[postgis-tickets] r17264 - Add lost rounding for PG12
Darafei
komzpa at gmail.com
Tue Feb 19 11:28:14 PST 2019
Author: komzpa
Date: 2019-02-19 23:28:14 -0800 (Tue, 19 Feb 2019)
New Revision: 17264
trunk/regress/core/measures.sql
Modified: trunk/regress/core/measures.sql
--- trunk/regress/core/measures.sql 2019-02-20 06:55:15 UTC (rev 17263)
+++ trunk/regress/core/measures.sql 2019-02-20 07:28:14 UTC (rev 17264)
@@ -107,11 +107,11 @@
select 'distancepoly2',
ST_Distance(a, b),
- st_maxdistance(a, b),
- st_astext(st_shortestline(a,b)),
- st_astext(st_shortestline(b,a)),
- st_astext(st_longestline(a,b)),
- st_astext(st_longestline(b,a)) from (
+ st_maxdistance(a, b)::numeric(12,6),
+ st_astext(st_shortestline(a,b)),
+ st_astext(st_shortestline(b,a)),
+ st_astext(st_longestline(a,b)),
+ st_astext(st_longestline(b,a)) from (
select ST_GeomFromText('POLYGON((17 14, 16 17, 17 18, 17 17, 17 14))') as a,
ST_GeomFromText('POLYGON((-1 -1, -1 25, 25 25, 25 -1, -1 -1), (14 14,14 19,19 19,19 14,14 14))') as b
) as foo;
@@ -118,11 +118,11 @@
select 'distancepoly3',
ST_Distance(a, b),
- st_maxdistance(a, b)::numeric(12,6),
select ST_GeomFromText('POLYGON((17 16, 16 17, 17 19, 17 17, 17 16))') as a,
) as foo;
