[postgis-tickets] [PostGIS] #4257: operator does not exist: gidx public.&& geography when upgrading from 9.4 postgis 2.4 to pg 11 3.0
trac at osgeo.org
Sun Nov 25 00:05:31 PST 2018
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Okay I know pramsey will want to scream a "Well if it hurts don't do that"
my way.
Here it is the dirty pg_upgrading from PostgreSQL 9.4 2.4.6 to PostgreSQL
11 3.0.0dev
1. Have PostgreSQL 9.4 instance installed with PostGIS 2.4.6 and a
database test24 with postgis installed in it.
2. On my PostgreSQL 11 instance, have postgis 3.0 installed and make a
copy of the postgis-3.dll, rtpostgis-3.dll to postgis-2.4.dll,
rtpostgis-2.4.dll
3. Run pg_upgrade from 9.4 to PG 11
4) Start up my PG 11 and run
SELECT postgis_full_version();
output is this - so far so good -yeh our version checker is smart enough
to know I tricked it with a 3.0 lib, but I'm running 2.4.6 scripts (and
2.4.6 scripts from a 9.4 install yeh and yeh)
POSTGIS="3.0.0dev r16983" PGSQL="94" (procs need upgrade for use with
"110") GEOS="3.7.0-CAPI-1.11.0 673b9939" PROJ="Rel. 5.2.0, September 15th,
2018" GDAL="GDAL 2.3.1, released 2018/06/22" LIBXML="2.7.8"
LIBPROTOBUF="1.2.1" (core procs from "2.4.6 r17057" need upgrade) RASTER
(raster procs from "2.4.6 r17057" need upgrade)
5) Run
ALTER EXTENSION postgis UPDATE TO "3.0.0dev";
FAILS
with
ERROR: operator does not exist: gidx public.&& geography
LINE 1: SELECT $2 OPERATOR(public.&&) $1;
Like a monkey expecting something different to happen by pressing the
button again, I try again
WARNING: unpackaging raster
WARNING: PostGIS Raster functionality has been unpackaged
HINT: type `SELECT postgis_extensions_upgrade(); to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
******* Error *******
HINT: No operator matches the given name and argument types. You might
need to add explicit type casts.
QUERY: SELECT $2 OPERATOR(public.&&) $1;
SQL state: 42883
I don't think I got that message the first time.
I try a 3rd time.
Hey how come no unpacking raster message this time:
SQL state: 42883
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4257>
