[postgis-tickets] [PostGIS] #4321: OSX cannot link libwagyu without -lstdc++
PostGIS trac at osgeo.org
Tue Feb 12 03:34:14 PST 2019
  Reporter:  pramsey  |      Owner:  Algunenano
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by Raul Marin):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17250" 17250]:
 #!CommitTicketReference repository="" revision="17250"
 Wagyu build improvements
 Use same compiler as postgresql (adds extra -x cxx)
 Pass the C++ standard library to postgres when linking wagyu
 Closes #4321
 Closes https://github.com/postgis/postgis/pull/371
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4321#comment:5>
