[postgis-tickets] [PostGIS] #4231: PostGIS can't build with PostgreSQL v12devel because "pg_constraint.consrc" has been removed
trac at osgeo.org
Thu Nov 22 13:10:51 PST 2018
has been removed
Reporter: Laurenz Albe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.5.x
Resolution: fixed | Keywords:
Comment (by robe):
In [changeset:"17060" 17060]:
#!CommitTicketReference repository="" revision="17060"
Add 2.2.8 to upgrade targets
Remove using of pg_constraint.consrc to allow support of 12 as noted by
Laurenz Albe (pg_constraint.consrc was removed in 12devel)
Closes #4231 for postgis 2.5.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4231#comment:10>
