[postgis-tickets] [PostGIS] #4324: Use pkg-config to improve dependency detection
trac at osgeo.org
Mon Feb 11 08:31:13 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
Mailist: https://lists.osgeo.org/pipermail/postgis-
devel/2019-February/027687.html
The idea is to use pkg-config for those dependencies that support it when
the corresponding option (e.g. `--with-projdir`) isn't set.
This has several benefits:
- It doesn't matter where you've installed your packages as long as the
pkg-build path is set up correctly, for example, OSX with brew.
- It's much simpler to support: You can do a one-liner to check if the
library is available and which flags to use.
- If any dependency in the future decided to change their API (different
include structure, change its library name), the pkg-build would work
automatically. OTOH, it'd be a nightmare with the hardcoded paths and
libraries.
For now, I've kept the `--with-XXdir` options as the first priority,
defaulting to pkg-build only if the option isn't passed and `pkg-build` is
available. I'm also showing a warning when using those options.
In the future (before final release) we should decide whether to keep the
options and/or the warnings.
Note that, for full manual configuration, if the proper "--prefix" is
passed when configuring proj:
./configure --with-projdir="/home/raul/dev/build/proj.4"
is equivalent to
./configure PKG_CONFIG_PATH="/home/raul/dev/build/proj.4"
which, with current proj, is equivalent to
./configure PROJ_CFLAGS="/home/raul/dev/build/proj.4/include"
PROJ_LIBS="-L/home/raul/dev/build/proj.4/libs -lproj"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4324>
