[postgis-tickets] r17072 - Create rt_legacy.c and postgis_legacy.c put back functions taken out in 2.5 and put them in these files. Stub them with errors.
Regina Obe lr at pcorp.us
Sat Nov 24 08:35:17 PST 2018
Author: robe
Date: 2018-11-24 20:35:17 -0800 (Sat, 24 Nov 2018)
New Revision: 17072
Added:
   trunk/postgis/postgis_legacy.c
   trunk/raster/rt_pg/rtpg_legacy.c
   trunk/postgis/Makefile.in
   trunk/raster/rt_pg/Makefile.in
Still need to check 2.1 - 2.4 for things we might have taken out (only test pg_upgrade from 9.4 2.4 to 11 3.0 which failed with 3.0 needs dump restore)
References #4193 for PostGIS 3.0 (trunk)
Modified: trunk/postgis/Makefile.in
--- trunk/postgis/Makefile.in	2018-11-25 01:33:04 UTC (rev 17071)
+++ trunk/postgis/Makefile.in	2018-11-25 04:35:17 UTC (rev 17072)
@@ -122,7 +122,8 @@
 	mvt.o \
 	lwgeom_out_mvt.o \
 	geobuf.o \
-	lwgeom_out_geobuf.o
+	lwgeom_out_geobuf.o \
+	postgis_legacy.o
 # Objects to build using PGXS
 OBJS=$(PG_OBJS)
Added: trunk/postgis/postgis_legacy.c
--- trunk/postgis/postgis_legacy.c	                        (rev 0)
+++ trunk/postgis/postgis_legacy.c	2018-11-25 04:35:17 UTC (rev 17072)
@@ -0,0 +1,62 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
+ * Copyright (C) 2018 Regina Obe <lr at pcorp.us>
+ * This file is to hold functions we no longer use,
+ * but we need to keep because they were used at one time behind SQL API functions.
+ * This is to ease pg_upgrade upgrades
+ * All functions in this file should throw an error telling the user to upgrade
+ * the install
+#include "postgres.h"
+#include "utils/builtins.h"
+#include "../postgis_config.h"
+#include "lwgeom_pg.h"
+/** pgis_abs_in: Removed PostGIS 2.5.0 **/
+Datum pgis_abs_in(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(pgis_abs_in);
+Datum
+pgis_abs_in(PG_FUNCTION_ARGS)
+	ereport(ERROR,(errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
+	               errmsg("function %s is out of date. Run: ALTER EXTENSION postgis UPDATE;", __func__)));
+	PG_RETURN_POINTER(NULL);
+/** pgis_abs_out: Removed PostGIS 2.5.0 **/
+Datum pgis_abs_out(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(pgis_abs_out);
+Datum
+pgis_abs_out(PG_FUNCTION_ARGS)
Modified: trunk/raster/rt_pg/Makefile.in
--- trunk/raster/rt_pg/Makefile.in	2018-11-25 01:33:04 UTC (rev 17071)
+++ trunk/raster/rt_pg/Makefile.in	2018-11-25 04:35:17 UTC (rev 17072)
@@ -45,6 +45,7 @@
 OBJS = \
 	rtpostgis.o \
 	rtpg_internal.o \
+	rtpg_legacy.o \
 	rtpg_spatial_relationship.o \
 	rtpg_mapalgebra.o \
 	rtpg_utility.o \
Added: trunk/raster/rt_pg/rtpg_legacy.c
--- trunk/raster/rt_pg/rtpg_legacy.c	                        (rev 0)
+++ trunk/raster/rt_pg/rtpg_legacy.c	2018-11-25 04:35:17 UTC (rev 17072)
@@ -0,0 +1,55 @@
+ * the install
+#include <postgres.h>
+#include <fmgr.h>
+#include "rtpostgis.h"
+/** obsolete as of 2.5.0 stubbing for smoother upgrade from 2.4 **/
+Datum RASTER_to_binary(PG_FUNCTION_ARGS);
+ * Removed in PostGIS 2.5.0
+PG_FUNCTION_INFO_V1(RASTER_to_binary);
+	elog(ERROR, "RASTER_to_binary: This function is out of date. Run: ALTER EXTENSION postgis UPDATE; SELECT PostGIS_Extensions_Upgrade();");
