[postgis-tickets] r17414 - Multiple fixes for undefined behaviour in implicit conversions
Raul
raul at rmr.ninja
Wed Apr 24 04:07:56 PDT 2019
Author: algunenano
Date: 2019-04-24 04:07:56 -0700 (Wed, 24 Apr 2019)
New Revision: 17414
trunk/liblwgeom/ptarray.c
trunk/loader/shp2pgsql-core.c
trunk/postgis/lwgeom_functions_basic.c
shp2pgsql-core.c:839:22: runtime error: implicit conversion from type 'int' of value -1 (32-bit, signed) to type 'DBFFieldType' changed the value to 4294967295 (32-bit, unsigned)
runtime error: implicit conversion from type 'int32' (aka 'int') of value -1 (32-bit, signed) to type 'uint32' (aka 'unsigned int') changed the value to 4294967295 (32-bit, unsigned)
UndefinedBehaviorSanitizer: undefined-behavior lwgeom_functions_basic.c:2237:10 in
runtime error: implicit conversion from type 'unsigned int' of value 4294967295 (32-bit, unsigned) to type 'int' changed the value to -1 (32-bit, signed)
UndefinedBehaviorSanitizer: undefined-behavior ptarray.c:333:13 in
References #4383
Modified: trunk/liblwgeom/ptarray.c
--- trunk/liblwgeom/ptarray.c 2019-04-24 11:03:39 UTC (rev 17413)
+++ trunk/liblwgeom/ptarray.c 2019-04-24 11:07:56 UTC (rev 17414)
@@ -329,9 +329,11 @@
void
ptarray_reverse_in_place(POINTARRAY *pa)
- int i;
- int last = pa->npoints-1;
- int mid = pa->npoints/2;
+ if (!pa->npoints)
+ return;
+ uint32_t i;
+ uint32_t last = pa->npoints - 1;
+ uint32_t mid = pa->npoints / 2;
double *d = (double*)(pa->serialized_pointlist);
int j;
Modified: trunk/loader/shp2pgsql-core.c
--- trunk/loader/shp2pgsql-core.c 2019-04-24 11:03:39 UTC (rev 17413)
+++ trunk/loader/shp2pgsql-core.c 2019-04-24 11:07:56 UTC (rev 17414)
@@ -836,7 +836,7 @@
int field_precision, field_width;
char name[MAXFIELDNAMELEN];
char name2[MAXFIELDNAMELEN];
- DBFFieldType type = -1;
+ DBFFieldType type = FTInvalid;
char *utf8str;
/* If we are reading the entire shapefile, open it */
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2019-04-24 11:03:39 UTC (rev 17413)
+++ trunk/postgis/lwgeom_functions_basic.c 2019-04-24 11:07:56 UTC (rev 17414)
@@ -2229,7 +2229,7 @@
GSERIALIZED *pglwg1, *result;
LWLINE *line, *outline;
- uint32 which;
+ int32 which;
POSTGIS_DEBUG(2, "LWGEOM_removepoint called.");
@@ -2244,9 +2244,9 @@
line = lwgeom_as_lwline(lwgeom_from_gserialized(pglwg1));
- if (which > line->points->npoints - 1)
+ if (which < 0 || (uint32_t)which > line->points->npoints - 1)
- elog(ERROR, "Point index out of range (%d..%d)", 0, line->points->npoints - 1);
+ elog(ERROR, "Point index out of range (%u..%u)", 0, line->points->npoints - 1);
PG_RETURN_NULL();
@@ -2256,7 +2256,7 @@
PG_RETURN_NULL();
- outline = lwline_removepoint(line, which);
+ outline = lwline_removepoint(line, (uint32_t)which);
/* Release memory */
lwline_free(line);
@@ -2275,7 +2275,7 @@
LWLINE *line;
LWPOINT *lwpoint;
POINT4D newpoint;
- int32 which;
+ int64_t which;
POSTGIS_DEBUG(2, "LWGEOM_setpoint_linestring called.");
@@ -2307,11 +2307,11 @@
if (which < 0)
/* Use backward indexing for negative values */
- which = which + line->points->npoints;
+ which += (int64_t)line->points->npoints;
- if ((uint32_t)which + 1 > line->points->npoints)
+ if ((uint32_t)which > line->points->npoints - 1)
- elog(ERROR, "abs(Point index) out of range (-)(%d..%d)", 0, line->points->npoints - 1);
+ elog(ERROR, "abs(Point index) out of range (-)(%u..%u)", 0, line->points->npoints - 1);
PG_RETURN_NULL();
