[postgis-tickets] r17064 - Preparing for 2.3.8 release
Regina Obe
lr at pcorp.us
Fri Nov 23 09:02:48 PST 2018
Author: robe
Date: 2018-11-23 21:02:47 -0800 (Fri, 23 Nov 2018)
New Revision: 17064
branches/2.3/ChangeLog
branches/2.3/NEWS
branches/2.3/README.postgis
branches/2.3/Version.config
branches/2.3/doc/release_notes.xml
branches/2.3/extensions/upgradeable_versions.mk
Modified: branches/2.3/ChangeLog
--- branches/2.3/ChangeLog 2018-11-23 17:56:22 UTC (rev 17063)
+++ branches/2.3/ChangeLog 2018-11-24 05:02:47 UTC (rev 17064)
@@ -1,12 +1,189 @@
+2018-11-22 16:14 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17056] Avoid unaligned memory access in BOX2D_out
+ References #4244
+2018-11-22 13:40 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17050] Fix undefined behaviour in ST_3DDistance
+ References #4246
+2018-11-21 14:10 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17040] Fix undefined behaviour in raster intersection
+ References #4249
+2018-11-21 11:43 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17035] Avoid undefined behaviour in next_float functions (Raúl
+ Marín)
+ References #4247
+2018-11-15 09:05 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17016] Allocate enough memory in gidx_to_string
+ References #4236
+2018-11-07 17:17 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16994] Add 4223 news line
+2018-11-07 17:15 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16993] Patch over bad behaviour for near-parallel boxes and
+ distancetree.
+ Unfortunately, this "fix" is probably breakable, just put the
+ boxes closer and closer together until we get "close enough to be
+ the same" results from the edge normal comparison again. Only way
+ around this is to do dot product and comparisons in
+ higher-than-double space
+ References #4223
+2018-10-23 13:07 Darafei Praliaskouski <me at komzpa.net>
+ * [r16943] [raster] Fix envelope Contains shortcut in ST_Clip
+ Patch by Sai-bot
+ Closes #3457
+2018-10-17 14:28 Sandro Santilli <strk at kbt.io>
+ * [r16920] Fix support for PostgreSQL-12 ("getrelid" macro removed)
+ The call is replaced with its expansion which should work
+ as back as PostgreSQL-9.1 which is before the oldest version
+ PostGIS-2.2 (our oldest maintained branch) supports.
+ This is then safe to backport to all branches till 2.2.
+ Patch by Laurenz Albe
+ References #4206 in 2.3 branch
+2018-10-15 11:47 Sandro Santilli <strk at kbt.io>
+ * [r16912] Only drop function IF EXISTS ...
+2018-10-15 11:31 Sandro Santilli <strk at kbt.io>
+ * [r16907] Use portable code to write extension-protection line
+ References #4203 in 2.3 branch
+2018-10-15 10:41 Sandro Santilli <strk at kbt.io>
+ * [r16902] [topology] properly drop removed internal functions on
+ upgrade
+ References #4202 in 2.3 branch
+2018-10-02 11:40 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16868] Fix undefined behaviour in ptarray_clone_deep
+ References #4191
+2018-10-02 09:45 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16865] Fix undefined behaviour in SADFWrite
+ References #4189
+2018-09-14 15:30 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16799] Use qualified names in topology extension install
+ References #4160
+2018-09-13 19:24 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16782] Avoid array overflow in ANALYZE (References #2985)
+2018-06-12 12:56 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16614] Fix flags in case where a boxless geom comes in with a
+ "has box" set of flags.
+ Closes #4707
+2018-05-23 09:27 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16587] Avoid segfault in median test (32bits)
+ References #4095
+2018-05-22 19:37 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r16585] Inconsistent results from qsort callback (yugr)
+ References #4093
+2018-05-21 11:03 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r16580] Fix bug in lwgeom_median and avoid division by zero
+ References #3997
+ Closes https://github.com/postgis/postgis/pull/245
+2018-05-16 21:39 Nicklas Avén <nicklas.aven at jordogskog.no>
+ * [r16574] Fixes bounding box handling in twkb_input #4089
+2018-05-12 20:31 Regina Obe <lr at pcorp.us>
+ * [r16571] comment out sfcgal tests for now until we resolve
+ cgal/sfcgal dependency issue on debian (hopefully got syntax
+ right this time)
+ References #4068
+2018-05-09 07:30 Regina Obe <lr at pcorp.us>
+ * [r16568] comment out sfcgal tests for now until we resolve
+ References #4068
+2018-04-24 09:28 Regina Obe <lr at pcorp.us>
+ * [r16551] Disable interrupt tests by default, now requires
+ --with-interrupt-tests to turn on.
+ This is to quiet false alarms which often happen on a busy box
+ Closes #4074
+2018-04-21 13:17 Darafei Praliaskouski <me at komzpa.net>
+ * [r16549] ST_ClusterKMeans crash on NULL and EMPTY
+ Closes #4071
+2018-04-06 04:58 Regina Obe <lr at pcorp.us>
+ * [r16525] Flip version to 2.3.8dev
+2018-04-02 07:04 Regina Obe <lr at pcorp.us>
+ * [r16521] Fix winnie's packaging versions for GEOS and GDAL
+2018-04-02 03:58 Regina Obe <lr at pcorp.us>
+ * [r16516] Update postgis_release_docs recipe for 2.2 (to be same
+ as 2.4, so debbie can build)
+2018-04-02 03:01 Regina Obe <lr at pcorp.us>
+ * [r16512] Update to 2.3.7 and get everything ready in prep for
+ official tagging on Friday (2018-04-06)
2018-03-28 09:02 Regina Obe <lr at pcorp.us>
- * [r16505] NEWS, doc/reference_raster.xml,
- raster/rt_pg/rtpg_mapalgebra.c, raster/test/regress/tickets.sql,
- raster/test/regress/tickets_expected: Fix crasher in raster when
- fed an empty raster (note was tempted to change the def of empty
- raster to include raster with no bands but not sure where else
- that is used, so just revised the clip check to not try to clip
- if no bands).
+ * [r16505] Fix crasher in raster when fed an empty raster (note was
+ tempted to change the def of empty raster to include raster with
+ no bands but not sure where else that is used, so just revised
+ the clip check to not try to clip if no bands).
References #3055 for PostGIS 2.3.7,
also minor doc fix references #2925 for PostGIS 2.3.7
reorder NEWS tickets numerically
@@ -13,64 +190,55 @@
2018-03-27 17:38 Darafei Praliaskouski <me at komzpa.net>
- * [r16501] NEWS, liblwgeom/lwlinearreferencing.c: ST_CPAWithin
- precision fix
+ * [r16501] ST_CPAWithin precision fix
Closes #4032
2018-03-24 00:01 Daniel Baston <dbaston at gmail.com>
- * [r16492] liblwgeom/lwgeom_geos_cluster.c, regress/tickets.sql,
- regress/tickets_expected: Avoid dropping SRID in
- ST_ClusterIntersecting
+ * [r16492] Avoid dropping SRID in ST_ClusterIntersecting
References #4055
2018-03-22 15:45 Regina Obe <lr at pcorp.us>
- * [r16481] NEWS, postgis/geography.sql.in: schema qualify geography
- functions (including ST_Buffer)
+ * [r16481] schema qualify geography functions (including ST_Buffer)
References #4052 for PostGIS 2.3.7
2018-02-26 20:14 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16427] liblwgeom/lwin_wkt_lex.c: Add generated lexer (for 2.3)
+ * [r16427] Add generated lexer (for 2.3)
- * [r16426] NEWS, liblwgeom/lwin_wkt_lex.l: Fix memory corruption in
- case where lexer is interrupted mid-process
+ * [r16426] Fix memory corruption in case where lexer is interrupted
+ mid-process
References #4017
For 2.3
2018-02-26 18:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16421] NEWS, liblwgeom/lwlinearreferencing.c: Use more precise
- bounds when testing overlap of temporal ranges.
