[postgis-tickets] r17397 - Remove ST_Accum. Please use array_agg instead.
Darafei
komzpa at gmail.com
Wed Apr 17 10:35:08 PDT 2019
Author: komzpa
Date: 2019-04-17 22:35:07 -0700 (Wed, 17 Apr 2019)
New Revision: 17397
trunk/NEWS
trunk/doc/reference_accessor.xml
trunk/doc/reference_constructor.xml
trunk/doc/reference_processing.xml
trunk/postgis/legacy.sql.in
trunk/postgis/lwgeom_accum.c
trunk/postgis/postgis.sql.in
trunk/postgis/postgis_drop_after.sql
trunk/postgis/postgis_legacy.c
trunk/regress/core/cluster.sql
Closes #4356
Closes https://github.com/postgis/postgis/pull/393
Modified: trunk/NEWS
--- trunk/NEWS 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/NEWS 2019-04-18 05:35:07 UTC (rev 17397)
@@ -21,6 +21,7 @@
- #4268, Bump minimum SFCGAL version to 1.3.1 (Darafei Praliaskouski)
- #4331, ST_3DMakeBox now returns error instead of a miniscule box (Regina Obe)
- #4342, Removed "versioned" variants of ST_AsGeoJSON and ST_AsKML (Paul Ramsey)
+ - #4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)
* New Features *
- #2902, postgis_geos_noop (Sandro Santilli)
Modified: trunk/doc/reference_accessor.xml
--- trunk/doc/reference_accessor.xml 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/doc/reference_accessor.xml 2019-04-18 05:35:07 UTC (rev 17397)
@@ -1588,7 +1588,7 @@
--First 3 Rejects from a successful quintuplet experiment
SELECT gid, ST_IsValidReason(the_geom) as validity_info
FROM
-(SELECT ST_MakePolygon(ST_ExteriorRing(e.buff), ST_Accum(f.line)) As the_geom, gid
+(SELECT ST_MakePolygon(ST_ExteriorRing(e.buff), array_agg(f.line)) As the_geom, gid
FROM (SELECT ST_Buffer(ST_MakePoint(x1*10,y1), z1) As buff, x1*10 + y1*100 + z1*1000 As gid
FROM generate_series(-4,6) x1
CROSS JOIN generate_series(2,5) y1
@@ -1676,7 +1676,7 @@
SELECT gid, reason(ST_IsValidDetail(the_geom)), ST_AsText(location(ST_IsValidDetail(the_geom))) as location
FROM
Modified: trunk/doc/reference_constructor.xml
--- trunk/doc/reference_constructor.xml 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/doc/reference_constructor.xml 2019-04-18 05:35:07 UTC (rev 17397)
@@ -1551,7 +1551,7 @@
geometries must be closed LINESTRINGS. Comes in 2 variants.</para>
<para>Variant 1: Takes one closed linestring.</para>
<para>Variant 2: Creates a Polygon formed by the given shell and array of
- holes. You can construct a geometry array using ST_Accum or the PostgreSQL ARRAY[] and
+ holes. You can construct a geometry array using the PostgreSQL array_agg, ARRAY[] and
ARRAY() constructs. Input geometries must be closed LINESTRINGS.</para>
<note>
<para>This function will not accept a MULTILINESTRING. Use <xref linkend="ST_LineMerge" /> or <xref linkend="ST_Dump" /> to generate line strings.</para>
@@ -1604,7 +1604,6 @@
<para>Build province boundaries with holes
representing lakes in the province from a set of
province polygons/multipolygons and water linestrings.
- This is an example of using PostGIS ST_Accum.
