[postgis-tickets] [PostGIS] #4243: Use of deprecated function in UpdateGeometrySRID
PostGIS trac at osgeo.org
Sun Nov 18 15:57:16 PST 2018
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17030" 17030]:
 #!CommitTicketReference repository="" revision="17030"
 Put back deprecated functions removed in r17029, but patch them to use
 newer pg_get_constraintdef function.
 Also mark them as undeprecated cause they are used in other management
 functions, and it's too messy to change those to use teh raw sql.
 We maybe stuck with these forever :(
 Closes #4243 for PostGIS 3.0
 Also fix error in raster patching
 References #4231 for PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4243#comment:3>