+ * [r16421] Use more precise bounds when testing overlap of temporal
+ ranges.
For 2.3, references #4025
2018-02-23 19:54 Regina Obe <lr at pcorp.us>
- * [r16414] authors.git, authors.svn: Add Raúl Marín Rodríguez to
- svn and git authors lists
+ * [r16414] Add Raúl Marín Rodríguez to svn and git authors lists
2018-02-22 22:22 Regina Obe <lr at pcorp.us>
- * [r16411] ci/winnie/build_postgis.sh,
- ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh:
- Backport ci changes to 2.3
+ * [r16411] Backport ci changes to 2.3
2018-02-22 13:42 Sandro Santilli <strk at kbt.io>
- * [r16408] .gitlab-ci.yml: [gitlab-ci] Switch to PostgreSQL 9.6 and
- libjson-c-dev
+ * [r16408] [gitlab-ci] Switch to PostgreSQL 9.6 and libjson-c-dev
Fixes gitlab-ci build for 2.3, references #4023
2018-02-22 11:16 Darafei Praliaskouski <me at komzpa.net>
- * [r16407] NEWS, postgis/lwgeom_box3d.c, regress/regress_expected,
- regress/sfcgal/regress_expected: Fix cast from box3d to geometry
+ * [r16407] Fix cast from box3d to geometry
Patch by Matthias Bay
@@ -79,14 +247,13 @@
2018-01-26 14:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16363] NEWS, liblwgeom/lwpoly.c: lwpoly_construct_circle: Avoid
- division by zero (Raúl Marín Rodríguez)
+ * [r16363] lwpoly_construct_circle: Avoid division by zero (Raúl
+ Marín Rodríguez)
References #4003
2018-01-22 14:13 Sandro Santilli <strk at kbt.io>
- * [r16357] NEWS, postgis/geography.sql.in: Set availability of
- support function for KNN index
+ * [r16357] Set availability of support function for KNN index
Fixes upgrade from 2.1 to 2.2+
References #3978 in 2.3 branch (2.3.7)
@@ -93,8 +260,8 @@
2018-01-22 12:37 Sandro Santilli <strk at kbt.io>
- * [r16354] .drone.yml: [drone] Use trisquel2 image, test all pgsql
- versions and upgrades
+ * [r16354] [drone] Use trisquel2 image, test all pgsql versions and
+ upgrades
The new docker image also uses newer GEOS (3.6.2).
References #3813 for 2.3 branch
@@ -102,40 +269,32 @@
2018-01-22 11:31 Sandro Santilli <strk at kbt.io>
- * [r16351] regress/run_test.pl: Backport run_test.pl fixes from
- trunk
+ * [r16351] Backport run_test.pl fixes from trunk
2018-01-16 06:33 Regina Obe <lr at pcorp.us>
- * [r16314] Version.config, ci/debbie/postgis_make_dist.sh,
- ci/debbie/postgis_release_docs.sh,
- extensions/upgradeable_versions.mk: flip version to 2.3.7dev, add
- in 2.3.6 to upgrade path
+ * [r16314] flip version to 2.3.7dev, add in 2.3.6 to upgrade path
backport changes to stamp timestamp
References #3991 for PostGIS 2.3.7dev
2018-01-15 21:01 Regina Obe <lr at pcorp.us>
- * [r16303] ci/debbie/postgis_release_docs.sh: Get rid of sed
- fiddling with SVN revision
+ * [r16303] Get rid of sed fiddling with SVN revision
2018-01-15 20:58 Regina Obe <lr at pcorp.us>
- * [r16302] HOWTO_RELEASE, Version.config: more clearifying notes on
- HOWTO_RELEASE
+ * [r16302] more clearifying notes on HOWTO_RELEASE
change version to 2.3.6 in prep for tagging tomorrow or
Wednesday.
2018-01-15 02:19 Regina Obe <lr at pcorp.us>
- * [r16300] ChangeLog, HOWTO_RELEASE,
- ci/debbie/postgis_make_dist.sh: update change log, echo branch
- reference, minor correction to HOWTO_RELEASE
+ * [r16300] update change log, echo branch reference, minor
+ correction to HOWTO_RELEASE
2018-01-14 16:05 Regina Obe <lr at pcorp.us>
- * [r16295] HOWTO_RELEASE, Version.config, doc/release_notes.xml,
- extensions/upgradeable_versions.mk: minor edits to HOWTO_RELEASE
+ * [r16295] minor edits to HOWTO_RELEASE
Add 2.3.5, 2.3.6dev to upgradeable_versions.mk
Update release_notes.xml to reflect impending release
Flip version to 2.3.6rc1 (in prep for rc1 tagging)
@@ -142,9 +301,8 @@
2018-01-14 15:34 Regina Obe <lr at pcorp.us>
- * [r16291] HOWTO_RELEASE, NEWS, ci/debbie/postgis_make_dist.sh,
- ci/debbie/postgis_release_docs.sh, make_dist.sh: Backport changes
- to standardize debbie's packaging and ensure
+ * [r16291] Backport changes to standardize debbie's packaging and
+ ensure
she builds tagged versions as well without manual intervention
Update HOWTO_RELEASE to reflect change
References #3985 for PostGIS 2.3
@@ -151,15 +309,12 @@
2018-01-12 13:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16272] NEWS, libpgcommon/lwgeom_pg.h,
- libpgcommon/lwgeom_transform.c, libpgcommon/lwgeom_transform.h:
- 2.3 fix, st_transform does not qualify query to spatial_ref_sys
- (references #3975)
+ * [r16272] 2.3 fix, st_transform does not qualify query to
+ spatial_ref_sys (references #3975)
2018-01-12 09:38 Sandro Santilli <strk at kbt.io>
- * [r16267] NEWS, postgis/postgis.sql.in, postgis/sqldefines.h.in:
- Add check for PostgreSQL version compatibility in
+ * [r16267] Add check for PostgreSQL version compatibility in
postgis_full_version
Adds _postgis_scripts_pgsql_version() and
@@ -174,8 +329,7 @@
2018-01-12 08:55 Darafei Praliaskouski <me at komzpa.net>
- * [r16265] NEWS, liblwgeom/cunit/cu_out_encoded_polyline.c,
- liblwgeom/lwout_encoded_polyline.c: Encoded Polyline of EMPTY
+ * [r16265] Encoded Polyline of EMPTY
Pull in from trunk
Closes #3982
@@ -182,35 +336,34 @@
2018-01-09 20:52 Sandro Santilli <strk at kbt.io>
- * [r16246] .drone.yml: Use template1 for connecting
+ * [r16246] Use template1 for connecting
2018-01-09 20:29 Sandro Santilli <strk at kbt.io>
- * [r16245] .drone.yml: Wait for database to be up before proceeding
+ * [r16245] Wait for database to be up before proceeding
2018-01-09 18:41 Sandro Santilli <strk at kbt.io>
- * [r16244] NEWS, postgis/geography_brin.sql.in,
- postgis/postgis_brin.sql.in: Simplify syntax for brin opclasses
- so upgrade script recognizes it
+ * [r16244] Simplify syntax for brin opclasses so upgrade script
+ recognizes it
Fixes #3956 in 2.3 branch
- * [r16243] utils/postgis_proc_upgrade.pl: Do not assume CREATE
- OPERATOR CLASS needs to end with ');'
+ * [r16243] Do not assume CREATE OPERATOR CLASS needs to end with
A single ending semicolon is enough to terminate the statement
2018-01-09 18:40 Sandro Santilli <strk at kbt.io>
- * [r16242] regress/run_test.pl: Upgrade SFCGAL too when requested
+ * [r16242] Upgrade SFCGAL too when requested
2018-01-02 14:09 Darafei Praliaskouski <me at komzpa.net>
- * [r16214] NEWS, liblwgeom/lwkmeans.c: Fix KMeans initialization
- issue that lost clusters sometimes.
