1738,18 @@
 		double *avgCenter = palloc(ndims_pageunion * sizeof(double));
 			avgCenter[d] = 0.0;
 		POSTGIS_DEBUG(4, "[GIST] picksplit can't find good split axis, trying center point method");
-				avgCenter[d] += (GIDX_GET_MAX(box_current,d) + GIDX_GET_MIN(box_current,d)) / 2.0;
+				avgCenter[d] += (GIDX_GET_MAX(box_current, d) + GIDX_GET_MIN(box_current, d)) / 2.0;
 			avgCenter[d] /= max_offset;
 			pos[BELOW(d)] = pos[ABOVE(d)] = 0; /* Re-initialize our counters. */
@@ -1921,35 +1757,44 @@
 		/* For each of our entries... */
 			double center;
-				center = (GIDX_GET_MIN(box_current,d)+GIDX_GET_MAX(box_current,d))/2.0;
-				if ( center < avgCenter[d] )
-				else if ( FPeq(center, avgCenter[d]) )
-					if ( pos[BELOW(d)] > pos[ABOVE(d)] )
+				center = (GIDX_GET_MIN(box_current, d) + GIDX_GET_MAX(box_current, d)) / 2.0;
+				if (center < avgCenter[d])
+				else if (FPeq(center, avgCenter[d]))
+					if (pos[BELOW(d)] > pos[ABOVE(d)])
+						gserialized_gist_picksplit_addlist(list[ABOVE(d)],
+										   &(box_union[ABOVE(d)]),
+										   box_current,
+										   &(pos[ABOVE(d)]),
+										   i);
 					else
+						gserialized_gist_picksplit_addlist(list[BELOW(d)],
+										   &(box_union[BELOW(d)]),
+										   box_current,
+										   &(pos[BELOW(d)]),
+										   i);
 				else
 		/* Do we have a good disposition now? If not, screw it, just cut the node in half. */
+		if (gserialized_gist_picksplit_badratios(pos, ndims_pageunion))
-			POSTGIS_DEBUG(4, "[GIST] picksplit still cannot find a good split! just cutting the node in half");
+			POSTGIS_DEBUG(4,
+				      "[GIST] picksplit still cannot find a good split! just cutting the node in half");
 			PG_RETURN_POINTER(v);
@@ -1959,41 +1804,43 @@
 	** number of entries in its regions is the most evenly distributed.
 	** TODO: what if the distributions are equal in two or more axes?
-		int posd = Max(pos[ABOVE(d)],pos[BELOW(d)]);
-		if ( posd < posmin )
+		int posd = Max(pos[ABOVE(d)], pos[BELOW(d)]);
+		if (posd < posmin)
 			direction = d;
 			posmin = posd;
-	if ( direction == -1 || posmin == entryvec->n )
-		/* ERROR OUT HERE */
+	if (direction == -1 || posmin == entryvec->n)
 		elog(ERROR, "Error in building split, unable to determine split direction.");
 	POSTGIS_DEBUGF(3, "[GIST] 'picksplit' splitting on axis %d", direction);
-	gserialized_gist_picksplit_constructsplit(v, list[BELOW(direction)],
-	                                        pos[BELOW(direction)],
-	                                        &(box_union[BELOW(direction)]),
-	                                        list[ABOVE(direction)],
-	                                        pos[ABOVE(direction)],
-	                                        &(box_union[ABOVE(direction)]) );
+	gserialized_gist_picksplit_constructsplit(v,