<note><para>The CASE construct is used because feeding a null array into
ST_MakePolygon results in NULL.</para></note>
<note><para>A left join is used to guarantee we get all provinces back even if they have no lakes.</para></note></para>
@@ -1611,8 +1610,8 @@
<programlisting>
SELECT p.gid, p.province_name,
CASE WHEN
- ST_Accum(w.the_geom) IS NULL THEN p.the_geom
- ELSE ST_MakePolygon(ST_LineMerge(ST_Boundary(p.the_geom)), ST_Accum(w.the_geom)) END
+ array_agg(w.the_geom) IS NULL THEN p.the_geom
+ ELSE ST_MakePolygon(ST_LineMerge(ST_Boundary(p.the_geom)), array_agg(w.the_geom)) END
FROM
provinces p LEFT JOIN waterlines w
ON (ST_Within(w.the_geom, p.the_geom) AND ST_IsClosed(w.the_geom))
@@ -1641,7 +1640,6 @@
<title>See Also</title>
<para>
<xref linkend="ST_Boundary" />,
- <xref linkend="ST_Accum" />,
<xref linkend="ST_AddPoint" />,
<xref linkend="ST_GeometryType" />,
<xref linkend="ST_IsClosed" />,
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/doc/reference_processing.xml 2019-04-18 05:35:07 UTC (rev 17397)
@@ -1,67 +1,6 @@
<sect1 id="Geometry_Processing">
<title>Geometry Processing</title>
- <refentry id="ST_Accum">
- <refnamediv>
- <refname>ST_Accum</refname>
- <refpurpose>An aggregate function to construct an array of geometries.</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>geometry[] <function>ST_Accum</function></funcdef>
- <paramdef><type>geometry set</type> <parameter>geomfield</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <title>Description</title>
- <para>An aggregate function to construct an array of geometries.</para>
- <para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
- <para>&Z_support;</para>
- <para>&curve_support;</para>
- <para>&P_support;</para>
- <para>&T_support;</para>
- </refsection>
- <refsection>
- <title>Examples</title>
- <programlisting>SELECT (ST_Accum(the_geom)) As all_em, ST_AsText((ST_Accum(the_geom))[1]) As grabone,
-(ST_Accum(the_geom))[2:4] as grab_rest
- FROM (SELECT ST_MakePoint(a*CAST(random()*10 As integer), a*CAST(random()*10 As integer), a*CAST(random()*10 As integer)) As the_geom
- FROM generate_series(1,4) a) As foo;
-all_em|grabone | grab_rest
- {0101000080000000000000144000000000000024400000000000001040:
- 0101000080000000000
-00018400000000000002C400000000000003040:
-0101000080000000000000354000000000000038400000000000001840:
-010100008000000000000040400000000000003C400000000000003040} |
- POINT(5 10) | {010100008000000000000018400000000000002C400000000000003040:
- 0101000080000000000000354000000000000038400000000000001840:
- 010100008000000000000040400000000000003C400000000000003040}
-(1 row)
- </programlisting>
- </refsection>
- <!-- Optionally add a "See Also" section -->
- <refsection>
- <title>See Also</title>
- <para><xref linkend="ST_Collect" /></para>
- </refsection>
- </refentry>
<refentry id="ST_Buffer">
<refnamediv>
<refname>ST_Buffer</refname>
Modified: trunk/postgis/legacy.sql.in
--- trunk/postgis/legacy.sql.in 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/postgis/legacy.sql.in 2019-04-18 05:35:07 UTC (rev 17397)
@@ -2091,16 +2091,6 @@
-- end Old underscored_names replaced by CamelCase names
---- Start Aggregates and supporting functions --
--- Deprecation in: 1.2.3
--- Changed: 2.5.0 use 'internal' stype
-CREATE AGGREGATE accum (
- sfunc = pgis_geometry_accum_transfn,
- basetype = geometry,
- stype = internal,
- finalfunc = pgis_geometry_accum_finalfn
-- Deprecation in 1.2.3
CREATE OR REPLACE FUNCTION collect(geometry, geometry)
RETURNS geometry
Modified: trunk/postgis/lwgeom_accum.c
--- trunk/postgis/lwgeom_accum.c 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/postgis/lwgeom_accum.c 2019-04-18 05:35:07 UTC (rev 17397)
@@ -42,7 +42,6 @@
Datum PGISDirectFunctionCall1(PGFunction func, Datum arg1);
Datum PGISDirectFunctionCall2(PGFunction func, Datum arg1, Datum arg2);
Datum pgis_geometry_accum_transfn(PG_FUNCTION_ARGS);
-Datum pgis_geometry_accum_finalfn(PG_FUNCTION_ARGS);
Datum pgis_geometry_union_finalfn(PG_FUNCTION_ARGS);
Datum pgis_geometry_collect_finalfn(PG_FUNCTION_ARGS);
Datum pgis_geometry_polygonize_finalfn(PG_FUNCTION_ARGS);
@@ -176,27 +175,6 @@
-** The "accum" final function just returns the geometry[]
-PG_FUNCTION_INFO_V1(pgis_geometry_accum_finalfn);
-Datum
-pgis_geometry_accum_finalfn(PG_FUNCTION_ARGS)
- pgis_abs *p;
- Datum result = 0;
- if (PG_ARGISNULL(0))
- PG_RETURN_NULL(); /* returns null iff no input values */
- p = (pgis_abs*) PG_GETARG_POINTER(0);
- result = pgis_accum_finalfn(p, CurrentMemoryContext, fcinfo);
- PG_RETURN_DATUM(result);
* The "union" final function passes the geometry[] to a union
* conversion before returning the result.