+ * [r16214] Fix KMeans initialization issue that lost clusters
+ sometimes.
Closes #3965
Closes https://github.com/postgis/postgis/pull/179
@@ -217,68 +370,56 @@
2018-01-02 13:45 Darafei Praliaskouski <me at komzpa.net>
- * [r16210] authors.git, authors.svn: Drag in authors mapping from
- trunk.
+ * [r16210] Drag in authors mapping from trunk.
2017-12-12 18:10 Regina Obe <lr at pcorp.us>
- * [r16147] ci/bessie/postgis_regress.sh,
- ci/bessie32/postgis_regress.sh: add in verbose and logic to drop
- test database if it exists. Switch to using BRANCH instead of TAG
+ * [r16147] add in verbose and logic to drop test database if it
+ exists. Switch to using BRANCH instead of TAG
2017-12-10 01:55 Regina Obe <lr at pcorp.us>
- * [r16140] doc/html/images/osgeo_logo.png: use new osgeo project
- logo
+ * [r16140] use new osgeo project logo
2017-11-30 21:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16132] NEWS, liblwgeom/cunit/cu_out_encoded_polyline.c,
- liblwgeom/lwout_encoded_polyline.c, postgis/lwgeom_export.c:
- Support google line encodings that include a backslash character
- (References #3713)
+ * [r16132] Support google line encodings that include a backslash
+ character (References #3713)
2017-11-29 02:37 Regina Obe <lr at pcorp.us>
- * [r16125] ci/bessie/postgis_regress.sh: Add to bessie step to
- install and test extension install
+ * [r16125] Add to bessie step to install and test extension install
2017-11-29 01:12 Regina Obe <lr at pcorp.us>
- * [r16124] ci/bessie, ci/bessie/postgis_regress.sh, ci/bessie32,
- ci/bessie32/postgis_regress.sh,
- extensions/postgis_sfcgal/Makefile.in: Explicitly specify $(PERL)
- to call create_unpackaged.pl otherwise at least on freebsd it
- fails (and backport other minor changes like remove of 9.1 which
- support was dropped in 2.2)
+ * [r16124] Explicitly specify $(PERL) to call create_unpackaged.pl
+ otherwise at least on freebsd it fails (and backport other minor
+ changes like remove of 9.1 which support was dropped in 2.2)
Closes #3938 for PostGIS 2.3.6
Also add the Bessie sisters to battery testing
2017-11-15 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16111] NEWS, Version.config: Push versions for next release
+ * [r16111] Push versions for next release
2017-11-15 17:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16109] ChangeLog, NEWS, README.postgis, Version.config,
- doc/release_notes.xml: Prepare for release
+ * [r16109] Prepare for release
2017-11-09 09:01 Regina Obe <lr at pcorp.us>
- * [r16101] NEWS, extensions/upgradeable_versions.mk: Add missing
- 2.2.6 upgrade path
+ * [r16101] Add missing 2.2.6 upgrade path
References #3926 for PostGIS 2.3.5
2017-11-09 08:55 Regina Obe <lr at pcorp.us>
- * [r16100] NEWS: Add missing release notes for ST_Segmentize
- geography fix.
+ * [r16100] Add missing release notes for ST_Segmentize geography
+ fix.
References #3667 for PostGIS 2.3.5
2017-11-07 18:31 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16095] liblwgeom/cunit/cu_geodetic.c, liblwgeom/lwgeodetic.c,
- regress/geography_expected: Replace project-and-entend logic with
+ * [r16095] Replace project-and-entend logic with
bisect-and-recurse in geography segmentization.
Preserves "mostly equal" segment lengths, and
should be more numerically stable.
@@ -287,8 +428,8 @@
2017-10-31 15:33 Sandro Santilli <strk at kbt.io>
- * [r16087] configure.ac, liblwgeom/Makefile.in: Make sure target
- directories are created before copying files to them
+ * [r16087] Make sure target directories are created before copying
+ files to them
References #3912 for 2.3 branch
References #3916 for 2.3 branch
@@ -295,10 +436,7 @@
2017-10-21 09:04 Sandro Santilli <strk at kbt.io>
- * [r16030] .gitignore, GNUmakefile.in, configure.ac,
- liblwgeom/Makefile.in, loader/Makefile.in, raster/install-sh,
- raster/loader/Makefile.in, utils/Makefile.in: Put build AUX files
- under build-aux
+ * [r16030] Put build AUX files under build-aux
Cleans and ignore build aux files from new location,
and remove spurious install-sh from repository.
@@ -307,26 +445,21 @@
2017-10-18 18:19 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16010] HOWTO_RELEASE, NEWS, Version.config,
- extensions/upgradeable_versions.mk: Push versions to dev
+ * [r16010] Push versions to dev
2017-10-18 18:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16008] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
- Version.config, doc/release_notes.xml,
- extensions/upgradeable_versions.mk: Prepare for 2.3.4 release
+ * [r16008] Prepare for 2.3.4 release
2017-10-17 16:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15998] NEWS, liblwgeom/cunit/cu_geodetic.c, liblwgeom/g_box.c:
- Allocate enough space for all possible GBOX string outputs (Raúl
- Marín Rodríguez)
+ * [r15998] Allocate enough space for all possible GBOX string
+ outputs (Raúl Marín Rodríguez)
Closes #3907
2017-10-10 22:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15959] NEWS, liblwgeom/lwin_wkb.c: Throw error on malformed WKB
- input (2.3 branch)
+ * [r15959] Throw error on malformed WKB input (2.3 branch)
Credit to OSS-Fuzz:
https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2589
Credit to OSS-Fuzz:
@@ -339,158 +472,136 @@
2017-10-10 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15954] NEWS, liblwgeom/lwout_encoded_polyline.c: Undefined
- behaviour in pointarray_to_encoded_polyline (2.3 branch)
+ * [r15954] Undefined behaviour in pointarray_to_encoded_polyline
+ (2.3 branch)
(References #3891)
2017-10-10 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15949] NEWS, liblwgeom/cunit/cu_varint.c, liblwgeom/varint.c,
- liblwgeom/varint.h: Fix undefined behaviour in zigzag with
- negative inputs (2.4 branch)
+ * [r15949] Fix undefined behaviour in zigzag with negative inputs
+ (2.4 branch)
(References #3882)
2017-10-10 16:37 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15946] NEWS, liblwgeom/cunit/cu_measures.c,
- liblwgeom/measures.c: lw_dist2d_pt_arc division by zero
- (References #3874)
+ * [r15946] lw_dist2d_pt_arc division by zero (References #3874)
2017-10-06 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15920] NEWS, liblwgeom/lwalgorithm.c: geohash_point_as_int: Fix
- undefined behaviour in shift operation
+ * [r15920] geohash_point_as_int: Fix undefined behaviour in shift
+ operation
References #3875
2017-10-06 13:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15916] NEWS, liblwgeom/cunit/cu_libgeom.c,
- liblwgeom/liblwgeom.h.in: Undefined behaviour in TYPMOD_GET_SRID
+ * [r15916] Undefined behaviour in TYPMOD_GET_SRID
References #3880
2017-10-05 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15901] NEWS, liblwgeom/cunit/cu_geodetic.c,
- liblwgeom/cunit/cu_libgeom.c, liblwgeom/liblwgeom_internal.h,
- liblwgeom/lwalgorithm.c, liblwgeom/lwgeodetic.c,
- liblwgeom/lwgeodetic.h, liblwgeom/lwspheroid.c: Combine multiple
- signum definitions (2.3)
+ * [r15901] Combine multiple signum definitions (2.3)
(References #3878)
2017-10-05 13:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15898] NEWS, liblwgeom/cunit/cu_measures.c,
- liblwgeom/measures.c: division by zero in lw_dist2d_arc_arc