+						  list[BELOW(direction)],
+						  pos[BELOW(direction)],
+						  &(box_union[BELOW(direction)]),
+						  list[ABOVE(direction)],
+						  pos[ABOVE(direction)],
+						  &(box_union[ABOVE(direction)]));
-	POSTGIS_DEBUGF(4, "[GIST] spl_ldatum: %s", gidx_to_string((GIDX*)v->spl_ldatum));
-	POSTGIS_DEBUGF(4, "[GIST] spl_rdatum: %s", gidx_to_string((GIDX*)v->spl_rdatum));
+	POSTGIS_DEBUGF(4, "[GIST] spl_ldatum: %s", gidx_to_string((GIDX *)v->spl_ldatum));
+	POSTGIS_DEBUGF(4, "[GIST] spl_rdatum: %s", gidx_to_string((GIDX *)v->spl_rdatum));
-	POSTGIS_DEBUGF(4, "[GIST] axis %d: parent range (%.12g, %.12g) left range (%.12g, %.12g), right range (%.12g, %.12g)",
-	               direction,
-	               GIDX_GET_MIN(box_pageunion, direction), GIDX_GET_MAX(box_pageunion, direction),
-	               GIDX_GET_MIN((GIDX*)v->spl_ldatum, direction), GIDX_GET_MAX((GIDX*)v->spl_ldatum, direction),
-	               GIDX_GET_MIN((GIDX*)v->spl_rdatum, direction), GIDX_GET_MAX((GIDX*)v->spl_rdatum, direction) );
+	POSTGIS_DEBUGF(
+	    4,
+	    "[GIST] axis %d: parent range (%.12g, %.12g) left range (%.12g, %.12g), right range (%.12g, %.12g)",
+	    direction,
+	    GIDX_GET_MIN(box_pageunion, direction),
+	    GIDX_GET_MAX(box_pageunion, direction),
+	    GIDX_GET_MIN((GIDX *)v->spl_ldatum, direction),
+	    GIDX_GET_MAX((GIDX *)v->spl_ldatum, direction),
+	    GIDX_GET_MIN((GIDX *)v->spl_rdatum, direction),
+	    GIDX_GET_MAX((GIDX *)v->spl_rdatum, direction));
@@ -2003,8 +1850,7 @@
 PG_FUNCTION_INFO_V1(gidx_in);
 Datum gidx_in(PG_FUNCTION_ARGS)
-	ereport(ERROR,(errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
-	               errmsg("function gidx_in not implemented")));
+	ereport(ERROR, (errcode(ERRCODE_FEATURE_NOT_SUPPORTED), errmsg("function gidx_in not implemented")));
 	PG_RETURN_POINTER(NULL);
@@ -2011,7 +1857,7 @@
 PG_FUNCTION_INFO_V1(gidx_out);
 Datum gidx_out(PG_FUNCTION_ARGS)
-  GIDX *box = (GIDX *) PG_GETARG_POINTER(0);
-  char *result = gidx_to_string(box);
-  PG_RETURN_CSTRING(result);
+	GIDX *box = (GIDX *)PG_GETARG_POINTER(0);
+	char *result = gidx_to_string(box);
+	PG_RETURN_CSTRING(result);
Modified: trunk/postgis/lwgeom_box3d.c
--- trunk/postgis/lwgeom_box3d.c	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/postgis/lwgeom_box3d.c	2018-11-11 10:39:57 UTC (rev 17001)
@@ -28,6 +28,7 @@
 #include "fmgr.h"
 #include "utils/elog.h"
 #include "utils/geo_decls.h"
+#include "gserialized_spgist_3d.h"
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/postgis/postgis.sql.in	2018-11-11 10:39:57 UTC (rev 17001)
@@ -824,6 +824,48 @@
 	JOIN = gserialized_gist_joinsel_nd
+-- Availability: 2.5.0
+CREATE OR REPLACE FUNCTION geometry_contains_nd(geometry, geometry)
+	RETURNS boolean
+	AS 'MODULE_PATHNAME' ,'gserialized_contains'
