[postgis-tickets] r17021 - Avoid undefined behaviour in gserialized_estimate
Raul
raul at rmr.ninja
Thu Nov 15 08:08:35 PST 2018
Author: algunenano
Date: 2018-11-15 08:08:35 -0800 (Thu, 15 Nov 2018)
New Revision: 17021
branches/2.5/NEWS
branches/2.5/postgis/gserialized_estimate.c
References #4190
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2018-11-15 16:07:47 UTC (rev 17020)
+++ branches/2.5/NEWS 2018-11-15 16:08:35 UTC (rev 17021)
@@ -19,6 +19,7 @@
- #4216, Revert non-sliced box access (Paul Ramsey)
- #2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)
- #4326, Allocate enough memory in gidx_to_string (Raúl Marín)
+ - #4190, Avoid undefined behaviour in gserialized_estimate
PostGIS 2.5.0
Modified: branches/2.5/postgis/gserialized_estimate.c
--- branches/2.5/postgis/gserialized_estimate.c 2018-11-15 16:07:47 UTC (rev 17020)
+++ branches/2.5/postgis/gserialized_estimate.c 2018-11-15 16:08:35 UTC (rev 17021)
@@ -657,7 +657,9 @@
for ( d = 0; d < ND_DIMS; d++ )
size = nd_box->max[d] - nd_box->min[d];
- if ( size <= 0 ) continue;
+ /* Avoid expanding boxes that are either too wide or too narrow*/
+ if (size < MIN_DIMENSION_WIDTH || size > MAX_DIMENSION_WIDTH)
+ continue;
nd_box->min[d] -= size * expansion_factor / 2;
nd_box->max[d] += size * expansion_factor / 2;
@@ -684,18 +686,26 @@
double smin = nd_stats->extent.min[d];
double smax = nd_stats->extent.max[d];
double width = smax - smin;
- int size = roundf(nd_stats->size[d]);
- /* ... find cells the box overlaps with in this dimension */
- nd_ibox->min[d] = floor(size * (nd_box->min[d] - smin) / width);
- nd_ibox->max[d] = floor(size * (nd_box->max[d] - smin) / width);
+ if (width < MIN_DIMENSION_WIDTH)
+ nd_ibox->min[d] = nd_ibox->max[d] = nd_stats->extent.min[d];
+ else
+ int size = (int)roundf(nd_stats->size[d]);
- POSTGIS_DEBUGF(5, " stats: dim %d: min %g: max %g: width %g", d, smin, smax, width);
- POSTGIS_DEBUGF(5, " overlap: dim %d: (%d, %d)", d, nd_ibox->min[d], nd_ibox->max[d]);
+ /* ... find cells the box overlaps with in this dimension */
+ nd_ibox->min[d] = floor(size * (nd_box->min[d] - smin) / width);
+ nd_ibox->max[d] = floor(size * (nd_box->max[d] - smin) / width);
- /* Push any out-of range values into range */
- nd_ibox->min[d] = Max(nd_ibox->min[d], 0);
- nd_ibox->max[d] = Min(nd_ibox->max[d], size-1);
+ POSTGIS_DEBUGF(5, " stats: dim %d: min %g: max %g: width %g", d, smin, smax, width);
+ POSTGIS_DEBUGF(5, " overlap: dim %d: (%d, %d)", d, nd_ibox->min[d], nd_ibox->max[d]);
+ /* Push any out-of range values into range */
+ nd_ibox->min[d] = Max(nd_ibox->min[d], 0);
+ nd_ibox->max[d] = Min(nd_ibox->max[d], size - 1);
return true;
@@ -1903,7 +1913,9 @@
POSTGIS_DEBUGF(3, " attribute stat target: %d", attr->attstattarget);
- /* Setup the minimum rows and the algorithm function */
+ /* Setup the minimum rows and the algorithm function.
+ * 300 matches the default value set in
+ * postgresql/src/backend/commands/analyze.c */
stats->minrows = 300 * stats->attr->attstattarget;
stats->compute_stats = compute_gserialized_stats;
