[postgis-tickets] r17024 - update change log in prep for 2.5.1 release
Regina Obe
lr at pcorp.us
Sun Nov 18 01:19:32 PST 2018
Author: robe
Date: 2018-11-18 01:19:32 -0800 (Sun, 18 Nov 2018)
New Revision: 17024
branches/2.5/ChangeLog
Modified: branches/2.5/ChangeLog
--- branches/2.5/ChangeLog 2018-11-18 08:43:10 UTC (rev 17023)
+++ branches/2.5/ChangeLog 2018-11-18 09:19:32 UTC (rev 17024)
@@ -1,3 +1,222 @@
+2018-11-18 08:43 Regina Obe <lr at pcorp.us>
+ * [r17023] Prepping for 2.5.1 release
+2018-11-15 16:08 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17021] Avoid undefined behaviour in gserialized_estimate
+ References #4190
+2018-11-15 09:06 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17018] Allocate enough memory in gidx_to_string
+ References #4236
+2018-11-13 10:47 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17006] Un-break build with debug logs
+ Related to #4235
+2018-11-12 09:15 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17003] ST_Scale: Document the availability of the origin
+ parameter
+ References #4232
+2018-11-08 06:57 Darafei Praliaskouski <me at komzpa.net>
+ * [r16997] Documentation for AddRasterConstraint optional
+ parameters
+ Patch by Sunveer Singh
+ Closes #2767
+ Closes https://github.com/postgis/postgis/pull/325
+2018-11-07 17:56 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16995] Revert change to avoid slicing on box access.
+ References #4216
+2018-11-07 16:50 Regina Obe <lr at pcorp.us>
+ * [r16992] Get rid of trailing space
+2018-11-07 16:27 Regina Obe <lr at pcorp.us>
+ * [r16991] Schema qualify some missed calls in raster plpgsql/sql
+ functions
+2018-11-06 22:26 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16985] Add name to NEWS
+2018-11-06 20:30 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16984] Move to "postgis blue" #468
+2018-11-05 22:46 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16982] Update news for #4223
+2018-11-05 22:36 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16980] Patch over bad behaviour for near-parallel boxes and
+ distancetree.
+ Unfortunately, this "fix" is probably breakable, just put the
+ boxes closer and closer together until we get "close enough to be
+ the same" results from the edge normal comparison again. Only way
+ around this is to do dot product and comparisons in
+ higher-than-double space
+ References #4223
+2018-11-02 22:15 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16974] Try for a responsive font size?
+2018-10-30 20:30 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16966] Update icons to new doco versions
+2018-10-30 19:50 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16965] Change doc target for debbie to be "html-chunked-web"
+ for google analytics fragment
+2018-10-30 19:47 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16964] Update HTML document styling to new "standard"
+2018-10-29 04:10 Darafei Praliaskouski <me at komzpa.net>
+ * [r16957] Fix typo in r16956
+ Closes #4217
+2018-10-29 03:22 Darafei Praliaskouski <me at komzpa.net>
+ * [r16956] ST_Subdivide: don't crash if on some iteration you need
+ to subdivide Empty
+ Closes #4217
+2018-10-24 14:03 Darafei Praliaskouski <me at komzpa.net>
+ * [r16947] [raster] Use GDALFPolygonize unconditionally
+ GDAL 1.10 is already required and 1.9 contains it, so no check
+ needed.
+ Closes #4215
+2018-10-23 13:00 Darafei Praliaskouski <me at komzpa.net>
+ * [r16941] [raster] Fix envelope Contains shortcut in ST_Clip
+ Patch by Sai-bot
+ Closes #3457
+2018-10-22 15:26 Darafei Praliaskouski <me at komzpa.net>
+ * [r16938] ST_Subdivide: support rect hole in rect shell
+ Closes #4211
+ Closes https://github.com/postgis/postgis/pull/317
+2018-10-17 14:25 Sandro Santilli <strk at kbt.io>
+ * [r16918] Fix support for PostgreSQL-12 ("getrelid" macro removed)
+ The call is replaced with its expansion which should work
+ as back as PostgreSQL-9.1 which is before the oldest version
+ PostGIS-2.2 (our oldest maintained branch) supports.
+ This is then safe to backport to all branches till 2.2.
+ Patch by Laurenz Albe
+ References #4306 in 2.5 branch
+2018-10-15 11:46 Sandro Santilli <strk at kbt.io>
+ * [r16910] Only drop function IF EXISTS ...
+2018-10-15 10:38 Sandro Santilli <strk at kbt.io>
+ * [r16901] [topology] properly drop removed internal functions on
+ upgrade
+ References #4202 in 2.5 branch
+2018-10-08 23:19 Regina Obe <lr at pcorp.us>
+ * [r16879] Fix packaging, was copying over old extension files
+2018-10-03 11:11 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16877] St_AsMVTGeom: Handle type changes in geometry
+ collections
+ References #4181
+2018-10-02 11:41 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16870] Fix undefined behaviour in ptarray_clone_deep
+ References #4191
+2018-10-02 09:37 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16862] Fix undefined behaviour in SADFWrite
+ Also addresses several gcc warnings
+ References #4189
+2018-10-02 07:23 Regina Obe <lr at pcorp.us>
+ * [r16861] Fix packaging link - broke it on last change
+2018-10-01 15:55 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16859] Avoid division by zero in kmeans
+ References #4188
+2018-10-01 13:31 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16857] St_AsMVTGeom: Drop invalid geometries after
+ simplification
+ References #4183
+2018-10-01 06:05 Regina Obe <lr at pcorp.us>
+ * [r16853] fix windows links should point at postgis.net and not
+ postgis.org
+2018-09-26 12:18 Regina Obe <lr at pcorp.us>
+ * [r16843] fix packaging so doesn't include old extension files
+2018-09-24 01:07 Regina Obe <lr at pcorp.us>
+ * [r16837] flip to 2.5.1dev
+2018-09-23 20:04 Regina Obe <lr at pcorp.us>
+ * [r16835] Stamp date of release.
+ Put in legacy stub function for RASTER_to_binary to allow pg
+ upgrade (newer lib)
+ Closes #4097
+2018-09-23 15:03 Regina Obe <lr at pcorp.us>
+ * [r16834] update changelog in prep for PostGIS 2.5.0 release
2018-09-23 01:07 Regina Obe <lr at pcorp.us>
* [r16833] Prep for 2.5.0 release