+	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+CREATE OPERATOR ~~ (
+	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_contains_nd,
+	COMMUTATOR = '@@',
+	RESTRICT = gserialized_gist_sel_nd,
+	JOIN = gserialized_gist_joinsel_nd
+CREATE OR REPLACE FUNCTION geometry_within_nd(geometry, geometry)
+	RETURNS boolean
+	AS 'MODULE_PATHNAME' ,'gserialized_within'
+CREATE OPERATOR @@ (
+	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_within_nd,
+	COMMUTATOR = '~~',
+CREATE OR REPLACE FUNCTION geometry_same_nd(geometry, geometry)
+	RETURNS boolean
+	AS 'MODULE_PATHNAME' ,'gserialized_same'
+CREATE OPERATOR ~~= (
+	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_same_nd,
+	COMMUTATOR = '~~=',
 -- Availability: 2.2.0
 CREATE OR REPLACE FUNCTION geometry_distance_centroid_nd(geometry,geometry)
 	RETURNS float8
@@ -866,9 +908,12 @@
 	FOR TYPE geometry USING GIST AS
 	STORAGE 	gidx,
 	OPERATOR        3        &&&	,
---	OPERATOR        6        ~=	,
---	OPERATOR        7        ~	,
---	OPERATOR        8        @	,
+	-- Availability: 2.5.0
+	OPERATOR        6        ~~=	,
+	OPERATOR        7        ~~	,
+	OPERATOR        8        @@	,
 	OPERATOR        13       <<->> FOR ORDER BY pg_catalog.float_ops,
Modified: trunk/postgis/postgis_spgist.sql.in
--- trunk/postgis/postgis_spgist.sql.in	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/postgis/postgis_spgist.sql.in	2018-11-11 10:39:57 UTC (rev 17001)
@@ -163,4 +163,107 @@
 	FUNCTION	4	geometry_spgist_inner_consistent_3d(internal, internal),
 	FUNCTION	5	geometry_spgist_leaf_consistent_3d(internal, internal),
 	FUNCTION	6	geometry_spgist_compress_3d(internal);
+-- SP-GiST ND Support Functions
+-- Geometry
+CREATE OR REPLACE FUNCTION geometry_spgist_config_nd(internal, internal)
+	RETURNS void
+	AS 'MODULE_PATHNAME' ,'gserialized_spgist_config_nd'
+	LANGUAGE C IMMUTABLE STRICT PARALLEL SAFE;
+CREATE OR REPLACE FUNCTION geometry_spgist_choose_nd(internal, internal)
+	RETURNS void
+	AS 'MODULE_PATHNAME' ,'gserialized_spgist_choose_nd'
+CREATE OR REPLACE FUNCTION geometry_spgist_picksplit_nd(internal, internal)
+	RETURNS void
+	AS 'MODULE_PATHNAME' ,'gserialized_spgist_picksplit_nd'
+CREATE OR REPLACE FUNCTION geometry_spgist_inner_consistent_nd(internal, internal)
+	RETURNS void
+	AS 'MODULE_PATHNAME' ,'gserialized_spgist_inner_consistent_nd'
+CREATE OR REPLACE FUNCTION geometry_spgist_leaf_consistent_nd(internal, internal)
+	RETURNS bool
+	AS 'MODULE_PATHNAME' ,'gserialized_spgist_leaf_consistent_nd'
+CREATE OR REPLACE FUNCTION geometry_spgist_compress_nd(internal)
+	RETURNS internal
+	AS 'MODULE_PATHNAME' ,'gserialized_spgist_compress_nd'
+CREATE OPERATOR CLASS spgist_geometry_ops_nd
+	FOR TYPE geometry USING SPGIST AS
+	OPERATOR        3        &&& ,
+	OPERATOR        6        ~~=	,
