[postgis-tickets] [PostGIS] #4237: gidx_merge may store uninitialized memory
PostGIS trac at osgeo.org
Wed Nov 14 09:23:37 PST 2018
 Reporter:  Algunenano  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  high        |  Milestone:  PostGIS 3.0.0
Component:  postgis     |    Version:  trunk
 Keywords:              |
 Detected with the memory sanitizer, so take it with a grain of salt:
  value was stored to memory at
  0x56464e28e2c5 in main
 /usr/src/debug/postgres/src/backend/main/main.c:228:3
  0x7f814fbac222 in __libc_start_main (/usr/lib/libc.so.6+0x24222)
  0x7f80433baf07 in gidx_merge
 /home/raul/dev/public/postgis/postgis/gserialized_gist_nd.c:196:3
  0x7f80433baf07 in gserialized_gist_picksplit_addlist
 /home/raul/dev/public/postgis/postgis/gserialized_gist_nd.c:1427
 /home/raul/dev/public/postgis/postgis/gserialized_gist_nd.c:1712
  0x56464d2cc09d in _start (/usr/bin/postgres+0xf809d)
  0x56464f611657 in FunctionCall2Coll
 /usr/src/debug/postgres/src/backend/utils/fmgr/fmgr.c:1145:11
 It seems that the loop at
 (https://github.com/postgis/postgis/blob/e89dd5b3ab9bbf87adcca196716c27b8636c6711/postgis/gserialized_gist_nd.c#L191)
 accesses and stores uninitialized memory when `i >= dims_union`. This
 memory was generated in the previous `if` by `repalloc` which, if it's a
 wrapper to realloc:
 If the new size is larger than the old size, the added memory will not be
 initialized.
 I haven't checked if previous releases are affected too.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4237>
