[postgis-tickets] [PostGIS] #4376: regress tickets failure nan nan
PostGIS trac at osgeo.org
Sat Apr 13 21:48:44 PDT 2019
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Loading PostGIS into 'postgis_reg'
   /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
 install/share/contrib/postgis/postgis.sql
 install/share/contrib/postgis/postgis_comments.sql
 install/share/contrib/postgis/postgis_proc_set_search_path.sql
 PostgreSQL 12devel on x86_64-pc-linux-gnu, compiled by gcc (Debian
 8.3.0-5) 8.3.0, 64-bit
   Postgis 3.0.0dev - r - 2019-04-14 04:22:36
   scripts 3.0.0dev r0
   GEOS: 3.8.0dev-CAPI-1.11.0 859dc941
   PROJ: Rel. 5.2.0, September 15th, 2018
  tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_98_diff)
 --- tickets_expected    2019-04-13 15:14:35.896524387 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_98_out
 2019-04-14 04:25:24.595690005 +0000
 @@ -303,7 +303,7 @@
  #3627b|t
  #3704|t
  #3709|t
 -NOTICE:  Hole lies outside shell at or near point 25495368.044100001
 6671726.9312000005
 +NOTICE:  Hole lies outside shell at or near point nan nan
  #3719a|f
  #3719b|t
  #3774|t
 I had disabled raster builting to get this far.  I suspect the sfcgal I
 installed brought in an old GDAL and the old GDAL brought in an old proj.
 So I uninstalled all that and ran without GDAL or SFCGAL.
 I haven't checked on my local to see what errors I get (as I'm getting a
 bunch of raster erros at moment with proj).
 But note though gitlab and github are showing greens, they are broken
 because of #4375
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4376>
