[postgis-tickets] r17086 - Document MULTISURFACE compatibility of ST_LineToCurve
Raúl Marín Rodríguez rmrodriguez at carto.com
Thu Nov 29 03:10:02 PST 2018
You are right. I'll change it in the NEWS files.
On Thu, Nov 29, 2018 at 11:31 AM Darafei "Komяpa" Praliaskouski
<me at komzpa.net> wrote:
> Ticket number should have been #4262.
> On Thu, Nov 29, 2018 at 12:31 PM Raul <raul at rmr.ninja> wrote:
>> Author: algunenano
>> Date: 2018-11-29 01:31:43 -0800 (Thu, 29 Nov 2018)
>> New Revision: 17086
>> Modified:
>>    trunk/NEWS
>>    trunk/doc/reference_processing.xml
>> Log:
>> Patch by Steven Ottens
>> Closes #4162
>> Closes https://github.com/postgis/postgis/pull/343
>> Modified: trunk/NEWS
>> --- trunk/NEWS  2018-11-29 09:29:59 UTC (rev 17085)
>> +++ trunk/NEWS  2018-11-29 09:31:43 UTC (rev 17086)
>> @@ -45,6 +45,7 @@
>>    - #4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)
>>    - #4139, Make mixed-dimension ND index build tree correctly (Darafei Praliaskouski,
>>             Arthur Lesuisse, Andrew Gierth, Raúl Marín)
>> +  - #4162, Document MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)
>>  PostGIS 2.5.0
>>  2018/09/23
>> Modified: trunk/doc/reference_processing.xml
>> --- trunk/doc/reference_processing.xml  2018-11-29 09:29:59 UTC (rev 17085)
>> +++ trunk/doc/reference_processing.xml  2018-11-29 09:31:43 UTC (rev 17086)
>> @@ -920,7 +920,7 @@
>>           <refnamediv>
>>                 <refname>ST_CurveToLine</refname>
>> -               <refpurpose>Converts a CIRCULARSTRING/CURVEPOLYGON to a LINESTRING/POLYGON</refpurpose>
>> +               <refpurpose>Converts a CIRCULARSTRING/CURVEPOLYGON/MULTISURFACE to a LINESTRING/POLYGON/MULTIPOLYGON</refpurpose>
>>           </refnamediv>
>>           <refsynopsisdiv>
>> @@ -938,7 +938,7 @@
>>           <refsection>
>>                 <title>Description</title>
>> -               <para>Converts a CIRCULAR STRING to regular LINESTRING or CURVEPOLYGON to POLYGON. Useful for outputting to devices that can't support CIRCULARSTRING geometry types</para>
>> +               <para>Converts a CIRCULAR STRING to regular LINESTRING or CURVEPOLYGON to POLYGON or MULTISURFACE to MULTIPOLYGON. Useful for outputting to devices that can't support CIRCULARSTRING geometry types</para>
>>                 <para>Converts a given geometry to a linear geometry.
>>                 Each curved geometry or segment is converted into a linear
>> postgis-tickets mailing list
>> postgis-tickets at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
> Support me: http://patreon.com/komzpa
carto.com
