[postgis-tickets] r17251 - Fix upgrades.
Darafei
komzpa at gmail.com
Wed Feb 13 02:23:15 PST 2019
Author: komzpa
Date: 2019-02-13 14:23:14 -0800 (Wed, 13 Feb 2019)
New Revision: 17251
trunk/postgis/postgis.sql.in
trunk/postgis/postgis_drop_after.sql
Fix upgrades.
References #4304
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2019-02-12 11:34:13 UTC (rev 17250)
+++ trunk/postgis/postgis.sql.in 2019-02-13 22:23:14 UTC (rev 17251)
@@ -3487,6 +3487,7 @@
COST 1; -- reset cost, see #3675
-- Availability: 2.3.0
+-- Changed: 3.0.0
CREATE OR REPLACE FUNCTION ST_GeneratePoints(area geometry, npoints integer)
RETURNS geometry
AS 'MODULE_PATHNAME','ST_GeneratePoints'
Modified: trunk/postgis/postgis_drop_after.sql
--- trunk/postgis/postgis_drop_after.sql 2019-02-12 11:34:13 UTC (rev 17250)
+++ trunk/postgis/postgis_drop_after.sql 2019-02-13 22:23:14 UTC (rev 17251)
@@ -154,6 +154,7 @@
DROP FUNCTION IF EXISTS ST_AsBinary(text); -- deprecated in 2.0
DROP FUNCTION IF EXISTS postgis_uses_stats(); -- deprecated in 2.0
+DROP FUNCTION IF EXISTS ST_GeneratePoints(geometry, numeric); -- numeric -> integer
-- Old accum aggregate support type, removed in 2.5.0
DROP TYPE IF EXISTS pgis_abs CASCADE;
