[postgis-tickets] [PostGIS] #4382: ST_Union of subdivided polygon fails on debbie
trac at osgeo.org
Sat Apr 20 14:37:18 PDT 2019
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 2.4.x
Keywords: |
Reproduces on debbie, not locally or on Travis. Traces go to GEOS SRID
handling.
make[2]: *** [Makefile:215: check] Error 1
make[2]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.0/regress/core'
make[1]: *** [Makefile:43: check] Error 2
make[1]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.0/regress'
make: *** [GNUmakefile:20: check] Error 1
[logbt] saw 'make' exit with code:2 (INT)
[logbt] Found corefile (non-tracked) at /tmp/logbt-
coredumps/core.690.!var!lib!jenkins!workspace!pg!rel!pg10w64!bin!postgres
[logbt] Processing cores...
[New LWP 690]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `postgres: postgres postgis_reg [local] SELECT
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007fe7051ae0d6 in
geos::geom::GeometryCollection::GeometryCollection (this=0x559b48811fb0,
newGeoms=<optimized out>, factory=<optimized out>, __in_chrg=<optimized
out>, __vtt_parm=<optimized out>) at
../../include/geos/geom/Geometry.h:271
271 return SRID;
Thread 1 (Thread 0x7fe70ef50300 (LWP 690)):
i = 2
ngeoms = 32
ngeoms = <optimized out>
i = <optimized out>
#1 0x00007fe7051af255 in
geos::geom::GeometryFactory::createGeometryCollection
(this=this at entry=0x559b487a51c0, newGeoms=newGeoms at entry=0x559b48802180)
at GeometryFactory.cpp:416
No locals.
#2 0x00007fe705d6d262 in GEOSGeom_createCollection_r
(extHandle=0x559b48786ea0, type=type at entry=7, geoms=0x559b48844ed8,
ngeoms=<optimized out>) at geos_ts_c.cpp:3063
gf = 0x559b487a51c0
vgeoms = 0x559b48802180
g = 0x0
handle = 0x559b48786ea0
#3 0x00007fe705d630e6 in GEOSGeom_createCollection (type=type at entry=7,
geoms=<optimized out>, ngeoms=<optimized out>) at geos_c.cpp:705
No locals.
#4 0x00007fe705da6c4e in pgis_geometry_union_finalfn
(fcinfo=0x7ffdcd3e8cf0) at lwgeom_geos.c:631
state = 0x559b48844e80
gser_out = 0x0
g = 0x0
g_union = 0x0
__func__ = "pgis_geometry_union_finalfn"
#5 0x0000559b47efa0cb in finalize_aggregate
(aggstate=aggstate at entry=0x559b487a9e20,
peragg=peragg at entry=0x559b487db9f8,
resultVal=resultVal at entry=0x559b487dbaf0,
resultIsNull=resultIsNull at entry=0x559b487dbb10 "",
pergroupstate=<optimized out>, pergroupstate=<optimized out>) at
nodeAgg.c:1592
numFinalArgs = <optimized out>
fcinfo = {flinfo = 0x559b487dba08, context = 0x559b487a9e20,
resultinfo = 0x0, fncollation = 0, isnull = 0 '\000', nargs = 1, arg =
{94125424922240, 0, 0, 94125424682912, 0, 140630199842754,
13641340179549726627, 13641340179549726627, 4716133919349538816,
4716133919349538816, 0, 94125424648480, 140630200771528, 94125424648496,
94125424622384, 140630199834314, 4716133919349538816, 9194493494814272512,
4716133919349538816, 94125424143296, 94125424143352, 94125424141472, 256,
94125417708966, 1, 128, 8192, 513, 18446744073709551536, 140630365650072,
65536, 1, 24, 0, 7, 32, 2, 94125423194128, 15, 64, 18446744073709551536,
0, 64, 140630199799886, 7, 94125424713568, 94125424713592,
140630199863426, 63, 112, 18446744073709551536, 1, 210453397509, 0, 0,
511101108315, 0, 532575944814, 2, 63, 64, 3, 18446744073709551536,
94125424144032, 140728046882704, 140630365656611, 140630200766512,
94125424713568, 94125424648480, 94125424648544, 94125424267712,
94125424144032, 94125424417656, 94125424417856, 672, 9194493494814272512,
94125424648544, 94125424140928, 0, 94125424140992, 94125424291848,
94125424288984, 94125424480992, 94125417707196, 94125424481104,
94125417708966, 94125424481104, 94125424065600, 94125424140992,
140630212429432, 94125424481104, 140728046882864, 94125424481104,