+ * [r15898] division by zero in lw_dist2d_arc_arc
References #3879
2017-10-02 12:50 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15871] NEWS, liblwgeom/lwlinearreferencing.c: Gracefully handle
- short-measure issue (Closes #3845)
+ * [r15871] Gracefully handle short-measure issue (Closes #3845)
2017-10-02 06:20 Sandro Santilli <strk at kbt.io>
- * [r15867] NEWS, liblwgeom/Makefile.in: Add -lm to liblwgeom link
- line
+ * [r15867] Add -lm to liblwgeom link line
References #3869 for 2.3 branch
2017-09-30 17:46 Sandro Santilli <strk at kbt.io>
- * [r15861] .drone.yml: Fix yaml syntax in drone config
+ * [r15861] Fix yaml syntax in drone config
2017-09-26 19:48 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15838] NEWS: TWKB news item (References #3866)
+ * [r15838] TWKB news item (References #3866)
2017-09-26 19:10 Nicklas Avén <nicklas.aven at jordogskog.no>
- * [r15837] liblwgeom/bytebuffer.c: increase possible size of varint
+ * [r15837] increase possible size of varint
2017-09-26 17:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15835] NEWS, liblwgeom/lwin_wkb.c, liblwgeom/lwin_wkt.c:
- Triangles un-closed in M should be WKT parseable (Closes #3818)
+ * [r15835] Triangles un-closed in M should be WKT parseable (Closes
+ #3818)
2017-09-25 13:39 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15815] NEWS, liblwgeom/lwstroke.c: Not-quite curved
- CurvePolygon rejected by ST_Contains (Closes #3781)
+ * [r15815] Not-quite curved CurvePolygon rejected by ST_Contains
+ (Closes #3781)
2017-09-20 00:19 Regina Obe <lr at pcorp.us>
- * [r15776] NEWS, postgis/postgis.sql.in: ST_ConcaveHull fix for
- ExteriorRing is not a polygon
+ * [r15776] ST_ConcaveHull fix for ExteriorRing is not a polygon
References #2836 for PostGIS 2.3.4
2017-09-18 21:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15762] NEWS: News item (references #3731)
+ * [r15762] News item (references #3731)
2017-09-18 14:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15761] NEWS: Added NEWS entry (references #3774)
+ * [r15761] Added NEWS entry (references #3774)
2017-09-18 13:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15756] liblwgeom/lwcompound.c: Trig length calculation for
- compoundcurve in 2.3 branch (references #3774)
+ * [r15756] Trig length calculation for compoundcurve in 2.3 branch
+ (references #3774)
2017-09-14 22:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15740] postgis/gserialized_estimate.c: #3731, backend crash on
- zero size stats histogram
+ * [r15740] #3731, backend crash on zero size stats histogram
2017-09-14 14:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15724] extensions/address_standardizer/gamma.c,
- loader/dbfopen.c, loader/pgsql2shp-core.c,
- loader/shp2pgsql-core.c, raster/loader/raster2pgsql.c: #3847,
- coverity fixes for 2.3
+ * [r15724] #3847, coverity fixes for 2.3
2017-09-13 20:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15718] doc/extras_topology.xml: Fix misplaced section end
+ * [r15718] Fix misplaced section end
2017-09-13 20:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15714] doc/extras_topology.xml: #3249, #2352, document
- ST_RemoveIsoEdge
+ * [r15714] #3249, #2352, document ST_RemoveIsoEdge
2017-09-13 13:14 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15709] topology/postgis_topology.c: Light PgSQL 11 support so I
- can compile and test bug fixes
+ * [r15709] Light PgSQL 11 support so I can compile and test bug
+ fixes
2017-09-11 16:38 Sandro Santilli <strk at kbt.io>
- * [r15686] .drone.yml: [drone] Extract upgrade target version
- dynamically
+ * [r15686] [drone] Extract upgrade target version dynamically
2017-09-11 15:50 Regina Obe <lr at pcorp.us>
- * [r15683] NEWS, loader/shp2pgsql-core.c: initialize
- state->num_fields and state->pgfieldtypes so doesn't cause
- intermittent crashes on windows
+ * [r15683] initialize state->num_fields and state->pgfieldtypes so
+ doesn't cause intermittent crashes on windows
Closes #3839 for PostGIS 2.3.4
2017-09-11 15:16 Regina Obe <lr at pcorp.us>
- * [r15682] loader/Makefile.in: always enable loader cunit tests
+ * [r15682] always enable loader cunit tests
References #3839
2017-09-07 05:51 Regina Obe <lr at pcorp.us>
- * [r15645] extras/tiger_geocoder/geocode/reverse_geocode.sql: fix
- field typo in reverse_geocoder
+ * [r15645] fix field typo in reverse_geocoder
Closes #3833 for PostGIS 2.3.4
2017-09-05 21:25 Sandro Santilli <strk at kbt.io>
- * [r15635] configure.ac, libpgcommon/gserialized_gist.c,
- postgis/gserialized_estimate.c, postgis/gserialized_gist_nd.c:
- Revert "Rework PGSQL_VERSION again so to use 2-digits minor from
- 10 onward"
+ * [r15635] Revert "Rework PGSQL_VERSION again so to use 2-digits
+ minor from 10 onward"
This reverts commit r15631
@@ -501,50 +612,37 @@
2017-09-05 20:50 Sandro Santilli <strk at kbt.io>
- * [r15632] NEWS: Add item about PostgreSQL 10 support
+ * [r15632] Add item about PostgreSQL 10 support
- * [r15631] configure.ac, libpgcommon/gserialized_gist.c,
- Rework PGSQL_VERSION again so to use 2-digits minor from 10
- onward
+ * [r15631] Rework PGSQL_VERSION again so to use 2-digits minor from
+ 10 onward
See #3614 (for 2.3 branch)
2017-09-05 20:37 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15630] configure.ac, libpgcommon/gserialized_gist.c,
- postgis/gserialized_estimate.c, postgis/gserialized_gist_nd.c,
- raster/rt_pg/rtpostgis.sql.in, raster/test/regress/rt_union.sql,
- raster/test/regress/rt_union_expected,
- regress/regress_selectivity.sql,
- topology/sql/topogeometry/totopogeom.sql.in,
- topology/test/regress/copytopology.sql,
- topology/test/regress/copytopology_expected: Support PgSQL 10 on
- PostGIS 2.3
+ * [r15630] Support PgSQL 10 on PostGIS 2.3
2017-09-05 16:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15627] liblwgeom/cunit/cu_geos.c, liblwgeom/lwgeom_geos.c:
- #3829 Segfault in LWGEOM2GEOS
+ * [r15627] #3829 Segfault in LWGEOM2GEOS
2017-09-04 00:06 Daniel Baston <dbaston at gmail.com>
- * [r15618] doc/reference_measure.xml: #3499, Clarify distance units
- in docs for ST_ClusterWithin
+ * [r15618] #3499, Clarify distance units in docs for
+ ST_ClusterWithin
2017-09-01 14:00 Regina Obe <lr at pcorp.us>
- * [r15612] doc/reference_processing.xml: Note that ST_Intersection
- drops M
+ * [r15612] Note that ST_Intersection drops M
Closes #3826 for PostGIS 2.3.4
2017-08-24 18:05 Regina Obe <lr at pcorp.us>
- * [r15585] NEWS, doc/installation.xml,
- extras/tiger_geocoder/tiger_loader_2016.sql: fix issues with
- loading tabblock, incorporate changes from Jeffrey Wescott
+ * [r15585] fix issues with loading tabblock, incorporate changes
+ from Jeffrey Wescott
change url to new census ssl one
update docs to describe how to load bg, tract, tabblock tables
Closes #3698 for PostGIS 2.3.4
@@ -552,28 +650,23 @@
2017-08-24 03:00 Regina Obe <lr at pcorp.us>
- * [r15579] extras/tiger_geocoder/census_loader.sql: delete no
- longer used
+ * [r15579] delete no longer used
2017-08-20 06:31 Regina Obe <lr at pcorp.us>
- * [r15557] doc/reference_measure.xml: Add reference to
- ST_HausdorffDistance to ST_Distance function.
