[postgis-tickets] [PostGIS] #4304: Add seed parameter to ST_GeneratePoints
PostGIS trac at osgeo.org
Tue Feb 12 03:25:45 PST 2019
  Reporter:  Mike Taves  |      Owner:  Mike Taves
      Type:  patch       |     Status:  reopened
  Priority:  blocker     |  Milestone:  PostGIS 3.0.0
 Component:  postgis     |    Version:  trunk
Resolution:              |   Keywords:
Changes (by Algunenano):
 * priority:  medium => blocker
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Dronie isn't happy about this patch, it appears to fail when checking
 upgrades (but it's not clear in the final message).
 The npoints parameter has changed from `numeric` to `integer`. Should the
 old signature moved to legacy so the upgrade is possible?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4304#comment:5>
