[postgis-tickets] [PostGIS] #4193: Create rt_legacy.c, postgis_legacy.c
PostGIS trac at osgeo.org
Sat Nov 24 20:35:18 PST 2018
  Reporter:  robe     |      Owner:  robe
      Type:  task     |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 In [changeset:"17072" 17072]:
 #!CommitTicketReference repository="" revision="17072"
 Create rt_legacy.c and postgis_legacy.c put back functions taken out in
 2.5 and put them in these files.  Stub them with errors.
 Still need to check 2.1 - 2.4 for things we might have taken out (only
 test pg_upgrade from 9.4 2.4 to 11 3.0 which failed with 3.0 needs dump
 restore)
 References #4193 for PostGIS 3.0 (trunk)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4193#comment:2>