+ * [r15557] Add reference to ST_HausdorffDistance to ST_Distance
+ function.
per Gary Turner
https://lists.osgeo.org/pipermail/postgis-users/2017-August/042322.html
2017-08-18 04:02 Regina Obe <lr at pcorp.us>
- * [r15554] NEWS, extras/tiger_geocoder/geocode/reverse_geocode.sql,
- extras/tiger_geocoder/regress/reverse_geocode_regress,
- extras/tiger_geocoder/regress/reverse_geocode_regress.sql:
- Reverse geocoder missing street suffix direction.
+ * [r15554] Reverse geocoder missing street suffix direction.
Closes #3806 for PostGIS 2.3.4
2017-08-10 09:36 Regina Obe <lr at pcorp.us>
- * [r15547] .travis.yml: Fix travis build by changing permissions of
- home folder
+ * [r15547] Fix travis build by changing permissions of home folder
upgrade to test on 9.5
References #3803 for PostGIS 2.3.4
Closes https://github.com/postgis/postgis/pull/134
@@ -580,149 +673,134 @@
2017-08-08 23:48 Regina Obe <lr at pcorp.us>
- * [r15546] doc/reference_raster.xml: doc Patch from Even Rouault
+ * [r15546] doc Patch from Even Rouault
Closes #3804 for PostGIS 2.3.4
2017-08-08 15:36 Sandro Santilli <strk at kbt.io>
- * [r15543] .editorconfig: Request crlf for .bat files
+ * [r15543] Request crlf for .bat files
2017-08-05 11:16 Regina Obe <lr at pcorp.us>
- * [r15524] doc/reference_editor.xml: Clarify description of ST_Snap
- that it is the newly snapped input geometry and will return input
- geometry unchanged if no snapping.
+ * [r15524] Clarify description of ST_Snap that it is the newly
+ snapped input geometry and will return input geometry unchanged
+ if no snapping.
2017-08-04 23:02 Regina Obe <lr at pcorp.us>
- * [r15523] loader/shp2pgsql-core.c: revert last change seems other
- things I borught over from 2.4 where are unrelated to #3800
+ * [r15523] revert last change seems other things I borught over
+ from 2.4 where are unrelated to #3800
2017-08-04 22:49 Regina Obe <lr at pcorp.us>
- * [r15522] NEWS, loader/shp2pgsql-core.c, loader/shp2pgsql-gui.c:
- Fix email addresses and credit stuff. shp2pgsql-gui Add support
- for exporting materialized views, foreign tables, and partitioned
- tables
+ * [r15522] Fix email addresses and credit stuff. shp2pgsql-gui Add
+ support for exporting materialized views, foreign tables, and
+ partitioned tables
Closes #3800 for PostGIS 2.3.4
2017-07-28 04:09 Regina Obe <lr at pcorp.us>
- * [r15514] NEWS, doc/xsl/postgis_aggs_mm.xml.xsl,
- postgis/postgis.sql.in, postgis/sfcgal.sql.in: Mark 3D functions
- and some other missed functions as parallel safe.
+ * [r15514] Mark 3D functions and some other missed functions as
+ parallel safe.
Closes #3792 for PostGIS 2.3.4
2017-07-27 19:27 Regina Obe <lr at pcorp.us>
- * [r15511] NEWS, postgis/gserialized_estimate.c: Solaris build
- issues due to missing isfinite define
+ * [r15511] Solaris build issues due to missing isfinite define
Patch from Julian Schauder
Closes #3795 for PostGIS 2.3.4
2017-07-20 22:34 Regina Obe <lr at pcorp.us>
- * [r15489] NEWS, liblwgeom/ptarray.c: OSS-Fuzz detected issues with
- ptarray
+ * [r15489] OSS-Fuzz detected issues with ptarray
References #3786 for PostGIS 2.3 (for 2.3.4)
2017-07-10 18:00 Sandro Santilli <strk at kbt.io>
- * [r15483] NEWS, loader/pgsql2shp-core.c: Fix buffer overflow and
- use of uninitialized values
+ * [r15483] Fix buffer overflow and use of uninitialized values
Closes #3101 for 2.3 branch
2017-07-09 14:35 Regina Obe <lr at pcorp.us>
- * [r15479] NEWS, liblwgeom/lwin_wkb.c: Memory leak in
- lwline_from_wkb_state
+ * [r15479] Memory leak in lwline_from_wkb_state
Closes #3782 for PostGIS 2.3.4
Patch provided by Even Rouault
2017-07-06 20:41 Regina Obe <lr at pcorp.us>
- * [r15477] ci/winnie/package_postgis.sh: missing copying
- libintl-8.dll needed for the VC++ 32-bit builds for postgis-gui
+ * [r15477] missing copying libintl-8.dll needed for the VC++ 32-bit
+ builds for postgis-gui
2017-07-01 06:49 Regina Obe <lr at pcorp.us>
- * [r15474] Version.config, extensions/upgradeable_versions.mk: bump
- to 2.3.4dev
+ * [r15474] bump to 2.3.4dev
2017-07-01 04:15 Regina Obe <lr at pcorp.us>
- * [r15472] NEWS, README.postgis, Version.config,
- doc/release_notes.xml: update version numbers, NEWS, release
- notes in prep for PostGIS 2.3.3 release
+ * [r15472] update version numbers, NEWS, release notes in prep for
+ PostGIS 2.3.3 release
2017-07-01 03:22 Regina Obe <lr at pcorp.us>
- * [r15470] ChangeLog: update ChangeLog in prep for PostGIS 2.3.3
- release
+ * [r15470] update ChangeLog in prep for PostGIS 2.3.3 release
2017-06-30 20:43 Regina Obe <lr at pcorp.us>
- * [r15469] doc/performance_tips.xml, doc/using_postgis_dataman.xml:
- Bring performance tips section up to newer versions
+ * [r15469] Bring performance tips section up to newer versions
Closes #3746 for PostGIS 2.3 (branch)
2017-06-24 06:18 Regina Obe <lr at pcorp.us>
- * [r15463] .travis.yml: try to fix travis gdal related build error
+ * [r15463] try to fix travis gdal related build error
2017-06-24 05:36 Regina Obe <lr at pcorp.us>
- * [r15460] doc/installation.xml: fix typo
+ * [r15460] fix typo
- * [r15459] doc/installation.xml: Specify highest version of
- PostgreSQL supported.
+ * [r15459] Specify highest version of PostgreSQL supported.
References #3762 for PostGIS 2.3.3
2017-06-24 05:31 Regina Obe <lr at pcorp.us>
- * [r15458] doc/extras_tigergeocoder.xml: change doco for
- Geocode_Intersection to agree with function definition.
+ * [r15458] change doco for Geocode_Intersection to agree with
+ function definition.
Closes #3717 for PostGIS 2.3.3
2017-06-24 04:58 Regina Obe <lr at pcorp.us>
- * [r15457] NEWS, raster/rt_pg/rtpg_mapalgebra.c: Change ST_Clip
- from Error to Notice when ST_Clip can compute no band
+ * [r15457] Change ST_Clip from Error to Notice when ST_Clip can
+ compute no band
Closest #3730 for PostGIS 2.3.3
2017-06-24 04:33 Regina Obe <lr at pcorp.us>
- * [r15454] doc/reference_processing.xml: Update 3D example and put
- a note about function may return the same geometry.
+ * [r15454] Update 3D example and put a note about function may
+ return the same geometry.
References #3702 for PostGIS 2.4 (trunk)
2017-06-24 04:06 Regina Obe <lr at pcorp.us>
- * [r15452] doc/xsl/postgis_gardentest.sql.xsl: Increase LIMIT
- clause on tests so can more readily catch issues like #3704.
+ * [r15452] Increase LIMIT clause on tests so can more readily catch
+ issues like #3704.
