[postgis-tickets] r17007 - Un-break build with debug logs
Raul raul at rmr.ninja
Tue Nov 13 02:49:07 PST 2018
Author: algunenano
Date: 2018-11-13 02:49:06 -0800 (Tue, 13 Nov 2018)
New Revision: 17007
   trunk/liblwgeom/lwstroke.c
   trunk/postgis/gserialized_spgist_2d.c
Related to #4235
Modified: trunk/liblwgeom/lwstroke.c
--- trunk/liblwgeom/lwstroke.c	2018-11-13 10:47:14 UTC (rev 17006)
+++ trunk/liblwgeom/lwstroke.c	2018-11-13 10:49:06 UTC (rev 17007)
@@ -178,8 +178,11 @@
 	if ( maxErr > radius * 2 )
 		maxErr = radius * 2;
-		LWDEBUGF(2, "lwarc_linearize: tolerance %g is too big, "
-			    "using arc-max 2 * radius == %g", tol, maxErr);
+		LWDEBUGF(2,
+			 "lwarc_linearize: tolerance %g is too big, "
+			 "using arc-max 2 * radius == %g",
+			 max_deviation,
+			 maxErr);
 	do {
 		halfAngle = acos( 1.0 - maxErr / radius );
@@ -191,7 +194,13 @@
 		maxErr *= 2;
 	} while(1);
 	increment = 2 * halfAngle;
-	LWDEBUGF(2, "lwarc_linearize: maxDiff:%g, radius:%g, halfAngle:%g, increment:%g (%g degrees)", tol, radius, halfAngle, increment, increment*180/M_PI);
+	LWDEBUGF(2,
+		 "lwarc_linearize: maxDiff:%g, radius:%g, halfAngle:%g, increment:%g (%g degrees)",
+		 max_deviation,
+		 radius,
+		 halfAngle,
+		 increment,
+		 increment * 180 / M_PI);
 	return increment;
@@ -337,12 +346,11 @@
 	if ( flags & LW_LINEARIZE_FLAG_SYMMETRIC )
-		LWDEBUGF(2, "lwarc_linearize SYMMETRIC requested - total angle %g deg",
-			         angle * 180 / M_PI);
+		LWDEBUGF(2, "lwarc_linearize SYMMETRIC requested - total angle %g deg", total_angle * 180 / M_PI);
 		if ( flags & LW_LINEARIZE_FLAG_RETAIN_ANGLE )
 			/* Number of complete steps */
 			int steps = trunc(total_angle / increment);
@@ -360,9 +368,9 @@
 			         "total angle %g, steps %d, increment %g, remainder %g",
 			         total_angle * 180 / M_PI, steps, increment * 180 / M_PI,
 			         angle_remainder * 180 / M_PI);
 		else
 			/* Number of segments in output */
 			int segs = ceil(total_angle / increment);
 			/* Tweak increment to be regular for all the arc */
@@ -372,8 +380,8 @@
 							"total angle %g degrees - LINESTRING(%g %g,%g %g,%g %g) - S:%d -   I:%g",
 							total_angle*180/M_PI, p1->x, p1->y, center.x, center.y, p3->x, p3->y,
 							segs, increment*180/M_PI);
 	/* p2 on left side => clockwise sweep */
 	if ( clockwise )
Modified: trunk/postgis/gserialized_spgist_2d.c
--- trunk/postgis/gserialized_spgist_2d.c	2018-11-13 10:47:14 UTC (rev 17006)
+++ trunk/postgis/gserialized_spgist_2d.c	2018-11-13 10:49:06 UTC (rev 17007)
@@ -679,8 +679,6 @@
 		PG_RETURN_POINTER(bbox_out);
-	POSTGIS_DEBUGF(4, "[SPGIST] got box: %s", box2df_to_string(bbox_out));
 	/* Check all the dimensions for finite values */
 	if ((!isfinite(bbox_out->xmax) || !isfinite(bbox_out->xmin)) ||
 	    (!isfinite(bbox_out->ymax) || !isfinite(bbox_out->ymin)))