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/postgis/postgis.sql.in 2019-04-18 05:35:07 UTC (rev 17397)
@@ -3822,13 +3822,6 @@
-- Availability: 1.4.0
-- Changed: 2.5.0 use 'internal' transfer type
-CREATE OR REPLACE FUNCTION pgis_geometry_accum_finalfn(internal)
- RETURNS geometry[]
- AS 'MODULE_PATHNAME'
- LANGUAGE 'c' _PARALLEL;
--- Availability: 1.4.0
--- Changed: 2.5.0 use 'internal' transfer type
CREATE OR REPLACE FUNCTION pgis_geometry_union_finalfn(internal)
RETURNS geometry
@@ -3869,18 +3862,6 @@
--- Availability: 1.2.2
--- Changed: 2.4.0 marked parallel safe
-CREATE AGGREGATE ST_Accum (geometry) (
- stype = internal,
-#if POSTGIS_PGSQL_VERSION >= 96
- parallel = safe,
-#endif
CREATE OR REPLACE FUNCTION ST_Union (geometry[])
RETURNS geometry
Modified: trunk/postgis/postgis_drop_after.sql
--- trunk/postgis/postgis_drop_after.sql 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/postgis/postgis_drop_after.sql 2019-04-18 05:35:07 UTC (rev 17397)
@@ -27,6 +27,8 @@
DROP AGGREGATE IF EXISTS st_geomunion(geometry);
DROP AGGREGATE IF EXISTS accum_old(geometry);
DROP AGGREGATE IF EXISTS st_accum_old(geometry);
+DROP AGGREGATE IF EXISTS st_accum(geometry); -- Dropped in 3.0.0
+DROP FUNCTION IF EXISTS pgis_geometry_accum_finalfn(internal);
DROP AGGREGATE IF EXISTS st_astwkb_agg(geometry, integer); -- temporarely introduced before 2.2.0 final
DROP AGGREGATE IF EXISTS st_astwkb_agg(geometry, integer, bigint); -- temporarely introduced before 2.2.0 final
Modified: trunk/postgis/postgis_legacy.c
--- trunk/postgis/postgis_legacy.c 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/postgis/postgis_legacy.c 2019-04-18 05:35:07 UTC (rev 17397)
@@ -74,3 +74,4 @@
POSTGIS_DEPRECATE("3.0.0", sfcgal_distance3d);
POSTGIS_DEPRECATE("3.0.0", LWGEOM_mindistance3d);
POSTGIS_DEPRECATE("3.0.0", intersects);
+POSTGIS_DEPRECATE("3.0.0", pgis_geometry_accum_finalfn);
Modified: trunk/regress/core/cluster.sql
--- trunk/regress/core/cluster.sql 2019-04-17 06:31:04 UTC (rev 17396)
+++ trunk/regress/core/cluster.sql 2019-04-18 05:35:07 UTC (rev 17397)
@@ -11,9 +11,9 @@
(7, 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))');
SELECT 't1', ST_AsText(unnest(ST_ClusterIntersecting(geom ORDER BY id))) FROM cluster_inputs;
-SELECT 't2', ST_AsText(unnest(ST_ClusterIntersecting(ST_Accum(geom ORDER BY id)))) FROM cluster_inputs;
+SELECT 't2', ST_AsText(unnest(ST_ClusterIntersecting(array_agg(geom ORDER BY id)))) FROM cluster_inputs;
SELECT 't3', ST_AsText(unnest(ST_ClusterWithin(geom, 1.4 ORDER BY id))) FROM cluster_inputs;
-SELECT 't4', ST_AsText(unnest(ST_ClusterWithin(ST_Accum(geom ORDER BY id), 1.5))) FROM cluster_inputs;
+SELECT 't4', ST_AsText(unnest(ST_ClusterWithin(array_agg(geom ORDER BY id), 1.5))) FROM cluster_inputs;
-- tests for ST_DBSCAN
