[postgis-tickets] [PostGIS] #2713: missing functions docs
PostGIS trac at osgeo.org
Sat Nov 24 20:25:43 PST 2018
  Reporter:  mjurce         |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:
 Component:  documentation  |    Version:  2.1.x
Resolution:                 |   Keywords:
Comment (by robe):
 sunveersingh,
 To work on the docs, you'd edit the corresponding docs -- for this case
 the st_startPoint, st_endPoint etc. are in the file
 https://svn.osgeo.org/postgis/trunk/doc/reference_accessor.xml
 You can check out the code from any of our mirrors listed here or the tar
 ball is fine too
 https://postgis.net/source/
 Make your changes to the trunk branch (3.0) and we'll back port changes if
 we feel they can be backported.
 Ideally you should provide us the patch in standard patch format and
 attach to the corresponding ticket.
 We also accept contributions via pull requests on any of our git mirrors
 listed on this page.
 Let me know if you need any clarification on the above.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2713#comment:6>