+	OPERATOR        7        ~~	,
+	OPERATOR        8       @@ 	,
+	FUNCTION		1		geometry_spgist_config_nd(internal, internal),
+	FUNCTION		2		geometry_spgist_choose_nd(internal, internal),
+	FUNCTION		3		geometry_spgist_picksplit_nd(internal, internal),
+	FUNCTION		4		geometry_spgist_inner_consistent_nd(internal, internal),
+	FUNCTION		5		geometry_spgist_leaf_consistent_nd(internal, internal),
+	FUNCTION		6		geometry_spgist_compress_nd(internal);
+-- Geography
+CREATE OR REPLACE FUNCTION geography_spgist_config_nd(internal, internal)
+	RETURNS void
+CREATE OR REPLACE FUNCTION geography_spgist_choose_nd(internal, internal)
+	RETURNS void
+CREATE OR REPLACE FUNCTION geography_spgist_picksplit_nd(internal, internal)
+	RETURNS void
+CREATE OR REPLACE FUNCTION geography_spgist_inner_consistent_nd(internal, internal)
+	RETURNS void
+CREATE OR REPLACE FUNCTION geography_spgist_leaf_consistent_nd(internal, internal)
+	RETURNS bool
+CREATE OR REPLACE FUNCTION geography_spgist_compress_nd(internal)
+	RETURNS internal
+CREATE OPERATOR CLASS spgist_geography_ops_nd
+	DEFAULT FOR TYPE geography USING SPGIST AS
+	OPERATOR        3        && ,
+--	OPERATOR        6        ~=	,
+--	OPERATOR        7        ~	,
+--	OPERATOR        8        @	,
+	FUNCTION		1		geography_spgist_config_nd(internal, internal),
+	FUNCTION		2		geography_spgist_choose_nd(internal, internal),
+	FUNCTION		3		geography_spgist_picksplit_nd(internal, internal),
+	FUNCTION		4		geography_spgist_inner_consistent_nd(internal, internal),
+	FUNCTION		5		geography_spgist_leaf_consistent_nd(internal, internal),
+	FUNCTION		6		geography_spgist_compress_nd(internal);
 #endif
Modified: trunk/regress/core/Makefile.in
--- trunk/regress/core/Makefile.in	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/regress/core/Makefile.in	2018-11-11 10:39:57 UTC (rev 17001)
@@ -233,7 +233,9 @@
 ifeq ($(HAVE_SPGIST),yes)
 	TESTS += \
 	regress_spgist_index_2d \
-	regress_spgist_index_3d
+	regress_spgist_index_3d \
+	regress_spgist_index_nd #\
+#	regress_gist_index_nd
 endif
 ifeq ($(HAVE_PROTOBUF),yes)
Modified: trunk/regress/core/operators.sql
--- trunk/regress/core/operators.sql	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/regress/core/operators.sql	2018-11-11 10:39:57 UTC (rev 17001)
@@ -115,31 +115,122 @@
 -- &&& with mixed dimensions
 WITH v(i,g) AS ( VALUES
- (1,'POINT(0 0)'::geometry), -- true, infinite M range
- (2,'POINTZ(0 0 1)'),        -- true, infinite M range
- (3,'POINTZ(0 0 0)'),        -- true, infinite M range
- (4,'POINTM(0 0 1)'),        -- true, fully defined overlap
- (5,'POINTZM(0 0 0 1)'),     -- true, fully defined overlap
- (6,'POINTZM(0 0 1 0)'),     -- false, M out of range
- (7,'LINESTRINGM(-1 0 2,1 0 3)'), -- false, M out of range
- (8,'LINESTRINGZ(-1 0 2,1 0 3)')  -- true, infinite M range