2017-06-23 22:57 Sandro Santilli <strk at kbt.io>
- * [r15451] postgis/lwgeom_btree.c, regress/operators.sql,
- regress/operators_expected: Fix lwgeom_cmp return code
+ * [r15451] Fix lwgeom_cmp return code
Closes #3777 once again (for 2.3 branch)
2017-06-23 15:07 Sandro Santilli <strk at kbt.io>
- * [r15449] topology/postgis_topology.c: Fix compiler warnings about
- printf-like formats
+ * [r15449] Fix compiler warnings about printf-like formats
This was already fixed in trunk
2017-06-23 14:58 Sandro Santilli <strk at kbt.io>
- * [r15448] NEWS, postgis/lwgeom_btree.c, regress/operators.sql,
- regress/operators_expected: Fix handling of EMPTY geometries in
- btree operator
+ * [r15448] Fix handling of EMPTY geometries in btree operator
Includes regress test
@@ -730,22 +808,19 @@
2017-06-23 06:15 Regina Obe <lr at pcorp.us>
- * [r15445] NEWS, liblwgeom/lwout_x3d.c, regress/tickets.sql,
- regress/tickets_expected: ST_AsX3D handle empty geometries
+ * [r15445] ST_AsX3D handle empty geometries
Closes #3704 for PostGIS 2.3.3
2017-06-23 05:55 Regina Obe <lr at pcorp.us>
- * [r15443] regress/dumper/realtable-pre.sql: Backport test sql
- script missed in last commit
+ * [r15443] Backport test sql script missed in last commit
References #3682 for 2.3.3
References #3701 for 2.3.3
2017-06-23 05:19 Regina Obe <lr at pcorp.us>
- * [r15442] NEWS, loader/pgsql2shp-core.c, loader/pgsql2shp-core.h,
- regress/dumper/realtable_expected.dbf: Backport fixes for
- pgsql2shp for Boolean field length and quote escaping
+ * [r15442] Backport fixes for pgsql2shp for Boolean field length
+ and quote escaping
Includes tests for both
Closes #3682
Closes #3701
@@ -752,27 +827,17 @@
2017-06-19 20:37 Sandro Santilli <strk at kbt.io>
- * [r15437] postgis/Makefile.in: Avoid ever-growing postgis
- extension upgrade scripts
+ * [r15437] Avoid ever-growing postgis extension upgrade scripts
Fixes #3775 for 2.3 branch
- * [r15436] postgis/Makefile.in: Style only change: remove trailing
- blanks
+ * [r15436] Style only change: remove trailing blanks
2017-06-06 12:27 Sandro Santilli <strk at kbt.io>
- * [r15421] NEWS, doc/po/de_DE/release_notes.xml.po,
- doc/po/es/release_notes.xml.po, doc/po/fr/release_notes.xml.po,
- doc/po/it_IT/release_notes.xml.po,
- doc/po/ja/release_notes.xml.po,
- doc/po/ko_KR/release_notes.xml.po,
- doc/po/pl/release_notes.xml.po,
- doc/po/pt_BR/release_notes.xml.po,
- doc/po/templates/release_notes.xml.pot, doc/release_notes.xml:
- Speep up -> Speed up
+ * [r15421] Speep up -> Speed up
Thanks Andreas Schild via
https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993598/
@@ -779,8 +844,7 @@
2017-06-06 12:22 Sandro Santilli <strk at kbt.io>
- * [r15418] NEWS, doc/release_notes.xml: shp2pgsql locale fixes are
- #3084, not #3048
+ * [r15418] shp2pgsql locale fixes are #3084, not #3048
https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993584/
@@ -787,15 +851,14 @@
2017-05-04 18:01 Sandro Santilli <strk at kbt.io>
- * [r15388] .drone.yml: Set RUNTESTFLAGS env variable locally
+ * [r15388] Set RUNTESTFLAGS env variable locally
global env doesn't seem to work with Drone
2017-05-03 03:50 Regina Obe <lr at pcorp.us>
- * [r15383] NEWS, postgis/postgis.sql.in,
- raster/rt_pg/rtpostgis.sql.in: @ operator not schema qualified
- and ~ not schema qualified in some places
+ * [r15383] @ operator not schema qualified and ~ not schema
+ qualified in some places
apply patch with adjustments. Patch provided by Shane StClair
(Axiom Data Science)
Closes #3750 for PostGIS 2.3.3
@@ -802,15 +865,14 @@
2017-04-25 08:20 Regina Obe <lr at pcorp.us>
- * [r15368] regress/subdivide.sql, regress/subdivide_expected:
- revise ST_Subdivide regress to use ticket instead of github pull
- request
+ * [r15368] revise ST_Subdivide regress to use ticket instead of
+ github pull request
References #3744 for PostGIS 2.3
2017-04-25 06:02 Regina Obe <lr at pcorp.us>
- * [r15365] NEWS, doc/Makefile.in, doc/texstyle.sty: PDF manual from
- dblatex renders fancy quotes for programlisting
+ * [r15365] PDF manual from dblatex renders fancy quotes for
+ programlisting
Change to use regular quotes
patch from Mike Toews
References #3726 for PostGIS 2.3
@@ -817,9 +879,8 @@
2017-04-24 20:42 Regina Obe <lr at pcorp.us>
- * [r15364] NEWS, liblwgeom/lwgeom.c, regress/subdivide.sql,
- regress/subdivide_expected: ST_Subdivide loses subparts of
- inverted geometries patch from Darafei Praliaskouski (Komzpa)
+ * [r15364] ST_Subdivide loses subparts of inverted geometries patch
+ from Darafei Praliaskouski (Komzpa)
Closes #3744 for PostGIS 2.3
changed area regress to cast to numeric so doesn't return
scientific notation on windows
@@ -826,36 +887,29 @@
2017-04-23 20:34 Regina Obe <lr at pcorp.us>
- * [r15362] NEWS, raster/loader/raster2pgsql.c: Get rid of logic
- that set out_srid to same as input srid and change to not try to
- transform when out_srid is unknown.
+ * [r15362] Get rid of logic that set out_srid to same as input srid
+ and change to not try to transform when out_srid is unknown.
Closes #3738 for PostGIS 2.3
2017-04-12 13:35 Sandro Santilli <strk at kbt.io>
- * [r15352] README.md: Fix drone build badge url
+ * [r15352] Fix drone build badge url
[ci skip]
2017-04-08 12:25 Regina Obe <lr at pcorp.us>
- * [r15348] regress/knn_recheck.sql, regress/knn_recheck_expected:
- Get rid of knn tests where multiple records have the same
- distances
+ * [r15348] Get rid of knn tests where multiple records have the
+ same distances
references #3649 for 2.3
2017-04-04 17:40 Daniel Baston <dbaston at gmail.com>
- * [r15346] doc/reference_measure.xml: Fix error in docs for
- ST_ClusterDBSCAN
+ * [r15346] Fix error in docs for ST_ClusterDBSCAN
2017-03-11 16:23 Sandro Santilli <strk at kbt.io>
- * [r15331] NEWS, liblwgeom/lwgeom_topo.c,
- topology/test/regress/topogeo_addlinestring.sql,
- topology/test/regress/topogeo_addlinestring_expected_newsnap,
- topology/test/regress/topogeo_addlinestring_expected_oldsnap: Fix
- azimuth computation for 2.5D edge ends
+ * [r15331] Fix azimuth computation for 2.5D edge ends
The change disreguard vertical movemements of the edge and
computes
@@ -867,57 +921,48 @@
2017-01-31 05:05 Regina Obe <lr at pcorp.us>
- * [r15303] Version.config, extensions/upgradeable_versions.mk: Bump
- to next dev revision
+ * [r15303] Bump to next dev revision
2017-01-30 05:59 Regina Obe <lr at pcorp.us>
- * [r15301] ChangeLog, NEWS, README.postgis, Version.config,
- doc/release_notes.xml, extensions/upgradeable_versions.mk: Prep
- for PostGIS 2.3.2 release
+ * [r15301] Prep for PostGIS 2.3.2 release
2017-01-28 04:10 Regina Obe <lr at pcorp.us>
- * [r15295] liblwgeom/lwprint.c: Fix for 32-bit lwprint to support
- ST_AsLatLonText
+ * [r15295] Fix for 32-bit lwprint to support ST_AsLatLonText
References #3688 for PostGIS 2.3.2
2017-01-25 23:42 Regina Obe <lr at pcorp.us>
- * [r15293] extras/tiger_geocoder/tiger_loader_2016.sql: Turn off
- loading of tabblock by default. It's been broken since 2014
+ * [r15293] Turn off loading of tabblock by default. It's been
+ broken since 2014
References #3898 for PostGIS 2.3
2017-01-22 07:44 Regina Obe <lr at pcorp.us>
- * [r15291] postgis/geography.sql.in, postgis/geography_brin.sql.in,
- postgis/postgis.sql.in, postgis/postgis_brin.sql.in: Fix for
- pg_upgrade of pg < 9.5 + 2.3+, pg_upgrade and doing a postgis
- micro update to latest stable.
