[postgis-tickets] [PostGIS] #4251: topology failing on PostgreSQL 12devel
trac at osgeo.org
Fri Nov 23 06:29:31 PST 2018
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.5.2
Component: topology | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
2.5 is even more of a mess for topology for 12 on my machine and I got
more failures. I just pulled the latest git master of postgresql
PostgreSQL 12devel on x86_64-w64-mingw32, compiled by gcc.exe (x86_64
-posix-seh-
rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
Postgis 2.5.2dev - r17061 - 2018-11-23 08:10:04
scripts 2.5.2dev r17061
raster scripts 2.5.2dev r17061
GEOS: 3.7.0-CAPI-1.11.0 673b9939
PROJ: Rel. 5.2.0, September 15th, 2018
GDAL: GDAL 2.3.1, released 2018/06/22
Running tests
regress/legacy_validate .. ok
regress/legacy_predicate .. failed (diff expected obtained:
/projects/postgis/t
mp/2.5_pg12w64/test_2_diff)
regress/legacy_invalid .. ok
regress/sqlmm .. ok
regress/legacy_query .. failed (diff expected obtained:
/projects/postgis/tmp/2
.5_pg12w64/test_5_diff)
regress/addnode .. ok
regress/addedge .. ok
regress/addface .. ok
regress/addface2.5d .. ok
regress/addtopogeometrycolumn .. ok
regress/polygonize .. ok
regress/st_addisoedge .. ok
regress/st_addisonode .. ok
regress/st_addedgemodface .. ok
regress/st_addedgenewfaces .. ok
regress/st_changeedgegeom .. ok
regress/st_createtopogeo .. ok
regress/st_getfacegeometry .. ok
regress/st_getfaceedges .. ok
regress/st_modedgeheal .. ok
regress/st_modedgesplit .. ok
regress/st_newedgeheal .. ok
regress/st_newedgessplit .. ok
regress/st_remedgenewface .. failed (diff expected obtained:
/projects/postgis/
tmp/2.5_pg12w64/test_24_diff)
regress/st_remedgemodface .. failed (diff expected obtained:
/projects/postgis/
tmp/2.5_pg12w64/test_25_diff)
regress/st_simplify .. ok
regress/topoelement .. ok
regress/topoelementarray_agg .. ok
regress/topogeo_addlinestring .. ok
regress/topogeo_addpoint .. ok
regress/topogeo_addpolygon .. ok
regress/topogeom_edit .. ok
regress/topogeometry_type .. failed (diff expected obtained:
/projects/postgis/
tmp/2.5_pg12w64/test_33_diff)
regress/topojson .. failed (diff expected obtained:
/projects/postgis/tmp/2.5_p
g12w64/test_34_diff)
regress/topologysummary .. ok
regress/topo2.5d .. ok
regress/totopogeom .. ok
regress/droptopology .. ok
regress/droptopogeometrycolumn .. ok
regress/copytopology .. failed (diff expected obtained:
.5_pg12w64/test_40_diff)
regress/createtopogeom .. ok
regress/createtopology .. ok
regress/gml .. failed (diff expected obtained:
/projects/postgis/tmp/2.5_pg12w6
4/test_43_diff)
regress/getnodebypoint .. ok
regress/getedgebypoint .. ok
regress/getfacebypoint .. ok
regress/getringedges .. ok
regress/gettopogeomelements .. failed (diff expected obtained:
/projects/postgi
s/tmp/2.5_pg12w64/test_48_diff)
regress/layertrigger .. ok
regress/validatetopology .. ok
uninstall .. ok (4643)
Run tests: 51
Failed: 9
Or perhaps I glossed over tehm in debbie, cause the first couple diffs I
look at have the same oids error.
As I recall I think I saw a headling saying "oids no more", so perhaps
they removed oid columns from pg12
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4251#comment:2>