+ (1,'POINT(0 0)'::geometry),			-- true for {1,2,3,4,5,6,7,8,9}
+ (2,'POINTZ(0 0 1)'),					-- true for {1,2,4,6,7}
+ (3,'POINTZ(0 0 0)'),					-- true for {1,3,4,5,7}
+ (4,'POINTM(0 0 1)'),					-- true for {1,2,3,4,5,8}
+ (5,'POINTZM(0 0 0 1)'),				-- true for {1,3,4,5}
+ (6,'POINTZM(0 0 1 0)'),					-- true for {1,2,6}
+ (7,'LINESTRINGM(-1 0 2,1 0 3)'),		-- true for {1,2,3,7,8,9}
+ (8,'LINESTRINGZ(-1 0 2,1 0 3)'),		-- true for {1,4,7,8,9}
+ (9,'LINESTRINGZM(-1 0 2 2,1 0 3 3)')	-- true for {1,7,8,9}
-SELECT 'ndovm1', array_agg(i) FROM v WHERE g &&& 'POINTM(0 0 1)'::geometry
-ORDER BY 1;
+SELECT 'ndovm', v1.i, array_agg(v2.i) FROM v v1, v v2 WHERE v1.g &&& v2.g
+group by v1.i
+ORDER BY 2;
+-- nd contains             ~~
+select 'ndcont1', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~
+                'POINT(3 3 3 5)'::geometry; -- f
+select 'ndcont2', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~
+                'POINT(3 3 5 3)'::geometry; -- f
+select 'ndcont3', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~
+                'POINT(3 5 3 3)'::geometry; -- f
+select 'ndcont4', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~
+                'POINT(5 3 3 3)'::geometry; -- f
+select 'ndcont5', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~
+                'POINT(3 3 3 3)'::geometry; -- t
+select 'ndcont6', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~
+                'POINT(2 4 2 4)'::geometry; -- t
+select 'ndcont7', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~
+                'POINT(4 2 4 2)'::geometry; -- t
+-- ~~ with mixed dimensions
- (1,'POINT(0 0)'::geometry), -- true, infinite Z range
- (2,'POINTZ(0 0 1)'),        -- true, fully defined overlap
- (3,'POINTZ(0 0 0)'),        -- false, Z out of range
- (4,'POINTM(0 0 0)'),        -- true, infinite Z range
- (5,'POINTZM(0 0 0 1)'),     -- false, Z out of range
- (6,'POINTZM(0 0 1 0)'),     -- true, fully defined overlap
- (7,'LINESTRINGM(-1 0 2,1 0 3)'), -- true, infinite Z range
- (8,'LINESTRINGZ(-1 0 2,1 0 3)')  -- false, Z out of range
-SELECT 'ndovm2', array_agg(i) FROM v WHERE g &&& 'POINTZ(0 0 1)'::geometry
-ORDER BY 1;
+SELECT 'ndcontm', v1.i, array_agg(v2.i) FROM v v1, v v2 WHERE v1.g ~~ v2.g
+group by v1.i
+ORDER BY 2;
+-- nd within             @@
+select 'ndwithin1', 'POINT(3 3 3 5)'::geometry @@
+                'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry; -- f
+select 'ndwithin2', 'POINT(3 3 5 3)'::geometry @@
+select 'ndwithin3', 'POINT(3 5 3 3)'::geometry @@
+select 'ndwithin4', 'POINT(5 3 3 3)'::geometry @@
+select 'ndwithin5', 'POINT(3 3 3 3)'::geometry @@
+                'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry; -- t
+select 'ndwithin6', 'POINT(2 4 2 4)'::geometry @@
+select 'ndwithin7', 'POINT(4 2 4 2)'::geometry @@