+ * [r15291] Fix for pg_upgrade of pg < 9.5 + 2.3+, pg_upgrade and
+ doing a postgis micro update to latest stable.
closes #3683 for PostGIS 2.3
2017-01-18 21:07 Sandro Santilli <strk at kbt.io>
- * [r15289] NEWS, liblwgeom/cunit/cu_print.c, liblwgeom/lwprint.c:
- ST_AsLatLonText: round minutes [2.3 backport]
+ * [r15289] ST_AsLatLonText: round minutes [2.3 backport]
Patch by Mike Toews, closes #3688
2017-01-07 08:52 Regina Obe <lr at pcorp.us>
- * [r15285] NEWS, postgis/gserialized_gist_2d.c,
- regress/knn_recheck.sql, regress/knn_recheck_expected: KNN
- recheck in 9.5+ fails with index returned tuples in wrong order
+ * [r15285] KNN recheck in 9.5+ fails with index returned tuples in
+ wrong order
references #3418 for PostGIS 2.3
2017-01-06 10:31 Regina Obe <lr at pcorp.us>
- * [r15282] NEWS: update news with latest 2 bug fixes
+ * [r15282] update news with latest 2 bug fixes
2017-01-05 19:15 Regina Obe <lr at pcorp.us>
- * [r15280] postgis/postgis.sql.in: Relationship functions not using
- an index in some cases
+ * [r15280] Relationship functions not using an index in some cases
Set cost back to 1 for functions that return a geometry
A higher cost has the side-effect of making the planner
think when used in conjunction with relate constructs like
@@ -928,150 +973,131 @@
2016-12-20 03:22 Regina Obe <lr at pcorp.us>
- * [r15278] utils/postgis_proc_upgrade.pl: PostGIS upgrade scripts
- missing GRANT for views
+ * [r15278] PostGIS upgrade scripts missing GRANT for views
references #3680 for PostGIS 2.3
2016-12-03 22:32 Sandro Santilli <strk at kbt.io>
- * [r15270] NEWS: Indent and style NEWS file
+ * [r15270] Indent and style NEWS file
2016-12-03 20:39 Regina Obe <lr at pcorp.us>
- * [r15268] postgis/postgis.sql.in: Cost on ST_SetSRID is preventing
- index use with relation functions. Change from 10 to 1.
+ * [r15268] Cost on ST_SetSRID is preventing index use with relation
+ functions. Change from 10 to 1.
References #3675 for PostGIS 2.3
2016-11-28 15:10 Regina Obe <lr at pcorp.us>
- * [r15265] HOWTO_RELEASE, Version.config,
- extensions/upgradeable_versions.mk: More minor corrections to
- HOW_TO_RELEASE, bump version to 2.3.2dev
+ * [r15265] More minor corrections to HOW_TO_RELEASE, bump version
+ to 2.3.2dev
2016-11-28 14:49 Regina Obe <lr at pcorp.us>
- * [r15263] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
- extensions/upgradeable_versions.mk: More corrections to
- HOWTO_RELEASE, prepare for PostGIS 2.3.1 release
+ * [r15263] More corrections to HOWTO_RELEASE, prepare for PostGIS
+ 2.3.1 release
2016-11-26 21:49 Regina Obe <lr at pcorp.us>
- * [r15260] HOWTO_RELEASE: Add build badges, trunk vs. branch
- release
+ * [r15260] Add build badges, trunk vs. branch release
closes #3671 for PostGIS 2.3
2016-11-26 19:54 Regina Obe <lr at pcorp.us>
- * [r15256] NEWS, postgis/postgis.sql.in: Mark ST_Extent, ST_Mem*
- aggregate functions parallel safe
+ * [r15256] Mark ST_Extent, ST_Mem* aggregate functions parallel
+ safe
closes #3650 for PostGIS 2.3.1
2016-11-26 16:39 Regina Obe <lr at pcorp.us>
- * [r15253] doc/reference_raster.xml: ST_DumpAsPolygons
- documentation confusing wrt no data value
+ * [r15253] ST_DumpAsPolygons documentation confusing wrt no data
+ value
closes #3512 for PostGIS 2.3.1
2016-11-26 15:19 Regina Obe <lr at pcorp.us>
- * [r15250] doc/reference_measure.xml: ST_Equals documentation does
- not describe current behavior
+ * [r15250] ST_Equals documentation does not describe current
+ behavior
closes #3566 for 2.3.1
2016-11-26 14:55 Regina Obe <lr at pcorp.us>
- * [r15246] doc/extras_topology.xml: Incorrect parameter name for
- CreateTopology
+ * [r15246] Incorrect parameter name for CreateTopology
references #3509 for 2.3.1
2016-11-25 01:05 Regina Obe <lr at pcorp.us>
- * [r15245] NEWS, raster/rt_pg/rtpostgis.sql.in: add raster
- constraint max extent exceeds array size limit
+ * [r15245] add raster constraint max extent exceeds array size
+ limit
references #3501 for 2.3 (PostGIS 2.3.1)
2016-11-21 15:03 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15238] configure.ac: Change MSG line
+ * [r15238] Change MSG line
2016-11-17 08:01 Sandro Santilli <strk at kbt.io>
- * [r15235] doc/extras_topology.xml: Backport trunk changes in
- topology docs
+ * [r15235] Backport trunk changes in topology docs
2016-11-15 23:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15231] configure.ac: OS guard 10.12 osx libxml fix
+ * [r15231] OS guard 10.12 osx libxml fix
2016-11-11 19:51 Regina Obe <lr at pcorp.us>
- * [r15228] NEWS: add missing bug fix to list
+ * [r15228] add missing bug fix to list
2016-11-11 19:42 Regina Obe <lr at pcorp.us>
- * [r15227] NEWS, doc/using_postgis_dataman.xml,
- libpgcommon/gserialized_gist.c, libpgcommon/gserialized_gist.h,
- postgis/brin_2d.c, postgis/brin_nd.c,
- postgis/gserialized_gist_2d.c, postgis/gserialized_gist_nd.c,
- regress/regress_brin_index.sql,
- regress/regress_brin_index_3d.sql,
- regress/regress_brin_index_3d_expected,
- regress/regress_brin_index_expected: index corruption and memory
- leak in BRIN support
+ * [r15227] index corruption and memory leak in BRIN support
Patch from Julien Rouhaud (Dalibo)
closes #3665 for PostGIS 2.3.1
2016-11-10 00:11 Regina Obe <lr at pcorp.us>
- * [r15222] NEWS, liblwgeom/lwgeodetic.c, regress/geography.sql,
- regress/geography_expected: Bug in geography ST_Segmentize
+ * [r15222] Bug in geography ST_Segmentize
References #3667 for PostGIS 2.3.1
Patch provided by Hugo Mercier (Oslandia)
2016-10-30 22:30 Regina Obe <lr at pcorp.us>
- * [r15220] NEWS, postgis/postgis.sql.in: st_concavehull() returns
- sometimes empty geometry collection
+ * [r15220] st_concavehull() returns sometimes empty geometry
+ collection
references #1973 for PostGIS 2.3
2016-10-28 15:41 Sandro Santilli <strk at kbt.io>
- * [r15216] .drone.yml: Update drone yml to 0.5 version
+ * [r15216] Update drone yml to 0.5 version
See https://git.osgeo.org/gogs/sac/gogs-service/issues/14
2016-10-16 01:16 Regina Obe <lr at pcorp.us>
- * [r15209] raster/rt_pg/rtpostgis.c: raster GUC -
