[postgis-tickets] r17380 - st_askml(geography, integer) was replaced by default args
Sandro Santilli
strk at kbt.io
Wed Apr 10 09:15:47 PDT 2019
Author: strk
Date: 2019-04-10 09:15:46 -0700 (Wed, 10 Apr 2019)
New Revision: 17380
trunk/postgis/postgis_drop_before.sql
Closes #4366 again
Modified: trunk/postgis/postgis_drop_before.sql
--- trunk/postgis/postgis_drop_before.sql 2019-04-10 15:18:20 UTC (rev 17379)
+++ trunk/postgis/postgis_drop_before.sql 2019-04-10 16:15:46 UTC (rev 17380)
@@ -72,7 +72,8 @@
DROP FUNCTION IF EXISTS ST_LineCrossingDirection(geometry, geometry);
DROP FUNCTION IF EXISTS _st_orderingequals(geometry,geometry);
DROP FUNCTION IF EXISTS st_orderingequals(geometry,geometry);
-DROP FUNCTION IF EXISTS st_askml(geometry, integer);
+DROP FUNCTION IF EXISTS st_askml(geometry, integer); -- changed to use default args in PostGIS 3.0 (r17357)
+DROP FUNCTION IF EXISTS st_askml(geography, integer); -- changed to use default args in PostGIS 3.0 (r17357)
DROP FUNCTION IF EXISTS st_buffer(geometry, double precision);
-- Old signatures for protobuf related functions improved in 2.4.0 RC/final
