[postgis-tickets] [PostGIS] #4139: Unstable behavior of gist nd indexes
trac at osgeo.org
Sun Nov 25 11:28:52 PST 2018
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.6
Component: postgis | Version: 2.4.x
Resolution: fixed | Keywords:
Changes (by komzpa):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"17074" 17074]:
#!CommitTicketReference repository="" revision="17074"
Stabilize GiST ND indexes for mixed dimensions
Patch by Darafei Praliaskouski
Thanks to
Arthur Lesuisse for synthesizing test case,
Andrew Gierth for finding runaway memcpy,
Raúl Marín for pointing to memory problem in index construction.
This is not backpatchable to 2.x, that requires separate solution.
Closes #4139
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4139#comment:10>
