[postgis-tickets] r17091 - postgis_legacy.c: use #define's
Darafei
komzpa at gmail.com
Fri Nov 30 09:01:32 PST 2018
Author: komzpa
Date: 2018-11-30 09:01:32 -0800 (Fri, 30 Nov 2018)
New Revision: 17091
trunk/postgis/postgis_legacy.c
Modified: trunk/postgis/postgis_legacy.c
--- trunk/postgis/postgis_legacy.c 2018-11-30 15:47:32 UTC (rev 17090)
+++ trunk/postgis/postgis_legacy.c 2018-11-30 17:01:32 UTC (rev 17091)
@@ -36,27 +36,18 @@
#include "../postgis_config.h"
#include "lwgeom_pg.h"
-/** pgis_abs_in: Removed PostGIS 2.5.0 **/
-Datum pgis_abs_in(PG_FUNCTION_ARGS);
-PG_FUNCTION_INFO_V1(pgis_abs_in);
+#define POSTGIS_DEPRECATE(version, funcname) \
+ Datum funcname(PG_FUNCTION_ARGS); \
+ PG_FUNCTION_INFO_V1(funcname); \
+ Datum funcname(PG_FUNCTION_ARGS) \
+ ereport(ERROR, \
+ (errcode(ERRCODE_FEATURE_NOT_SUPPORTED), \
+ errmsg("function %s is out of date since PostGIS %s. Run: ALTER EXTENSION postgis UPDATE;", \
+ __func__, \
+ version))); \
+ PG_RETURN_POINTER(NULL); \
-Datum
-pgis_abs_in(PG_FUNCTION_ARGS)
- ereport(ERROR,(errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
- errmsg("function %s is out of date. Run: ALTER EXTENSION postgis UPDATE;", __func__)));
- PG_RETURN_POINTER(NULL);
-/** pgis_abs_out: Removed PostGIS 2.5.0 **/
-Datum pgis_abs_out(PG_FUNCTION_ARGS);
-PG_FUNCTION_INFO_V1(pgis_abs_out);
-Datum
-pgis_abs_out(PG_FUNCTION_ARGS)
+POSTGIS_DEPRECATE("2.5.0", pgis_abs_in);
+POSTGIS_DEPRECATE("2.5.0", pgis_abs_out);