140728046882864, 94125424289264, 94125415154335, 94125424499744,
94125424291784, 140728046882928, 94125424961216}, argnull =
"\000\000\000\000\000\000\000\000\246=\026H\233U\000\000\300\346\204H\233U\000\000x\037\201H\233U\000\000\021\017\000\000\000\000\000\000\030p\332\005\347\177\000\000\260\224zH\233U\000\000\333\372\360G\233U\000\000\212\001\000\000\233U\000\000\360\245zH\233U\000\000(\260zH\233U\000\000p\247zH\233U\000\000\210\250zH"}
anynull = <optimized out>
oldContext = <optimized out>
i = <optimized out>
lc = <optimized out>
pertrans = <optimized out>
#6 0x0000559b47efa57c in finalize_aggregates
peraggs=peraggs at entry=0x559b487db9f8, pergroup=<optimized out>) at
nodeAgg.c:1799
peragg = 0x559b487db9f8
transno = <optimized out>
pergroupstate = <optimized out>
econtext = <optimized out>
aggvalues = <optimized out>
aggnulls = <optimized out>
aggno = 0
#7 0x0000559b47efb87a in agg_retrieve_direct (aggstate=0x559b487a9e20) at
nodeAgg.c:2505
tmpcontext = 0x559b487aa058
hash_pergroups = <optimized out>
outerslot = <optimized out>
i = <optimized out>
firstSlot = 0x559b487aa298
result = <optimized out>
hasGroupingSets = 0 '\000'
numGroupingSets = 1
currentSet = <optimized out>
numReset = <optimized out>
node = 0x559b487b8030
econtext = 0x559b487aa1d8
pergroup = 0x559b487dcb48
nextSetSize = <optimized out>
node = <optimized out>
tmpcontext = <optimized out>
peragg = <optimized out>
pergroup = <optimized out>
firstSlot = <optimized out>
hasGroupingSets = <optimized out>
numGroupingSets = <optimized out>
i = <optimized out>
#8 ExecAgg (pstate=0x559b487a9e20) at nodeAgg.c:2158
node = 0x559b487a9e20
result = 0x0
#9 0x0000559b47eecb4d in ExecProcNode (node=0x559b487a9e20) at
../../../src/include/executor/executor.h:250
No locals.
#10 ExecutePlan (execute_once=<optimized out>, dest=0x559b487bbb10,
direction=<optimized out>, numberTuples=0, sendTuples=<optimized out>,
operation=CMD_SELECT, use_parallel_mode=<optimized out>,
planstate=0x559b487a9e20, estate=0x559b487a9260) at execMain.c:1723
current_tuple_count = 0
current_tuple_count = <optimized out>
#11 standard_ExecutorRun (queryDesc=0x559b486c8180, direction=<optimized
out>, count=0, execute_once=<optimized out>) at execMain.c:364
estate = 0x559b487a9260
operation = CMD_SELECT
dest = 0x559b487bbb10
sendTuples = <optimized out>
oldcontext = 0x559b486d9ed0
__func__ = "standard_ExecutorRun"
#12 0x0000559b48037e6b in PortalRunSelect (portal=0x559b487c72c0,
forward=<optimized out>, count=0, dest=<optimized out>) at pquery.c:932
queryDesc = 0x559b486c8180
direction = <optimized out>
nprocessed = <optimized out>
__func__ = "PortalRunSelect"
#13 0x0000559b480394d8 in PortalRun (portal=portal at entry=0x559b487c72c0,
count=count at entry=9223372036854775807, isTopLevel=isTopLevel at entry=1
'\001', run_once=run_once at entry=1 '\001', dest=dest at entry=0x559b487bbb10,
altdest=altdest at entry=0x559b487bbb10, completionTag=0x7ffdcd3e9460 "") at
pquery.c:773
save_exception_stack = 0x7ffdcd3e9710
save_context_stack = 0x0
local_sigjmp_buf = {{__jmpbuf = {0, -1491573552534279655,
94125423641592, 140728046883936, 94125424407232, 2, -4647196651462350311,
-1491574116205614567}, __mask_was_saved = 0, __saved_mask = {__val =
{94125419562501, 94124208291841, 140727420601965, 94124208291840,
94125423631512, 0, 94125423631360, 94125419562501, 4, 1, 4,
140728046883934, 88, 94125424407232, 94125423641592, 94125419014460}}}}
saveTopTransactionResourceOwner = 0x559b486d45a0
saveTopTransactionContext = 0x559b486d4850
saveActivePortal = 0x0
saveResourceOwner = 0x559b486d45a0
savePortalContext = 0x0
saveMemoryContext = 0x559b486d4850
