[postgis-tickets] r17085 - Document MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)
Raul
raul at rmr.ninja
Thu Nov 29 01:29:59 PST 2018
Author: algunenano
Date: 2018-11-29 01:29:59 -0800 (Thu, 29 Nov 2018)
New Revision: 17085
branches/2.5/NEWS
branches/2.5/doc/reference_processing.xml
References #4162
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2018-11-29 09:19:57 UTC (rev 17084)
+++ branches/2.5/NEWS 2018-11-29 09:29:59 UTC (rev 17085)
@@ -8,10 +8,11 @@
- #4249, Fix undefined behaviour in raster intersection (Raúl Marín)
- #4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)
- #4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)
- - #4139, Make mixed-dimension ND index build tree correctly.
+ - #4139, Make mixed-dimension ND index build tree correctly.
WARNING: REINDEX your ND index on tables that have records with different M/Z
dimensions for &&& operator to work predictably.
(Darafei Praliaskouski, Arthur Lesuisse, Andrew Gierth, Raúl Marín)
+ - #4162, Document MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)
PostGIS 2.5.1
Modified: branches/2.5/doc/reference_processing.xml
--- branches/2.5/doc/reference_processing.xml 2018-11-29 09:19:57 UTC (rev 17084)
+++ branches/2.5/doc/reference_processing.xml 2018-11-29 09:29:59 UTC (rev 17085)
@@ -920,7 +920,7 @@
<refnamediv>
<refname>ST_CurveToLine</refname>
- <refpurpose>Converts a CIRCULARSTRING/CURVEPOLYGON to a LINESTRING/POLYGON</refpurpose>
+ <refpurpose>Converts a CIRCULARSTRING/CURVEPOLYGON/MULTISURFACE to a LINESTRING/POLYGON/MULTIPOLYGON</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -938,7 +938,7 @@
<refsection>
<title>Description</title>
- <para>Converts a CIRCULAR STRING to regular LINESTRING or CURVEPOLYGON to POLYGON. Useful for outputting to devices that can't support CIRCULARSTRING geometry types</para>
+ <para>Converts a CIRCULAR STRING to regular LINESTRING or CURVEPOLYGON to POLYGON or MULTISURFACE to MULTIPOLYGON. Useful for outputting to devices that can't support CIRCULARSTRING geometry types</para>
<para>Converts a given geometry to a linear geometry.
Each curved geometry or segment is converted into a linear