- boot_postgis_gdal_enabled_drivers should use TopMemoryContext
- instead of CurrentMemoryContext
+ * [r15209] raster GUC - boot_postgis_gdal_enabled_drivers should
+ use TopMemoryContext instead of CurrentMemoryContext
References #3659 for 2.3 (PostGIS 2.3.4) patch provided by
manaeem
2016-10-10 20:24 Sandro Santilli <strk at kbt.io>
- * [r15202] liblwgeom/lwgeom_geos.c: Fix typo in error message about
- ClipByBox availability
+ * [r15202] Fix typo in error message about ClipByBox availability
2016-10-10 19:46 Sandro Santilli <strk at kbt.io>
- * [r15198] .drone.yml: Be verbose in running tests
+ * [r15198] Be verbose in running tests
2016-10-08 09:11 Sandro Santilli <strk at kbt.io>
- * [r15194] README.md: Fix buildbot badges to point to 2.3 branch
+ * [r15194] Fix buildbot badges to point to 2.3 branch
See #3657
2016-10-07 20:17 Sandro Santilli <strk at kbt.io>
- * [r15191] utils/check_all_upgrades.sh: Add missing upgrade checker
+ * [r15191] Add missing upgrade checker
2016-10-07 20:05 Sandro Santilli <strk at kbt.io>
- * [r15190] .drone.yml, NEWS, postgis/postgis.sql.in: Fix aggregates
- upgrade
+ * [r15190] Fix aggregates upgrade
Fixes #3656 (aggregate upgrades)
@@ -1079,49 +1105,43 @@
2016-10-06 17:31 Sandro Santilli <strk at kbt.io>
- * [r15179] doc/doxygen.cfg.in: Remove hard-coded version in Doxygen
- project name
+ * [r15179] Remove hard-coded version in Doxygen project name
2016-10-03 20:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15168] NEWS, liblwgeom/lwstroke.c: #3652, Crash on
- collection(multicurve())
+ * [r15168] #3652, Crash on collection(multicurve())
2016-09-27 22:55 Regina Obe <lr at pcorp.us>
- * [r15160] README.postgis:
+ * [r15160]
2016-09-27 08:12 Sandro Santilli <strk at kbt.io>
- * [r15157] NEWS, postgis/postgis_module.c: Do not call printf from
- interrupt handler, fixing deadlocks
+ * [r15157] Do not call printf from interrupt handler, fixing
+ deadlocks
Closes #3644 for 2.3 branch
2016-09-26 21:47 Regina Obe <lr at pcorp.us>
- * [r15153] NEWS, configure.ac: PostGIS not building on latest OSX
- XCode
+ * [r15153] PostGIS not building on latest OSX XCode
References #3643 for PostGIS 2.3.1 (patch from pramsey)
2016-09-26 05:45 Regina Obe <lr at pcorp.us>
- * [r15148] Version.config, extensions/upgradeable_versions.mk: bump
- up version to 2.3.1dev
+ * [r15148] bump up version to 2.3.1dev
2016-09-26 05:15 Regina Obe <lr at pcorp.us>
- * [r15145] doc/release_notes.xml: fix typo in release notes
+ * [r15145] fix typo in release notes
2016-09-26 04:45 Regina Obe <lr at pcorp.us>
- * [r15144] ChangeLog, NEWS, README.postgis, Version.config,
- doc/release_notes.xml, extensions/upgradeable_versions.mk: Get
- ready for PostGIS 2.3.0 launch
+ * [r15144] Get ready for PostGIS 2.3.0 launch
2016-09-26 03:26 Regina Obe <lr at pcorp.us>
- * [r15143] .: Branch 2.3 (trunk will become 2.4 after we are done)
+ * [r15143] Branch 2.3 (trunk will become 2.4 after we are done)
2016-09-25 09:19 Regina Obe <lr at pcorp.us>
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2018-11-23 17:56:22 UTC (rev 17063)
+++ branches/2.3/NEWS 2018-11-24 05:02:47 UTC (rev 17064)
@@ -1,7 +1,7 @@
PostGIS 2.3.8
-2018/xx/xx
+2018/11/24
- * Bug Fixes and Enchantments
+ * Bug Fixes and Enhancements
- #4071, ST_ClusterKMeans crash on NULL/EMPTY fixed (Darafei Praliaskouski)
- #4074, Disable interrupt tests by default (Regina Obe)
Modified: branches/2.3/README.postgis
--- branches/2.3/README.postgis 2018-11-23 17:56:22 UTC (rev 17063)
+++ branches/2.3/README.postgis 2018-11-24 05:02:47 UTC (rev 17064)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.3.7
-:Date: 2018-04-08
+:Version: 2.3.8
+:Date: 2018-11-24
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.3/Version.config
--- branches/2.3/Version.config 2018-11-23 17:56:22 UTC (rev 17063)
+++ branches/2.3/Version.config 2018-11-24 05:02:47 UTC (rev 17064)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=8dev
+POSTGIS_MICRO_VERSION=8
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.3/doc/release_notes.xml
--- branches/2.3/doc/release_notes.xml 2018-11-23 17:56:22 UTC (rev 17063)
+++ branches/2.3/doc/release_notes.xml 2018-11-24 05:02:47 UTC (rev 17064)
@@ -3,6 +3,31 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 2.3.8</title>
+ <para>Release date: 2018/11/24</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>Bug Fixes and Enhancements</title>
+ <para>#4071, ST_ClusterKMeans crash on NULL/EMPTY fixed (Darafei Praliaskouski)</para>
+ <para>#4074, Disable interrupt tests by default (Regina Obe)</para>
+ <para>#3997, fix bug in lwgeom_median and avoid division by zero (Raúl Marín)</para>
+ <para>#4093, Inconsistent results from qsort callback (yugr)</para>
+ <para>#4160, Use qualified names in topology extension install (Raúl Marín)</para>
+ <para>#4189, Fix undefined behaviour in SADFWrite (Raúl Marín)</para>
+ <para>#4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)</para>
+ <para>#4020, Fix leftovers in topology upgrade from 2.1 (Sandro Santilli)</para>
+ <para>#4203, Fix build with GNU Make 4.1 (Sandro Santilli)</para>
+ <para>#4206, Fix support for PostgreSQL 12 dev branch (Laurenz Albe)</para>
+ <para>#3457, Fix raster envelope shortcut in ST_Clip (Sai-bot)</para>
+ <para>#4223, Fix parallel/near rectangle case in geography (Paul Ramsey)</para>
+ <para>#4326, Allocate enough memory in gidx_to_string (Raúl Marín)</para>
+ <para>#4247, Avoid undefined behaviour in next_float functions (Raúl Marín)</para>
+ <para>#4249, Fix undefined behaviour in raster intersection (Raúl Marín)</para>
+ <para>#4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)</para>
+ <para>#4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.3.7</title>
<para>Release date: 2018/04/06</para>
Modified: branches/2.3/extensions/upgradeable_versions.mk
--- branches/2.3/extensions/upgradeable_versions.mk 2018-11-23 17:56:22 UTC (rev 17063)
+++ branches/2.3/extensions/upgradeable_versions.mk 2018-11-24 05:02:47 UTC (rev 17064)
@@ -25,6 +25,7 @@
2.2.5 \
2.2.6 \
2.2.7 \
+ 2.2.8 \
2.3.0 \
2.3.1 \
2.3.2 \