__func__ = "PortalRun"
#14 0x0000559b480351b1 in exec_simple_query (query_string=0x559b487259b0
"with inverted_geom as (\n select ST_Difference(\n", ' ' <repeats 15
times>, "ST_Expand('SRID=3857;POINT(0 0)' :: geometry, 20000000),\n", ' '
<repeats 15 times>, "ST_Buffer(\n", ' ' <repeats 19 times>,
"'SRID=3857;POINT(0 0)' :: geometr"...) at postgres.c:1122
parsetree = 0x559b4870c3c0
portal = 0x559b487c72c0
snapshot_set = <optimized out>
commandTag = <optimized out>
completionTag =
"\000\000\000\000\002\000\000\000Q\000\000\000\000\000\000\000\260\224>\315\375\177\000\000\360\225>\315\375\177\000\000\260YrH\233U\000\000\200!jH\233U\000\000\000\000\000\000\000\000\000\000\320\001mH\233U\000"
querytree_list = <optimized out>
plantree_list = <optimized out>
receiver = 0x559b487bbb10
format = 0
dest = DestRemote
oldcontext = 0x559b486d4850
parsetree_list = 0x559b4870c420
parsetree_item = 0x559b4870c3f8
save_log_statement_stats = 0 '\000'
was_logged = 0 '\000'
isTopLevel = 1 '\001'
msec_str =
"\000\000\000\000\002\000\000\000Q\000\000\000\000\000\000\000\260\224>\315\375\177\000\000\360\225>\315\375\177\000"
__func__ = "exec_simple_query"
#15 0x0000559b480368e2 in PostgresMain (argc=<optimized out>,
argv=argv at entry=0x559b486d01d0, dbname=<optimized out>,
username=<optimized out>) at postgres.c:4117
query_string = 0x559b487259b0 "with inverted_geom as (\n select
ST_Difference(\n", ' ' <repeats 15 times>, "ST_Expand('SRID=3857;POINT(0
0)' :: geometry, 20000000),\n", ' ' <repeats 15 times>, "ST_Buffer(\n", '
' <repeats 19 times>, "'SRID=3857;POINT(0 0)' :: geometr"...
firstchar = <optimized out>
input_message = {data = 0x559b487259b0 "with inverted_geom as (\n
select ST_Difference(\n", ' ' <repeats 15 times>,
"ST_Expand('SRID=3857;POINT(0 0)' :: geometry, 20000000),\n", ' ' <repeats
15 times>, "ST_Buffer(\n", ' ' <repeats 19 times>, "'SRID=3857;POINT(0 0)'
:: geometr"..., len = 439, maxlen = 1024, cursor = 439}
local_sigjmp_buf = {{__jmpbuf = {140728046884368,
4646110874158869017, 94125423206784, 140728046884928, 94125423395280,
94125420647040, -4647196651388949991, -1491574109633795559},
__mask_was_saved = 1, __saved_mask = {__val = {0, 94125423395208, 1024,
140728046884800, 140728046884928, 94125423395280, 94125417734909, 0,
94125417708966, 94125420647040, 140728046884800, 140728046884928,
94125417623520, 94125423333184, 4398046511104, 0}}}}
send_ready_for_query = 0 '\000'
disable_idle_in_transaction_timeout = 0 '\000'
__func__ = "PostgresMain"
#16 0x0000559b47fbb497 in BackendRun (port=0x559b486c9530) at
postmaster.c:4406
ac = 1
secs = 609109337
usecs = 382752
i = 1
av = 0x559b486d01d0
maxac = <optimized out>
av = <optimized out>
secs = <optimized out>
usecs = <optimized out>
i = <optimized out>
__func__ = "BackendRun"
#17 BackendStartup (port=0x559b486c9530) at postmaster.c:4078
bn = <optimized out>
pid = <optimized out>
__func__ = "BackendStartup"
save_errno = <optimized out>
#18 ServerLoop () at postmaster.c:1756
port = 0x559b486c9530
i = <optimized out>
rmask = {fds_bits = {32, 0 <repeats 15 times>}}
selres = <optimized out>
now = <optimized out>
readmask = {fds_bits = {56, 0 <repeats 15 times>}}
nSockets = 6
last_lockfile_recheck_time = <optimized out>
last_touch_time = 1555793903
__func__ = "ServerLoop"
#19 0x0000559b47fbc33c in PostmasterMain (argc=3, argv=0x559b4869ffd0) at
postmaster.c:1364
opt = <optimized out>
status = <optimized out>
userDoption = <optimized out>
listen_addr_saved = <optimized out>
i = <optimized out>
output_config_variable = <optimized out>
__func__ = "PostmasterMain"
#20 0x0000559b47d3fd86 in main (argc=3, argv=0x559b4869ffd0) at main.c:228
No locals.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4382>
