[postgis-tickets] [PostGIS] #2921: Tell more about max_err parameter in documentation for ST_Rescale
trac at osgeo.org
Tue Nov 13 05:25:06 PST 2018
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: documentation | Version: 2.1.x
Resolution: | Keywords: raster
Comment (by komzpa):
sunveersingh,
this issue is less trivial than previous ones. :)
1. find a file that creates raster extension in SQL, it is somewhere in
raster directory and ends with .sql.in;
2. find there ST_Rescale, and see how it is defined. It may be written in
SQL or in C. if it is written in SQL, read it there, otherwise it will
have C function name - search all the files for it and start reading.
3. figure out what max_err is doing. What unit is it in? How is this error
calculated? What happens when max_err is reached?
4. write a couple of sentences about it into raster file in doc/ as a
separate new paragraph.
Does this look like a plan you can follow?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2921#comment:2>