+-- @@ with mixed dimensions
+WITH v(i,g) AS ( VALUES
+SELECT 'ndwithinm', v1.i, array_agg(v2.i) FROM v v1, v v2 WHERE v1.g @@ v2.g
+group by v1.i
+ORDER BY 2;
+-- nd same             ~~=
+select 'ndsame1', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~=
+                'POINT(3 3 3 3)'::geometry; -- f
+select 'ndsame2', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~=
+                'LINESTRING(2 2 2 2, 4 4 4 5)'::geometry; -- f
+select 'ndsame3', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~=
+                'LINESTRING(2 2 2 2, 4 4 5 4)'::geometry; -- f
+select 'ndsame4', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~=
+                'LINESTRING(2 2 2 2, 4 5 4 4)'::geometry; -- f
+select 'ndsame5', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~=
+                'LINESTRING(2 2 2 2, 5 4 4 4)'::geometry; -- f
+select 'ndsame6', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~=
+                'LINESTRING(4 4 4 4, 2 2 2 2)'::geometry; -- t
+select 'ndsame7', 'LINESTRING(2 2 2 2, 4 4 4 4)'::geometry ~~=
+                'LINESTRING(2 2 2 4, 2 2 4 2, 2 4 2 2, 4 2 2 2)'::geometry; -- t
+-- ~~= with mixed dimensions
+SELECT 'ndsamem', v1.i, array_agg(v2.i) FROM v v1, v v2 WHERE v1.g ~~= v2.g
+group by v1.i
+ORDER BY 2;
 -- GROUP BY on empty
 SELECT '#3777', ST_AsText(geom), count(*)
 FROM (VALUES
Modified: trunk/regress/core/operators_expected
--- trunk/regress/core/operators_expected	2018-11-11 10:26:13 UTC (rev 17000)
+++ trunk/regress/core/operators_expected	2018-11-11 10:39:57 UTC (rev 17001)
@@ -54,8 +54,63 @@
 ndov5|t
 ndov6|t
 ndov7|t
-ndovm1|{1,2,3,4,5,8}
-ndovm2|{1,2,4,6,7}
+ndovm|1|{1,2,3,4,5,6,7,8,9}
+ndovm|2|{1,2,4,6,7}
+ndovm|3|{1,3,4,5,7}
+ndovm|4|{1,2,3,4,5,8}
+ndovm|5|{1,3,4,5}
+ndovm|6|{1,2,6}
+ndovm|7|{1,2,3,7,8,9}
+ndovm|8|{1,4,7,8,9}
+ndovm|9|{1,7,8,9}
+ndcont1|f
+ndcont2|f
+ndcont3|f
+ndcont4|f
+ndcont5|t
+ndcont6|t
+ndcont7|t
+ndcontm|1|{1,2,3,4,5,6}
+ndcontm|2|{1,2,4,6}
+ndcontm|3|{1,3,4,5}
+ndcontm|4|{1,2,3,4,5}
+ndcontm|5|{1,3,4,5}
+ndcontm|6|{1,2,6}
+ndcontm|7|{1,2,3,7,8,9}
+ndcontm|8|{1,4,7,8,9}
+ndcontm|9|{1,7,8,9}
+ndwithin1|f
+ndwithin2|f
+ndwithin3|f
+ndwithin4|f
+ndwithin5|t
+ndwithin6|t
+ndwithin7|t
+ndwithinm|1|{1,2,3,4,5,6,7,8,9}
+ndwithinm|2|{1,2,4,6,7}
+ndwithinm|3|{1,3,4,5,7}
+ndwithinm|4|{1,2,3,4,5,8}
+ndwithinm|5|{1,3,4,5}
+ndwithinm|6|{1,2,6}
+ndwithinm|7|{7,8,9}
+ndwithinm|8|{7,8,9}
+ndwithinm|9|{7,8,9}
+ndsame1|f
+ndsame2|f
+ndsame3|f
+ndsame4|f
+ndsame5|f
+ndsame6|t
+ndsame7|t
+ndsamem|1|{1,2,3,4,5,6}
+ndsamem|2|{1,2,4,6}
+ndsamem|3|{1,3,4,5}
+ndsamem|4|{1,2,3,4,5}
+ndsamem|5|{1,3,4,5}
+ndsamem|6|{1,2,6}
+ndsamem|7|{7,8,9}
+ndsamem|8|{7,8,9}
+ndsamem|9|{7,8,9}
 #3777|GEOMETRYCOLLECTION EMPTY|1
 #3777|LINESTRING(0 0,0 1)|1
 #3777|POINT EMPTY|1
